Question about Dell Dimension 2400 PC Desktop
Hi ive just got a dell 2400 and it was working fine then i took it home in the car and turned it on and pluged it in to my moniter then the picture flickers when its loading windows and goes off saying no signal can anyone help thanks
    Scholar:
  • 88 Answers
I would unplug everything and then open the case. I would clean out the inside with some canned air. I would then remove the video card if it has one, some have on board video that is built into motherboard. Remove the video card, clean the fan if it has one and then install it making sure it's installed firmly into the slot on the motherboard. Then reassembly the case, attach all connections firmly. Power it up and hopefully it will work again.
I hope this helps,
Thanks for using FixYa
Eric
Posted on Jan 22, 2009
  • 115 Answers
First thing I'd check is the Monitor plug...remove it(with everything powered off) and check to see if you inadvertently bent one of the pins over. If you have, be real careful and gently bend it back up.
After unplugging the computer the moniter went blank
This is typical. When you unplug your computer there is no output being shown to the monitor. Reboot your computer and you should be able to see a picture.
Mar 06, 2011 | Dell Dimension 2400 PC Desktop
Dell e173fp monitorno power at all
If the pwoer indicator is blinking on the Dell monitor, you have shorted out transistors (C5706/5707) in the inverter circuits, also look out for bad capactiors.
Dec 17, 2009 | Dell E173FP 17" LCD Monitor
No audio from external speakers dell 2400 computer
hi,
1)Check audio Enabled in bios
2)Check whether audio drivers are installed in device manager if not install audio driver for DIMENSION 2400 from Support.dell.com
3)Check Audio port using Head phones to ensure is audio port is working fine.
4)If Dell speakers, check speakers Manuals from support.dell.com
Dec 04, 2009 | Dell Dimension 2400 PC Desktop
I have the NVIDIA 6200 in an IBM tower. Tower was
Compaq's are notoriously under powered. You should take a look at the power rating on your power supply, then cheque the necessary voltage for the card. Also make sure that the card doesn't have an extra power connection that you need to fill to make it work.
Jul 22, 2009 | PNY GeForce 6200 (VCG6200APB) (128 MB)...
No picture on tv screen when i turn on my 360 plz help
make sure the hd switch is not turned on on the video cable that connects to the xbox, it is a small black switch
Jun 28, 2009 | Microsoft Xbox 360 Console
New moniter too dim.
Good morning! Please review the operations manual of the unit, taking note of set-up settings value requirements. best regards.
Mar 20, 2009 | Samsung SyncMaster 920NW Monitor
Lines on the Screen, shut down and will not turn back on
Hi, the issue may with the LCD panel. I work in DELL and have been getting lot of issues like this. It's called vertical line defects.. You can connect and external monitor and press Fn and F8 to toggle the display over to the Monitor. If the display is fine, replace the LCD screen. If the system is under wrranty, call Dell tech support and get a replacement or else call 800-288-4410 (out of warranty repair) department to send your laptop for repair. If the display is the same on the monitor, then the video card/Motherboard has to be replaced.
If this information is succesfull, then please rate!!
Sep 17, 2008 | Dell Computers & Internet
Moniter turned sideways
right click on your desktop and go to your graphics settings, try to find the rotate option in there and change it to 0 or off
hope it helps
Aug 12, 2008 | Dell Dimension 2400 PC Desktop
Bass speaker stops working every now and then
Hi, Ive finally found the problem with my system :o) Its not the subwoofer its the DVD unit!!! think outside the box. Mine was randomly switching into headphone mode, so i pluged some headphones in took them out and walla its working fine. Not sure why this happaned perhaps some dirt or something else got inside there???? Let me know if this helps
Apr 07, 2007 | JVC TH-A85 System
Dell Dimension 2400 PC Desktop Logo
35 people viewed this question
Alun Cox
