Question about GE JVM1631 Microwave Oven
Microwave makes deep humming sound and doesn't heat
I have a GE JVM163 that isn't heating at all. When I turn it on, it sounds normal for about two seconds then suddenly the "hum" changes sound and gets a little deeper and louder. Any ideas?
    Novelist:
  • 140 Answers
Your magnetron that actually does the cooking is making that humming sound. That part needs to be replaced before it starts blowing your fuse inside the microwave. That part is the one located on top behind the control panel of your microwave and is about the size of a persons hand (sometimes smaller sometimes bigger). With everthing unplugged you can take the cover off and see it. It has some cooling fins on it and is held in place with only three to four screws. There are three to four wires that come out of it and go to only a couple of places one of them being a large capacitor that is about three to four inches long with terminals at its top. Find a magnetron at a local tv repair shop (reputable), a local electronic supply house (they can order you one) or on the internet. They cost from $25 to $60 depending on size of microwave. If you can do it yourself you can save about $40 to $50. Let me know how it goes. Good luck.
Posted on Jan 22, 2009
GE microwave JE1660WB001 does not heat makes humming sound
The magnetron has gone and is the heart of the microwave oven, this part is the most expensive to replace, cheaper to buy new in the long run.
Apr 19, 2012 | GE JE1660 Microwave Oven
Does not heat up food everything else is OK i think that the rack touch the door when i was using it
Double check and make sure that the rack did't scratch the paint inside the cavity. Could be two possible reasons for it not to heat. Could possible be the magnetron or the diode. Normal when the magnetron goes bad, the microwave will still sound almost normal, bit just wouldn't heat. when the diode goes bad the microwave tends to make a humming sound when turned on
Feb 12, 2011 | Whirlpool MH3184XP Microwave Oven
It just stoped heating or cooking foods why im hungry
If the microwave is making a humming sound, the diode is bad and needs to be replaced. If it sounds normal, but just not heating, then the magnetron is bad and needs to be replaced. If it is the magnetron, I suggest that you change the diode as well.
Feb 10, 2011 | General Electric Microwave Oven
Jvm1650cb003 has power to unit, fuse is good, all items function, but will not cook or heat items
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Feb 10, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE space maker JVM1640. Does not heat food.
with out a proper diagnosis, i would have to believe your magnetron is gone
Oct 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1850CH06 microwave no heat with loud humming sound
With the details you described, the high voltage diode might be shorted( usually HVR 1X). It is connected from the Capacitor and the chassis, or else the capacitor is the one at fault,but not common .
Aug 29, 2009 | GE JVM1850 1000 Watts Microwave Oven
Microwave doesn't heat anything
This more than likely is the magnatron,< heats food >, making noise and not working. it isn,t really easy fix and can be done if you get part and experienced person to walk you through it. Most GE magnatrons have at least 5 yr warranty and if it isn't that old call them first.
Apr 23, 2009 | GE JVM1320 Microwave Oven
GE profile JE1660WB01
may be megnetron or high voltage circuit ..
Sep 29, 2007 | GE JE1660 Microwave Oven
GE JVM1631 Microwave Oven Logo
221 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
