Question about Cobra 150 GTL DX Base CB Radio
WANT TO ADD TALKBACK IN A RADIO
I HAVE A UNIDEN PRO 510 CB RADIO IT HAS NO PA DOES ANYONE HAVE A CLUE OF HOW TO ADD TALK BACK IN THE RADIO
  • Anonymous Mar 13, 2014
    Question
    I have a CB radio Uniden Pro 520XL and inside is damaged coil with name LB1 112 Please help me find because in Poland ispossible
  • 585 Answers
A 200 ohm 1-watt resistor across pins 1 & 4 of the mic jack will make some talkback. More or less resistance will make less or more talkback. Note the association of less and more.
Posted on Jan 23, 2009
Install a utb-1 talkback board in a uniden pc 78 xl+
why,just jump the pa and ext speaker outputs and you have instant talkback.
Feb 25, 2015 | Uniden Radio Communications
Uniden 40-Channel CB Radio (PRO505XL) "PA" acts like an extra external speaker!
because when you switch to PA it is because you are on the outside of your vehicle.When another party calls you ,you can hear them and then go to your vehicle flip it to cb and talk to your party.
Jul 07, 2014 | Uniden Pro505xl 40 Channel Cb Radio
I Want To Add Talk Back Mod To CB Radio
there is what is known as the Quick and Dirty way, to add talkback to almost any CB radio. You will need a 130 Ohm 1/4 watt resistor. Open the radio and find the two mounting points for the external speaker jack and PA audio jack, you will want to solder the resistor across from the Positive connection of the PA jack to the Ground connection for the External speaker jack. This will give you talkback, and eliminate any feedback when the microphone is held at a normal operating distance away, Just remember, (This could potentially damage your radio if done improperly, I will not be held liable for anything that you do to your radio.) However, when done correctly this is a perfectly safe modification, and will allow you to monitor your output audio, as it is being transmitted. You can adjust the size of the resistor to your liking, however, I do not recommend anything lower than 100 Ohm, as there will be more potetial for squealing/feedback.
Feb 20, 2014 | Midland Radio Midland 9001Z Citizen Band...
My galaxy dx 88 hl works great but the talk back won't work on am but does work on pa what is wrong
if you hooked it up its wrong but I assume you didn't.First of all talkback is a feature that allows you to hear your voiceand you don't5 need a radio check because you can tell by your own voice how your radio sounds if you want it to work on am you need to attach a 33ohm resistor from the positive to the neg of the external and pa plug ins. the talkback will be on all the time by the way.
Sep 27, 2013 | Galaxy Radios DX- 88HL Base CB Radio
What do you clip to turn up the power on a uniden pro 510 xl new style
hi you cannot tweak anymore output power from these radios as ajusting any components will damage the rig ,they come factory set at 4watts tweaking it anymore will after prolonged use damage the finals /pa transistor so leave it well alone if its not broken dont fix it goodluck
Oct 27, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
I want talkback on my cobra 29ltd classic radio how do i do this myself
Open the case on your radio. Solder a 100 ohm resistor between the pa jack and ext speaker jack. You can add a switch if you like to turn it on and off. The lower the resistance, the louder the talkback.
Mar 30, 2009 | Cobra 29 LTD CB Radio
ADD TALKBACK TO A UNIDEN 510 WITHOUT A PA JACK
In theory you could locate the AUDIO pin from the back of the mic jack, and add a resistor from there to the center pin of the ext speaker jack in the same manner as you would a PA jack.  But look into more before you do as I have never done it that way and Unidens sometimes have a funky way of wiring their boards.  If I had one laying around I would try it out but I don't.  best of luck!
Jan 22, 2009 | Cobra 150 GTL DX Base CB Radio
Scematic
Hi there!!
If you have an echo board what kind is it? I can give you the connections and where they go it just depends on which echo board you have!! I can also tell you where that talkback goes!! Let me know
Dennis
Dec 10, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
257 Talkback
use a talk back ext. speaker.
Apr 12, 2008 | Magnum 257 CB Radio
Cobra 150 GTL DX Base CB Radio Logo
305 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
