Question about MSI Computers & Internet
Mother board ms 7525 stops operating saying cpu fan p.supply stoped
  • 8 Answers
SOURCE: Mother Board Fan Making too Much Noise
There are 2 main reasons for the CPU fan to run noisily.One is that there is film of dust accumalated on the cooling fins thus not allowing air to circulate and cool the CPU properly.The second is that perhaps the fan needs to be oiled because the sleeve bearing has gone dry.The most common problem for a noisy CPU fan is accumalation of dust.You will have to remove the fan and clean it thoroughly with a soft brush.
Posted on Aug 21, 2008
  • 25 Answers
SOURCE: Power supply Ok.But CPU fans started with seconds It's stop.
sounds to me like your mainboard is bad, i bet if you closely inspect the capacitors around the cpu one or more is bulged out or leaking
Posted on Feb 15, 2009
  • 2692 Answers
SOURCE: switching out mother boards
KT4V link:  3GB Ram Max http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1∏_no=505
  MS 6712 is a design compliant number.KT3V, KT4v,KT4AV are all MS 6712 compliant:
http://global.msi.com.tw/index.php?func=searchresult&keywords=MS-6712
Posted on Mar 12, 2009
tunmun
  • 413 Answers
SOURCE: driver xp mother board ms-7525
kindly visit
http://mxdtr.com/MS-7525-MSI-Socket775-Motherboard-Driver-Drivers-Download.html
and download complete driver
thanks and regards
kindly rate this solution
Posted on May 12, 2009
SOURCE: Need XP drivers for the MS-7525 Compaq mother board
Almost any drivers will work off the site. MS motherboards are weird like that.
Try this one:
Motherboard driverd are available here:
http://mxdtr.com/index.php/category/msi-ms-7525-ms7525-motherboard-boston-gl6-xp-audio-sound-video-chipset-driver-drivers-download/
Posted on Jul 09, 2009
My msi ms - 7352 ver :1.0 won't display but wen i plug the power cable on the power supply the cpu fan and power supply fan spin but wen i turn the pc on it doesn't display
Auto power on the mother board means there was not found RAM or VGA adapter. If you herd Beep tones
follow this link to identify the error
https://forum-en.msi.com/faq/article/bios-beep-codes
if not pls check the power supply 4pin connector correctly plugged .
Also need to check the cpu and post error codes by post diagnostic card to identify the eror.
Oct 24, 2013 | Computers & Internet
MSI 845GVM-V (MS-7057-010) Motherboard cpu fan not ruuning but smps is ok when jpw1 is disconnected then fan is running but mother board is not on
Hello hare is the homepage:
http://www.msi.com/product/mb/845GVM-V.html#/?div=Manual
Try to download the manual, and check all your connections again.
Try also to renew the power supply.
Check also this site:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
The jpw1 is the main power connection for power to the cpu:
So you probably have a bad power supply.
Good luck
Jan 25, 2013 | Computers & Internet
Cpu fan not working
Get a new one. They fail occasionally. The system cannot operate without it.
Jan 08, 2012 | Compaq Computers & Internet
Gateway Desktop GM5626: Would not power-up, replaced Power Supply; Then Mother Board beep once when trying to turn-on; replaced Mother Board; Mother Board lights on, but when I try to turn on the CPU...
some powersuplay comes with 2 extra connectors a 4pin based switch connector and a alternate power supply for the fan...you must to be sure if it is comatible......check the model and search on google for compatibility ...
May 31, 2011 | Computers & Internet
I want MS 7525 Mother board cd because i farmat the computer the all files are lost
The MS-7525 is not a retail motherboard, it's an OEM motherboard that MSI custom built for HP/Compaq and called the Boston GL6 by HP.
Motherboard specs: http://h10025.www1.hp.com/ewfrf/wc/d...752001&lang=en
In order to see what drivers are available, you must visit the HP/Compaq website and type the pc model number into the box, then click NEXT.
http://h10025.www1.hp.com/ewfrf/wc/s...en&lc=en&cc=us
Note: MSI doesn't provide support for OEM boards, they leave support to the vendor. And unless HP shipped your pc with Windows XP installed, they won't offer any XP support. If you are trying to convert the machine from Vista to XP, why not just say that's what your trying to do?
Hope This Helps
May 12, 2011 | HP Compaq Motherboard
The purple light is flashing in the front and tries to start and won't turn on. disconnected power cord and held button in for thirty seconds still have same issue what could it be?
This can be a faulty power supply or a damaged mother board. here's how you can confirm.
When pressing the power button, inspect the cooling fan that is located on the back of the power unit where the power cord plugs in. if the fan starts then stops immediately, this will confirm a damaged power supply.
Now, if the fan continues to operate but, the CPU doesn't start to power up and load the OS, thsi will confirm a mother board issue. replace the mother board in this case.
Jun 21, 2009 | E-Machines T6216 (827103077834) PC Desktop
Driver xp mother board ms-7525
kindly visit
thanks and regards
May 12, 2009 | HP Compaq Motherboard
Feb 15, 2009 | Asrock P4S61 Motherboard
Try this one:
Feb 06, 2009 | HP Compaq Motherboard
New Computer Wont Boot!
when you say "the fan makes a noise like its getting ready to spin", which fan...power supply's or cpu? if you answer power supply, then the POWER OK signal is not returning to power supply and it then quickly shuts down to prevent further damage. double check a firm connection to mother board. If you answer CPU, then it becomes far more complicated. Try re-seating the memory chips.
Jun 05, 2007 | Systemax Venture PC Desktop
Computers & Internet Logo
78 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
