Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
The on off switch is pushed in and won't respond
  • 4 Answers
Check all fuses and circuit breakers to make sure there is ample power
Posted on Feb 23, 2009
I am self cleaning my wall oven. I have an error message with F 10 but the oven will not respond when I push stop.
Flip the electrical circuit switch for your oven after 5-10 minutes watch what it does when you do. After it reboots follow normal procedures should respond properly. If not push your stop button keep pushing on it for at least 15 30 seconds this should clear it. If not flip the power switch again then watch it as it reboots when you turn it back on it should respond. What has happened is you have knocked the program out of operation mode. You need to clear that is why you need to shut the off to oven then start again.
Nov 19, 2017 | Ovens
make sure push start switch is not stuck pushed in.Also sounds like the switch mounted on the motor could be stuck, which means new motor. Does motor start and stop with timer being moved to the off position ?.If so then not the motor.
Jul 01, 2013 | Dryers
Sylvania TV lc320ssx keeps switching input modes and won't and cannot stop it. Won't respond to remote or on set controls
Its main system control memory IC is faulty. Replace it. It can be located very near to the main system control IC. Will look like this.5328cc98-0a90-4a81-8aa5-f9c8c2b31484.jpgVery cheap to buy, easly available.
Jun 05, 2013 | Televison & Video
My Beko MW5104 is frozen and does not respond to any settings. It is permanently on at spin/end with the green light on. I can switch it on and off. I have unplugged it from the mains and switched it off...
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
I have 2004 chev tahoe w/ a viper remote starter system,but no key fob. I replaced the car battery & now the cars computer won't let it start. How do I reset the computer?
The car's computer wont let it start?
Well, if you changed the battery and the viper alarm is the issue; locate the push button valet/programming switch. Turn the ignition on, press and release the switch. The alarm will disarm and you can start the vehicle.
To put the alarm in valet, turn the ignition on then off, within 10 seconds press and release the valet switch. The LED will illuminate solid to show that the system is in valet.
Aug 20, 2012 | 5900 SST 2-Way Security System / Remote...
Featherlite primmer button won`t work. put new gas lines on and they are open, still when I push the primmer it draws no fuel and won`t respond back as if it has a vacume holding it compressed?? can you...
If there is a blockage in the fuel sysstem the bulb will not return, check the fuel filter in the tank, check the fuel hoses are not kinked, if this does not help the blockage will be in the carb itself.
Jun 15, 2011 | Garden
The adapter to my Western Digital Book does not respond
The monitor requires a adapter with a current output of 4 amps. but the Western Digital Book adapter can only supply 2 amps (half the current required by the monitor).
This means using the WD adapter on the monitor will stress this adapter beyond its capacity and continual use of this adapter on the monitor will cause it to fail and/or switch off if it has overload protection.
If you are having problems with the 2 amp adapter on the WD Book, then the power adapter could be faulty or it maybe OK when the adapter cools down.
I suggest you get a 12 volt 4 or more amps adapter for the monitor.
You may need an adapter for the WB book too if the adapter is faulty.
Dec 06, 2009 | Western Digital My Book Essential Edition...
Washing Machines Logo
47 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
