Question about LG HX966TZ 5.1ch 3D Bray Home Cinema System
Re setting booting for hours - LG HX966TZ 5.1ch 3D Bray Home Cinema System
Water leaking into boot
Look at the seal closely. If you see where it comes threw. I cut there with a razor blade and fill the inside with cotton. Then silicone the cut. Let it set an hour before closing the boot. If you have a brake light mounted in the boot. This is usually where a lot of water will come in. I silicone them in also. Spoiler on the boot, I remove them and silicone them down.
Jul 27, 2016 | Hyundai Excel Cars & Trucks
Recovery management never complete
A little late, but perhaps useful to others with similar problems. Did you have all peripherals disconnected (except mouse, keyboard and monitor)?
We had similar problems when trying to downgrade a Packard Bell PC from Windows 8 to Windows 7 (keeping a backup of all settings). We got stuck at 99% for hours, and we ended up downgrading including a reset of the settings (the other remaining option was completely reformatting the HDD). This recovery worked, but subsequently the PC would not fully boot Windows 7: it got stuck in an everlasting cycle of booting-rebooting.
It later turned out that a Netgear Wifi dongle had been connected throughout. When this was disconnected, Windows 7 booted normally... This may have been the reason for the recovery stall at 99% as well.
Mar 04, 2012 | Packard Bell Computers & Internet
My laptop has been preparing to configure windows screen its been doing this for over 2 hours not sure what is going on with it
Bobby,
Please press F8 at boot up and boot in Safe Mode. Once booted, right click on the desk top and select Properties->Settings. Here Reduce the resolution of the screen display one notch and let it reboot normally after that.
If the problem still persists then Press F8 at boot up again and boot up in Last Known Good Boot. option.
Dec 27, 2010 | Toshiba Satellite L455DS5976 Notebook
My emachine wont boot up its resets while trying to boot windows i tryed reinstalling windows with the back up disk but it keeps reseting..its a t5248 model with windows vista.. any ideas??
Go into bios and set it to boot first to the hdd - also set it to default in the bios - and - make sure the TIME is set correctly - sometimes the time get's out of wack and windows will not work right over two hours out of right times
Apr 01, 2010 | E-Machines eMachines Desktop PC
Acer laptop power button and fan problem
This is usually something to do with network booting, see if your PC is trying to boot from some sort of network device, or network address, real or imaginary, It may also be a virus, trying to connect, somewhere, at boot up, so run a rootkit check too. Check all network settings and privacy settings too.
Here is a program that runs at boot time and tells you what is going on and how to speed up your boot time, it may help. copy/paste below. http://www.soft32.com/Download/Free/BootVis/4-19687-1.html
Feb 26, 2010 | Acer Aspire 3680 Laptop
After installing Vista SP2. computer tries to reboot, but cant configure update 3of 3, so it reboots to start all over. tried setting CD as 1st boot, hangs waitng for CD-rom then boots off HDD. Tried...
ok go into your bios and load default settings.
set your cd-rm as your first boot device. then HDD.
save settings and exit. allow unit to reboot.
you can contact me direct e-mail. rain_catcher000_6@hotmail.com.
so i can give you one on one technical support.
Nov 14, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
Initial set up problem. Acer net book
this small laptop does not comes with cd rom,So you can arrange a USB Optical drive.In bios setup please check for boot sequence is to be set for usb boot device.Now insert the bootable cd or Operating system cd with boot files & it ill works
Mar 14, 2009 | Acer Aspire One Netbook 8.9" Notebook
Xbox
Basically it comes down to this. Error 16 has to do with not finding the menu setting with which you can set the clock of the hdd. This happens to a lot of people that erase their hdd (original/upgraded) or MS dashboard files and after that they don't immediatly install the hdd but leave the xbox without power longer than 5 hours.
It's all about the hdd can't find the menu with which it can set the clock. This is mostly because the xbox hdd is empty (you removed dashboard or fux0red it via ftp). The problem arises when xbox searches for menu to set clock with, can't find it and voila: error 16. Well read on please!
So you have an error 16 huh? Don't worry "nothing" is broken!
You have an xbox hdd that is locked. And normally you can boot in original and modded mode. Retail or upgraded doesn't matter. You start playing around with xboxdash.xbe etc. using ftp programs. While doing this you "accidently" remove your MS dashboard and also your alternate dashboard (Evox, etc.) so there is no dash anymore on the xbox hdd.
You end the ftp session and after that you shut off your xbox. Normally when you would start up again it gives you an error 13/14 ( no dashboard found). No worries with a slayer Evox cd (and a hardmod), all is ok. BUT this is only WITHIN 3 hours or so.
This is because the internal clock of the xbox will only be kept alive by the capacitors for only 3 or 4 hours. So when you leave your xbox unplugged from electricity for over 5 hours after you have played with the .xbe's AND you have removed your (ms and evo-x) dash from your xbox than you are fux0red. Why do you ask?
Why can't I boot from disc?
Its as follows Xbox starts booting==> (almost 1st thing a xbox does is) searches for internal clock==> doesnt find internal clock because there hasn't been any electricity on the xbox for 5 hours so battery that kept clock alive is empty and clock is gone==> searches for the proper dashboard menu to set clock with ==> doesnt find msdashboard or evo-x dashboard menu becuz you have removed it from the hdd for whatever reasons you had==> xbox gives error 16: cannot set clock.
So what do you do about it? Two options!
1. There are some bios'es around that allow the chip to boot past the clocksetting. (do a search!). So how do you get that bios on your chip because you cant boot to a flash program or something? Well you need to have an external flasher.
It seems the m8 bios will take care for you of booting past the clocksetting. Or use the latest Xecutor bios
2. This is the more easy and newbie friendly strategy
-Get a friend with a modded xbox.
-Unlock his hdd with eeprom management from a slayer evo-x cd.
-Than, place his hdd in your xbox.
-Boot with your chip on.
-Now the xbox DOES find a dashboard when you boot in original mode and you can set the time in the msdashboard clock settings.
-Shut off xbox and remove your friends hdd
-PLace his hdd back in his xbox and lock it again
-Install your hdd
-(clock has been set) So boot up with slayer cd.
-Install normally whatever you wanna install
-lock hdd
Oct 23, 2007 | Microsoft Xbox Console
Failure to boot after several hours of operation
assuming you set the date and time, the error message checksum can refer to incorrect memory timings along with the front side bus speeds, so check the processor bus speed eg 533MHZ or whatever and check the memory speed as if they are different you wont get it to boot, you will need to reset the bios if you cannot get it to run at all.
Sep 09, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
LG HX966TZ 5.1ch 3D Bray Home Cinema System Logo
32 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
