Question about York Yankees Bedding MLB Comforter
Replacement of control board
I need to know where the control board is located for my York P2MPD14W08001A furnace. Also any special instructions on how to change this part. The part# is Z6-P2MPD14W08001A-32YW.
Thanks
United products, rosedale, md. shut off power and write down all of the low voltage connections, double check everything before you restore power
Posted on Feb 21, 2009
Gas central heater
The "mother board" or integrated control module is essentially the brain that controls the sequence of operation in your gas fired furnace. It is located, generally, in the blower compartment. That is the bottom of the two compartments of the in the furnace. It looks like a circuit board with all the wires of the furnace leading to it.
Feb 28, 2014 | York Furnace Draft Inducer Blower Fasco #...
I have a York Stellar Plus furnace (1994 model) on which the ventor (air induction) motor will not turn off. This problem just started. The Furnace seems to work fine, but the ventor runs continuously. I'm...
The W on the board initiates the start up sequence so I believe your problem is with the relay on the control board. probably stuck closed you need to replace the board
Apr 12, 2011 | Heating & Cooling
York 90 furnace\r\n\r\nindicator light is blinking 7 times the code shows a lock out due to no ignition but the furnace is igniting do I need a new control board ? or is there a less expensive fix? oh I...
I believe you may have sanded the thermocouple, the sensor is usually a flame sensor and it will be round and look like a button. These will get dirty and not see the flame, you can try cleaning it with a soft cloth and glass cleaner once you locate it. This piece sends signal to the board letting it know there is flame. It should have wires that head to the board and plug in.
Dec 29, 2010 | Heating & Cooling
Draft inducer runs continuously, unless i turn the furnace off at the fused switch on the furnace. Turning the Honeywell thermostat to the off position does nothing to stop it, nor does removing the front...
Sounds like some one needs a new induce draft fan relay, if relay is located on the main control board you have to replace control board,follow wires from inducer motor and you will find the relay. I could help you more if i knew model # and serial # of the furnace, Good luck.
Feb 06, 2010 | York Furnace Draft Inducer Blower Fasco #...
York 92 % eff. furnace shuts down on # 3 error (pressure switch)
i have fixed almost every one of pc9 -----we have installed in our company,code three{flashes} at first new presure switches installed, same thing,york knows about this,induction motor bearings,could be bad.our local york dist, has boards,inducer, ***.motor, dual press.switch,free.as is known as the only way to fix.after all else is ruled out.one local competator called us if we wanted to join class action suit . good luck.furnaces work good at first, season or two then bam
Nov 28, 2009 | York Furnace Draft Inducer Blower Fasco #...
Need blower motor schematics and / or schematics for a york Controller #031-01267-001
you will need the model of the furnace not the part # of the board. is the schematic not in the unit?
Sep 25, 2009 | Honeywell Power Humidifier: Furnace...
York furnace coding 9. which is ground or polarity fault. what do i look for?
I put a new control board in my York today and it was a different/newer board. I immediately had the 9 code thrown at me for grounding and polarity issue. All I had to do was switch the 2 gray wires on the transformer. The gray wires go the the 12 pin connector. The new board is wired differently.
Aug 02, 2009 | York Tools & Hardware - Others
York diamond 80 hvac blower and comp wont start on automatic
Need blower motor for York Diamond 80 Furnace I am in St Louis MO where can i get one
Jun 20, 2009 | York Furnace Draft Inducer Blower Fasco #...
York Yankees Bedding MLB Comforter Logo
335 people viewed this question
Top York Sport & Outdoor - Others Experts
Paul Carew
Shehu Pro
Shehu Pro
ray gallant
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
