Question about Holmes Products Cool Mist HM3500 Humidifier
My whole house unit mdl #3500 leaks watter at the seam on the left tank when the tanks are toward you. the warrenty says 5 years and mine is about four, it has been leaking for the past three years but now it is getting to bad to use, will it be replaced? Tony
    Novelist:
  • 88 Answers
Hey Tony, Thanks for the Question,
Does it specifically state that that replacement is 5 years or just parts? you have to read the fine print sorry to say, but if it is the whole unit then yes, they will replace the whole thing,
If its parts only then maybe they would send you out a new tank which more than likely would solve your problem too! hope that was helpful, let us know and please leave some feed back on how we did, thanks again,
mr.grzz
Posted on Jan 22, 2009
HAD UNIT FOR SEVERAL YEARS. IT STARTED TO OVERFLOW INSIDE AND FLOODS CARPET. TANKS DO NOT LEAK AND ARE INSTALLED PROPERLY
Larry, there is a float above tank,remove tank, adjust float lever , bend down arm gently, or loosen adjusting screw on arm adjust down and re tighten.
press the helpful button and follow me on fixya for more tips and info.
Feb 13, 2016 | Humidifiers
Is a kaz water tank leak under warranty?
I doubt if there is any warranty on this now. It has been over three years ago.
May 18, 2017 | Honeywell Humidifiers
Sunbeam humidifier 3502
Tanks are no longer available. Search for used units on your local craigslist.com. This model was previously made by Holmes and tanks were the same on HM3500, HM3501. Search "Holmes humidifier" then search "sunbeam humidifier" on your local craigslist.org
most bigger towns will have one or two show up. Keep an eye out. People who move to a house (or install) a whole house humidifier sell their old units. We have two of the exact model and I bought a new in box 3501 from a Craigslist posting in September 2013!
Mar 13, 2014 | Sunbeam Humidifiers
How do I clean / sanitize my sunbeam humidifier swm5250 with bleach?
I'm no expert, but a friend of mine loaned me her humidifier recently and she just put some bleach and water in the tank and cleaned the tank with that. It did leave a smell of bleach in the tank that could be smelled any time it ran, but after a few refillings, it went away, and I figure if it smells there must be a little left, which means it should clean the working parts fairly well too. (while you're running it the first few times) And the medicine tray in the SWM5250 is dishwasher safe, so I would just run that through the dishwasher, but bleach should be fine for that too.
Jan 27, 2011 | Sunbeam Humidifiers
Need to find a new water tank
Mine also cracked along the seam several years ago. I sealed the crack using two-part waterproof plastic epoxy (found at any hardware store.) Not really pretty to look at, but it hasn't leaked since!
Dec 01, 2008 | Holmes Products Cool Mist HM3500...
Water Tank leaks all over the floor
This happened to me the second night of use.  Water all over the carpet and a dripping vent. I called customer service and they told me to remove the tank and filter, and run unit dry for an hour or so. Then restart it.  Worked fine after that.  I think we may have bumped it which is said to be the cause of most leaks.  Bummer is that after 5 night of use the grip on water tank slipped and the tank is in pieces.
Nov 12, 2008 | Honeywell HCM-300T Humidifier
Left Tank won't empty
Eureka! Solved my "left bottle not emptying" problem. The problem was not with the bottle but that the top of unit which houses the on/off switch was not seated properly. It takes only a very slight difference in water level for the float to activate the switch, therefore if the top is raised even 1/4" the unit will shut off before the water level is low enough to allow the left bottle to drain.
Feb 26, 2007 | Emerson HDC12 Humidifier
Holmes Products Cool Mist HM3500 Humidifier Logo
85 people viewed this question
Top Holmes Products Humidifiers Experts
cwradio73
ray gallant
Ben Eng
Level 1 Expert
Are you a Holmes Products Humidifier Expert? Answer questions, earn points and help others
