TV won't change to dvd
I can't get to dvd on input 1 as connected at rear
I get sound from home theater,but no picture.
It seems that it is not going to input on tv.
worked ok last time used
Duh! I had the video input cable in wrong place after moving tv.
Thanks!
Posted on Jan 24, 2009
Need to hook up LG tv to phillips cd/4 head hi fi and RCA surround sound
Hello!
Ok: I will guide yourself through "hook up" process.
1. connect your TV set to your VCR, using 3 wires RCA cable(Yellow, red, white) to "Video1" input, yellow only! The other 2(sound channels) connect to "home theater/DVD unit. Use "aux" input.
2. Connect your DVD video output. yellow or 3 colored( green, blue, red) component cables to your TV's Video 2 or "component 1" input.
Now you'll be able to use your TV as a video monitor for your VCR and DVD.
The sound will be handled by DVD/Home theater. In case your TV is a very modern, all you can get out is: direct digital sound stream. Your home theater must be equipped with coaxial(orange) input(looks like RCA plug) or optical input. Or both. You must use proper cables to connect TV to Home theater.
sorry, but it requires some patience and thorough reading of user manuals.
Otherwise, it's "level 1" difficulty. nothing you may damage, due to installation.
Good luck,
Feel free to ask for more help, if needed.
thanks,
Alex.
Dec 14, 2011 | LG 42LC2D 42 in. LCD HDTV
Tip
Home Theater / Surround Sound Receiver simple Connection.
Are you tired of trying to remember what input on the Home Theater / Surround Sound Receiver goes with the Input on the TV? Wife fussing at you that the TV is too confusing? Here is a simple way to set up your connections.<br /><br /> <ol> <li>Connect each of your devices ( ie. Cable box, Game Sytem, VCR, ETC) to the inputs on your TV.</li> <li>Locate the AUDIO OUT on the back of the TV.</li> <li>Connect a cable from the AUDIO OUT on the TV to the TV/AUX INPUT on the back of the Home Theater.</li> <li>If the Home Theater has a DVD player built in then connect the Video out (either Component or HDMI or standard Video out) to the TV.</li> <li>When not watching a DVD (if equipped), keep the Home Theater tuned to AUX/TV for the source.</li></ol>The advantage of this set up is that whatever input you tune the TV to will then play through the Home Theater speakers without having to change the source on the Home Theater.<br /><br /><span style="font-weight: bold;"><span style="font-style: italic;">NOTE: Turn the volume all the way down on the TV to avoid distortion due to the slight delay between the TV and Home Theater Audio.<br /><br /></span></span> Hope this tip is helpful for many of you.<br />Robert<br />
on Feb 26, 2011 | Audio Players & Recorders
I cant get the tv to go through the surround sound i can only get the surround sound to play when its a dvd playing do i need another wire to go from the dvd player or will it not work no matter what plz...
If you've got the Audio Input Source set as TV-Audio and it won't play as Surround Sound then you'll need to connect the Audio Out from your TV (if it has one?) to the Audio AUX IN on your LH-T360SE and change the Audio Input Source to AUX.
Jun 04, 2011 | LG LH-T360SE Theater System
I have a panasonic viera flat panel plasma tv and a samsung 5.1 ch blue ray home theater system and the speakers work fine on the home theater system while playing a dvd, but does not work when watching...
1. The easiest solution would be to connect a stereo RCA (red and white) cable to the audio output on the back of your TV.
2. Then connect the other end to the input on your home theater system.
3. Change the home theater system to the correct input.
Feb 12, 2011 | Samsung HTC550 Theater System
No pic, no sound, but, has all three colors illuminated?
  • 1 Check the power. Don't be embarrassed if your problem is as simple as an unplugged power cord. It's better that you should discover this than pay a repair technician to come out to your house and find out.
  • 2 Isolate the problem. The main troubles that will crop up with a TV set are either no picture, no sound or both.
  • 3 Check the input setting on your remote control. If you have other devices connected to the TV, such as a video game system, those devices must be used with a different input setting than the input you use for watching programs or movies on a DVD or Blu-Ray player. Chances are, the kids were playing a game and forgot to turn the input back the way it was.
