Shredders
Problem for Shredders
Generic problem for all Shredders
Shredder won't run
By deedon on Feb 16, 2009
This Staples SPL-1506X crosscut shredder quit working. It is well past warranty so I took it apart. With it unplugged and while apart I cheated the cutoff switch and removed the sensor connector from the circuit board. I plugged it back in and put it in shred mode and it ran for just a second or two. It may have quit because of sensing the bin to be full - I don't know. I did not think to check it in reverse. I put it back together and it worked so I shredded some papers.
Then I took it back upstairs to my office and was going to shred more but it wold not work again. I took it back to my workshop and took it apart again. Now it won't work at all.
The green power light goes on and stays on but the motor is not running in either forward or reverse. If I put paper in it a click sounds so I know the sensor is working.
Comments:
Feb 16, 2009
- I have received two solutions:
The first said "try first unplugging power cable for five minutes."
The shredder has been unplugged and replugged multiple times since the problem began.
This was no help.
The second said, "check the connection once again .... "
What connection. All connections seem to be OK.
Still need help.
Feb 19, 2009
- This Staples SPL-1506X crosscut shredder quit working. It is well past warranty so I took it apart. With it unplugged and while apart I cheated the cutoff switch and removed the sensor connector from the circuit board. I plugged it back in and put it in shred mode and it ran for just a second or two. It may have quit because of sensing the bin to be full - I don't know. I did not think to check it in reverse. I put it back together and it worked so I shredded some papers.
The green power light goes on and stays on but the motor is not running in either forward or reverse. If I put paper in it a click sounds so I know the sensor is working.Comment posted on Feb 16, 2009
This was no help.
Still need help.
Solution #1
Not Helpful)
gopi20
Rank: Wiz
Rating: 80%, 276 votes
Was this helpful?
Yes
No
Solution #2
posted on Mar 22, 2009
Not Rated)
Calpil0t
Rank: Apprentice
Rating: 0%, 0 votes
I had similar problem. I took unit apart and checked the motor by hotwiring it after checking voltage coming off the circuit board connections that the motor is connected to. Motor did not run until I tapped it a couple times with a hammer. Seems ok now.
Was this helpful?
Yes
No
Solution #3
posted on Feb 19, 2009
Not Rated)
askmee
Rank: Wiz
Rating: 85%, 150 votes
Once it powers on there is no electrical problems and fuses are fine.
Most common problem for shredders to get stuck is the paper jammed in the corner. Check it one more time for tighny paper pieces.
Also maybe good idea to use the shredder with another paper bin to see if it is working. If it works look for the problem in bin assembly.
If still no help, motor itself is bad. Futhrer repair is not worthy.
Good Luck
Was this helpful?
Yes
No
Solution #4
Not Rated)
fossildude
Rank: Wiz
Rating: 84%, 281 votes
hiya there!
you have done:
1. checking all the connections, you have turned off and on the power.
2. did you tried shredding in reverse?
3. did you tried shredding few papers?
4. is the sensor still working?
5. did you empty the bin?
Pls check if there are some little metal stuffs from the inside that preventing the shredding, such as small wires, bunch of little papers that stucked within it. if the power is on, but the motor is not working, either forward or reverse, make a thorough cleaning and do it again from the basic.
hope it works! good luck!
Was this helpful?
Yes
No
Solution #5
Not Rated)
blueextc3221
Rank: Guru
Rating: 90%, 1440 votes
The safety power relay on the main circuitboard has failed.
Even though you hear the click of the switch - the relay is not engaging to allow the power to flow to the motor.
If you have the expertise, jumper the relay and verify the motor still works.
Unfortunately, the relay will be a bear to find, (if at all) and your best option is to purchase a new unit.
Thanks for using FixYa - a FixYa rating is appreciated!!
Was this helpful?
Yes
No
Solution #6
Not Rated)
Ronnieh49
Rank: Wiz
Rating: 82%, 1574 votes
i would say it time to get a new shredder rather than waste more time trying to fix one that may or may not continue to work. they arent very expensive and it will save you time and frustration in the long run. they cost less than 40.0 now at wal mart
Was this helpful?
Yes
No
Solution #7
Not Rated)
ginko
Rank: Guru
Rating: 89%, 5074 votes
Comments:
Feb 16, 2009
- try first unplugging power cable for five minutes.Shredders usually have a reset button inside.
Staples shredders are re-branded.
The best thing to do is contacting Staples. They offer complete technical support for their articles:Staples.com® | Contact Us.
Was this helpful?
Yes
No
Popular Solutions for Shredders
Questions and Unsolved Problems for Shredders
Answer
the as1500cd when you trun it on the red light blinks and nothing happens. is see nothing jaming it... (More)
Answer
i have a bad geer, i need a part
Answer
i have lost my pessure pad for my avery a4tr trimmer.- i had a problem with my trimmer and my... (More)
Answer
will not turn on in the auto position when paper put in--need new auto turn on switch. Where do I... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Shredders:
Top Shredder Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Shredder Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
