Question about Toshiba 57H81 57" Rear Projection Television
Toshiba 57H81, power to transformer and flyback.
I changed out the IC's, and one pecos fuse. I turned on TV and everything was perfect. Ran TV for about 2 hours, then went to bed. Next morning turned on TV and nothing. An attempt to start up, could hear relay kicking in and then got a continuous red flashing led light from power on led light on front of TV. Checked the pecos fuse and replaced , it went out. Powered up TV, Transformer fired up, relay engaged. Guns never engaged and pretty quickly could smell something burning, disconnected the power from the board and lokked for burn outs. Couldnt find any sign to reveal what burned out, Connected power to board and get No power to flyback transformer or main transformer. Get a start up power for TV, minus the firing up of guns and a solid red led light at front power led light on TV. Trouble shot the power failure to what is a photo coupler, but not sure if that the problem. Photo coupler is ET1103. Any ideas on what my problem is. Thank you Sunny
  • Sundance McCoy
    Sundance McCoy Jan 22, 2009
    I have power light on, system starts up, except transformers. I have 1 pecos 125amp 1.25w that registers neg. on the board with out power. Can pecos fuses be universally checked?
  • Sundance McCoy
    Sundance McCoy Jan 23, 2009
    I have checked and resoldered the c810 and c809, Q751,q752 f 850, f 852 pecos fuses and still have the same problem. The ics were snug and proper thermal heat compound applied. I get power to the system just mothing to the flyback of transformer..im going for the schlematics now. If you think of anything please let me know.
    Sergeant:
    Champion:
  • 346 Answers
You need to check the 1.8 ohms resistors 2watts, the horizontal output transistor.make sure that the ics that you replaced and the fuses are the exact rating that were on the original
Posted on Jan 24, 2009
    Sergeant:
    Champion:
  • 267 Answers
IF YOU REPLACED THE SAME PICO FUSE, YOU PROBABLY HAVE A BAD CONVERGENCE IC AGAIN . DID YOY SNUG UP THE IC TO THE HEAT SINK AND USE THERMAL HEAT COMPOUND ON THE NEW IC'S? ALSO CHECK SOLDER CONNECTIONS TO C810 AND C809 THE FUSE BY THE CAPACITORS MAY BE OPEN.
Posted on Jan 23, 2009
I have a Sony model KV-32S26 that will not turn on, been sitting for about 2 years. Had a tv repair guy tell me it was the flyback transformer. If that's the case, can I replace it myself? Thanks
1) You must test the a) fuse b) c.breaker inside c) diode, d) rectifier e) transformer f) filter. g) IC. regulator voltage and test it. If the problem persist you must go to the horizontal problem by lack of RASTER, now you test the transistor horizontal power, flyback. If you have some experience with the electronic you can try. If do not, better go to the repair shop Tv. Since you can have a electric shock by H.Voltage discharge.
God bless you
Oct 11, 2012 | Sony KV-32S26 32" TV
Dark, fuzzy picture
The fluid in the CRT bulbs is most likely cloudy. Check the blue to see if fluid is clear. If fluid is clear, then likely your flyback transformer is failing. I assume you already check the brightness and contrast settings on the tv.
Feb 18, 2011 | Toshiba 57H81 57" Rear Projection...
No power or red led fuse good .toshiba 27df46
Hello Hloggins, hi, your power supply is not producing the pulse needed to start the switching. check for the IC on the oscillator part of the power supply, you need an Oscilloscope to test this. if there is no scope. i suggest you replace the IC.
May 20, 2010 | Toshiba 27DF46 27" TV
No Sound on Toshiba 57H81 projection TV. Picture is fine.
The sound amplifier IC has went bad and needs replaced. Call a good TV Tech.
Check with the BBB 1st before you decide on one.
Jun 19, 2009 | Toshiba 57H81 57" Rear Projection...
Hyundai 14" colored tv no power
if the final flyback is ok ,then check the driver transistor and the voltage in his collector .Probably the flyback transformer is ok.please reply.
Oct 17, 2008 | Sharp 25R-S100 25" TV
Tv will not turn on
First, locate the horizontal output transistor. This is found very close to, or next to, the horizontal output transformer (also known as the flyback). The flyback should be on an aluminum heat sink, or on the side of the metal chassis. Disconnect or unsolder two of the three legs of the transistor. Measure it with your meter, or plug in the set with the light bulb attached across the fuse.
If the transistor is shorted, or the light bulb doesn’t glow bright anymore, replace the transistor and plug back in. If the light bulb glows bright again, you must replace both the flyback and horizontal output transistor simultaneously. In some cases this will fix the set, but sometimes there are multiple problems with a set.
Go to where the flyback is, and start measuring the diodes and capacitors on the flyback itself. If you don't find any shorts there, it could be a shorted vertical output IC, a shorted sound IC, a shorted disc capacitor in the Hi Voltage/sweep circuit, or in rare cases, a shorted capacitor or tuner.Feel free to ask and post whatever the result of your troubleshooting..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 25, 2008 | Toshiba 32A33 32" TV
Toshiba 57H81
Check all fuses in the power supply and look for any bad connrctions on the PCB. You are probably missing the 130 volt supply to the horizontal circuit. Common reasons are: Shorted horiz output transistor; flyback transformer, picture tube arcing , bad power regulator IC. In short, you need to get a qualified tech for this symptom. Hope this helps.
Oct 29, 2007 | Toshiba 57H81 57" Rear Projection...
TV won't turn on
Check supply at BU508 COLLECTOR. IF SUPPLY DROPS BELOW 100V LOT IS FAULTY. CHANGE LOT.PROBLEM SOLVED
Aug 22, 2007 | Philips TS3259C TV
No power
Check the FBT and the Horizontal Output Transistor also.
Sep 18, 2006 | Panasonic TX-15AT1 15" TV
Toshiba 57H81 57" Rear Projection Television Logo
256 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
