Question about Philips 50PFP5332D 50 in. Plasma Television
50 inch plasma blank screen
Philips 50 inch plasma green light comes on nothing on screen av does nothing switch on and leave of for different periods of tim before it comes on
I bought my Philips Magnavox 50" plasma in June of 2007. In february of 2009, I noticed increasingly longer delays in the video coming on after turning on the power and then the audio began to delay coming on. After a few weeks of this problem the audio and video then stopped coming on at all. However, there was power going to the unit because the green power light was working. I noticed over 50 other consumers on this website had the same problem. WITH THE HELP OF OTHERS ON THIS WEBSITE, I HAVE FIXED THE PROBLEM FOR $40. YES, FOR LESS THAN $100.00 I HAVE A WORKING HDTV AGAIN, BUT WITH NO THANKS TO PHILIPS - MAGNAVOX. THEY WERE USELESS.
HERE IS THE FIX:
1. Unplug your power supply cord.
2. Remove back panel on your HD.
3. Look for capacitors that have a bubbled or slightly raised and rounded top. This indicates the capacitors have overheated or leaked and need to be replaced. The normal look is a flat surface with no raised features at all. (I had two bad capacitors that were side-by-side and identical: 3300uf 10v. Also, they should be located on the power supply board. My power supply board is in the middle of my 50" plasma.)
4. Go to an electronics repair store or Radio Shack and see if they carry your capacitor type and size and replace them yourself if you are comfortable with removing the capacitors and soldering new ones to the power supply board. The capacitors will cost you $2.00 each or less.
5. I was not comfortable replacing the capacitors myself so I removed the power supply board by removing the screws and unplugging several wire connections. This was not difficult at all. I then brought the power supply board to a local electronics shop that did repairs on HDTVs and simply asked them to remove the bad capacitors and solder two new capacitors onto the power supply board. They did it for $40, which included cost for the 2 new capacitors, while I waited and it only took about 10 minutes.
6. I replaced the power supply board and back panel of TV and it worked!!!
Some people on this sight suggested replacing the capacitors with some that have higher temperature ratings. Based on that advice, I wanted to replace my two that were bad (3300uf 10v) with two rated at 4700uf 35v, but my electronics guy suggested against it. Instead, I replaced mine with 3300uf 50v, with the only difference from the original parts being the higher voltage (50v instead of 10v). I figure if the problem occurs again, I now know I can get it fixed for less than $50.00. Philips - Magnavox should be ashamed for such poor customer service and not telling people about this simple fix. When I called their customer service support number I was simply directed to a repair place --over two hours away!!!
Posted on Mar 05, 2009
50 inch Insignia Plasma TV that clicks intermittently as if the power switch is being hit, even while it's off. It also only comes on, on occasion. From what I can see, there's a two stage power sup
check both power units for dry joints and caps going faulty. as this is most likely a problem. its because Plasma screens get so hot they cause these problems.
Dec 29, 2013 | Insignia 50 in. Flat-Panel Plasma HDTV
2006 42" plasma has blank
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Apr 23, 2011 | Philips 42PF9630A 42 in. Plasma Television
Hello i bought a philips big screen tv from a second hand store anyway the screen has a green tint to it,i was wondering if it could be the picture tube? If so around what would the price of one be? The tv...
Never buy a used plasma,Period,,,,because these tv,s are made to work right for only so many hours and than start there troubles. Always look at any used tv back and get the manufacture date,this way you can see how old it is,,,,,,,,,Alot of flat screens called LCD dont last long eithermall I can say is check with consumer guide before you buy even a New one. Cany say whats wrong with your used one but now you know better on how to buy one.
Mar 13, 2011 | Philips 50PF9631D 50 in. HD-Ready Plasma...
My 50 inch phillips plasma made a loud pop and the picture and sound went away. if i plug it in it makes the normal click a few times and the green light comes on and then flashes red.
I have the same problem. after pulling the back off. we found that the 3 capaciters above the 2 power relay switches are bad. i am currently looking for a scematic so i can replace the 2 dios that burned up due to the issue along with the capasitors.
Dec 08, 2010 | Philips 50PFP5332D 50 in. Plasma...
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips Power supply flashes 5 times
one day not start his open. stan by red led and after switch on ,his green bligkig is not open.sound is ok.(the relay his not click)
Apr 12, 2010 | Philips 50PF7321D 50 in. Plasma HDTV
I have a Vizo 50 inch plasma tv...was watching the the other night and screen went out however the sound still works....I have not on screen menus at all. Called Sears and their repair guy charged us $100...
Thats crazy mine just went out today green light comes on screen is black nothing.Tryed to unplug it screen looks like it trying to come on makes a noise something funny on screen nothing. HELP
Dec 23, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
My Philips plasma only shows half the screen. The other half is just blacked out.
This model has PiP (Picture In Picture), find the button on the remote or check manual, this mode is most likely turned on and is being shared with one of the AV channels, or try turning on a plugged in SCART device to see if this picture shows on the other half of screen.
Sep 14, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Philips 50 Inch Plasma Model 50PF7320A/37 will not turn on
Commonly it's going to be a power supply related problem. The two boards that need to be looked at is the Main Power Supply Board or the power supply board for the screen. The one that powers the screen, some manufactures call it a Backlight Inverter Board.
If you have some electronic experience, you can sometimes find a Service Manual for the TV over the internet for less than $20. It will have the all resource material for repairing your TV model. It's just the matter of replacing the bad part on the circuit board.
Aug 12, 2009 | Philips 50PFP5332D 50 in. Plasma...
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Philips 50PFP5332D 50 in. Plasma Television Logo
373 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
