Question about Samsung Dryers
Dv456 Take apart push out dent on top of dryer
3 Suggested Answers
  • 9 Answers
SOURCE: dented top on kenmore ge3 dryer
Yes it is, remove the 4 set screws and top comes off.
Posted on Apr 28, 2009
machinetech7
  • 1344 Answers
SOURCE: Electrolux dryer model EIED55HBM0 dented on top
There are two clips, one on each side that are between the top and the front piece of the machine. Take a flat screwdriver and press each clip in and the top should just lift up
Posted on Jun 03, 2012
I dented the top of my dryer (Whirlpool Cabrio model number WGD5600XW0) and want to know how to remove top to fix dent.
-Here a sample to remove most brand 's top.
-Unplug the power, then remove couple screw on the upper back
-Now use Flat head screw driver wrap the tip with clothe then pry the front that sit on the end up.
Good Luck
Mai
Nov 14, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Broken bumper
if it is memory lets just say plastic try a blow dryer at the dent dont let it get to hot an than try to push it back out may just pop back out ...if fiberglass well Body shop here we come unless ya want to learn how
Nov 25, 2013 | Cars & Trucks
Electrolux dryer model EIED55HBM0 dented on top and is now grinding when it runs. How do I take the covering off to push out dent?
Jun 03, 2012 | Electrolux Dryers
My whirlpool duet dryer is working but is very loud like there is loose change in it. It is also banging at the top and has left a dent in it.
Maybe you can take off the cover, one of the rollers is either off or broken..best thing is to replace both rollers. When cover is off gently push dent out make sure dent doesn't reoccur. Hope this helps. PS..Never put anything heavy on top.
Feb 28, 2012 | Whirlpool Dryers
Brand new dryer sounds like the drum is grinding intermittently
Hi tebb1623..
You did not provide enough information about your dryer to help guide you thru the repair.
So the only thing I can help you find the problem is to tell you what COULD be wrong with your dryer.
1..Felt seal missing or out of place causing the rotating drum to rub on the door, look for signs of rubbing on the door.
2. Rear bearing that holds the drum up is worn,broken,slipped,out of place.
3.Drum rollers are worn, have string,hair,etc wound around the roller shafts.
You will need to either call the service man, or risk doing the job yourself and possibly voiding your warrenty.
Please take time to rate me
Sep 04, 2011 | Dryers
Dented top on kenmore ge3 dryer
Apr 28, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer making a grinding or rumbling noise when it is on
i would bet you hae a dented top of the dryer. thats what is hitting the drum causing the noise. if you put something heavy on top of the unit then the top could have bent down and is now hitting the drum when it runs. and heat as it runs will make it worse.
if yo can, pull the top up and re-shape the top so it doesnt hit th drum and then dont let the top get pushed down again.
Jan 15, 2009 | Estate EED4300SQ Dryer
Dented rear bumper, how does bumper detach to pound out?
is it a rubber bumper? use suction cups, thats what dent specialist use instead of takin off the entire bumper. use a winshield dashboard suction cup for example. Just be creative...
Sep 30, 2008 | 2006 Kia Sportage
Gas dryer LG DLG3788W
Take a 2 inch putty knife and slide in the separation gap just above the door.  There are 2 catches on each of the panel about 3 inches from each side.  Push in to release the catch and the top panel will pop open.
Jun 01, 2008 | LG DLG3788W Gas Dryer
Dryers Logo
142 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
