Question about Zenith ZN110 Remote Control
Change Sony Trinitron TV settings without remote control
I have no remote for my Sony Trinitron TV, and this model doesn't have manual buttons for accessing the menu (button panel is on the side of the tv and only has program, volume, language buttons) ; I also can't find the exact model anywhere on the tv (it was a hand me down).
I need to check the resolution settings as today my Sky has started to change the normal 16:9 format to 4:3 on certain channels. This has never been a problem before today but I am told that somehow the TV settings may have gone onto Auto rather than staying permanently on 16:9. So I need to access the settings to check and change.
Thanks
jomaru
  • 337 Answers
SOURCE: Cannot access menu
The tv has lost the menu,in order for the menu to come up in the screen it needs horizontal and vertical sync,the syncs come from the secondary of the flyback and from the vertical Ic.Is rare but We have seen it happen,sometimes you also have an Ic called character generator and it could be bad.You will need the assitance of a servicer for this problem because there are voltages to measure and signal to trace.
Posted on Oct 02, 2006
SOURCE: Zenith TV not programmed for home purpose
Got the same problem.  How can we reprogram these TVs?
Posted on Jul 03, 2008
SOURCE: Sony Trinitron
the code for the sony trinitron is 0414
have a nice day
Angelus
Posted on Aug 03, 2008
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Posted on Jan 17, 2009
SOURCE: I need the remote control codes
Codes for OneForAll URC-7030
Sony:
1505
0505
1651
1010
0011
0036
0102
0074
Procedure:
- press the "tv" button
- press and keep pressed the "magic" button until tv button blinks twice
- insert one of the codes
- try to switch off the tv set: if this works, press "magic" again to confirm the code.
Otherwise, proceed via automatic search:
- press "tv"
- press and keep pressed "magic"
- dial "991": "tv" button will blink twice
- press "tv" then press the standby button on the rc, repeating this last step until your tv set turns off. this may take several "tv>>standby" pressions.
when your tv set responds properly, press "magic" to confirm".
Posted on May 09, 2009
What is the code for a 2001 Sony Trinitron?
Search Results
    Sony eSupport - Remote Control Codes & Programming ...
    https://esupport.sony.com/.../select-system.pl?...RCOD...
    Sony CorporationFind the codes you need to program your remote control. ... Television - Accessories; Television - FD Trinitron® & WEGA™; Television - Internet TV & Players ...
    [PDF]Trinitron Color TV - Manuals, Specs & Warranty - Sony
    https://docs.sony.com/release/KV20FV12.PDF Sony CorporationRefer to section 54-300 of Canadian Electrical Code for Antenna Grounding. Lightning .... Congratulations on your purchase of the Sony Trinitron Color TV.
Dec 08, 2015 | Sony Televison & Video
Programming a URC22B universal remote controller
You are looking for a code for your remote correct ?
Jul 01, 2008 | Jensen JR500 Remote Control
Sony KV-13FS100 - channels cycling
you need to change the control board or the touch buttons
Apr 12, 2008 | Sony FD Trinitron WEGA KV-13FS100 13" TV
We have a sony trinitron tv that after using sleep mode turns itself back on after a couple hours. any idea how to fix this?
Get into its menu, come over to timer settings. Set the timer to 0:00. The set never get Off after that. Now, it might be set to 2:00; I assume. You should have its remote control to set this, as some Sony Trinitron models will not have a Menu button at its front panel control; to enter into its menu option.
Electrohelponline
Oct 04, 2014 | Sony FD Trinitron WEGA KV-27FV17 27" TV
Need operators manual for tv sony kv2183wr
There are channel select buttons on the front of your tv push those to recieve local stations (if you are watching cable programming look for the cable box remote)
Apr 09, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-36FV26- no remote control. trying to reset to factory settings. Any ideas?
There is no other way to select factory setting, without its remote control.
Apr 04, 2013 | Sony KV-20S20 20" TV
I have got a sony trinitron tv, without a remote control, i can i set up tv chanels without remote?
there is hundreds off universal remotes out there and yes they do work but try to avoid the cheeper models as they can be verry dificult to set up hope this helps you
Jun 13, 2010 | Televison & Video
TV doesn't respond to remote controller suddenly. I changed batteries of the controller and checked it. The controller is not a problem. I tried manual buttons on TV but it didn't work. TV turns on and...
This is caused by radio frequency and what i mean by that isyour tv unit is gettng confused with the crystals that control the connection between the tv and remote.The solution to this is to go to wal mart and buy a new universal remote and in the package should be an instruction manual to set the remote to the tv , First find your tv name in the pamplet,second there will show a code of the remote type it in and enjoy.
May 18, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Cant change the bright of the sony trinitron (FROM THE REMOTE )
this is a problem with the sony tv set not your remote.
you can have a tech turn up the HV seting on the botem of your fly back and at same time have him do a diagnostics on the tv set.
Jan 09, 2009 | Sony RM-Y173 Remote Control
How to turn on Sony Trinitron without a remote control
Good day.
Please check with the channel buttons of your unit. They replace the power buttons functions.
chris
Mar 21, 2008 | Sony KV-27V40 27" TV
Zenith ZN110 Remote Control Logo
507 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