  • 4 Press the Input button on your remote control to return to the setting you wish to use. For example, the cable box might be connected to Input 1 and your DVD player might be connected to Input 2. Newer television sets have at least 3 inputs.
  • 5 Check the coaxial connection from your cable or satellite receiver to the television. The cable should be attached securely by twisting the round lock nut clockwise. Also check the power connections for the satellite or cable receiver. If either is unplugged, you won't receive a programming signal on the TV.
  • 6 Make sure the video cable is securely attached to the TV jack if you have a home theater system. The video cable runs from the Video Out jack on your home theater receiver to the Video In jack on the back of your TV.
  • 7 Check your receiver setting. Home theater receivers manage several components, so if you have the receiver set to operate the CD player but you are trying to watch a movie on your Blu-Ray player, you'll need to change the selection to Blu-Ray to watch the movie on your TV.
  • 8 Check the TV speakers to see whether they have been muted by accident. Press the volume button on your remote control or go to the Menu section and scroll down until you reach TV Speakers. Toggle left or right to turn the speakers on or off.
  • 9 Press the speaker button on your receiver to make sure your external home theater speakers are activated. Many home theater systems use external for their superior audio rather than the speakers inside a television
  • pls rte or vote on how helpful it works.
    Feb 05, 2011 | Philips 50P8341 50" Rear Projection...
    I just bought a Samsung HD LCD 32 in TV and want to play it through my Home Theatre System. I set the TV to external speakers, put the HTS in aux mode, but I don't get sound. My old Samsung SDTV would...
    If you do not have a manual for the machine down load one at http://www.samsung.com/us/support/downloads/LN32B460B2D
    It will show you how to set up a Home Theater Connection
    Connecting an Amplifier / DVD Home Theater
    TV Rear Panel
    1 Audio Cable (Not supplied)
    Amplifier/DVD Home Theater
    1 Connect Audio Cables between the
    AUDIO OUT [R-AUDIO-L] jacks on
    the TV and Audio Input jacks on the
    Amplifier / DVD Home Theater.
    When an audio amplifier is connected
    to the AUDIO OUT [R-AUDIO-L]
    jacks: Decrease the volume of the TV
    and adjust the volume level with the
    Amplifier's volume control.
    Each Amplifier/DVD Home Theater has
    a different back panel configuration.
    When connecting an Amplifier/DVD
    Home Theater, match the color of the
    connection terminal to the cable.
    Nov 29, 2010 | Samsung LN32B460 32 in. LCD HDTV
    Installed new 1080 plasma tv can't get sound from home theater system
    A home theater system usually consists of a dolby digital stereo amplifier and 5 to 7 speakers.
    Turn your stereo on and select the source that delivers video to the TV (DVD, VHS, Game, etc.). The video may be connected directly from the device to the TV, but the audio should connect to the stereo system (DVD, VHS, or other input). This way, the source audio is sent to the stereo and it provides the big sound to match the picture. Otherwise, you'd have to connect the source audio to the TV and let it's comparably tiny amplifier and speakers provide sound - that comes up short.
    When playing a DVD, select the DVD input on the TV *and* the DVD input on the stereo. If you do not connect the audio to the DVD input on the stereo system, you'll have to connect to the TV, otherwise nothing will be heard.
    Sep 17, 2009 | Audio Players & Recorders
    No picture from Home Theater/ DVD player... only sound
    Have you checked to see if your t.v remote has an input selection button ? If it does than just scroll through the inputs and see if this works.
    Jan 31, 2009 | Audio Players & Recorders
    No picture
    Change the input on the TV to the input that you have the S or Composite (yellow) plugged into from the RCA
    Channel 3 should be the cable or antenna input F connector.
    Charles
    Oct 30, 2008 | RCA RTDVD1 System
    Home theater system connections
    Hi
    I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
    Oct 15, 2007 | LG 42PC5D Television
    Televison & Video Logo
    20 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
