Question about HP Designjet Z6100 InkJet Printer
Hp designjet z6100ps error 71.04 - HP Designjet Z6100 InkJet Printer
SOURCE: HP designjet 1050 C plotter system error 04c3000 25c0000
when installing a network card i am getting this error cod 04c00 00002a0a
Posted on Sep 10, 2008
  • 99 Answers
SOURCE: hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Posted on Aug 01, 2009
  • 3 Answers
SOURCE: In designjet 800,what is System Error 20:10?
Here's a great page for that:
http://www.computercarefiles.com/TWI_Docs/bpp90134/default.html
Posted on Sep 30, 2009
SOURCE: HP Designjet 800 with a 'system error 81:01'
i have hp dnj Plotter 500 Printer Is Redy But Self Test & Computer Print Than Error 81:01 Papar Jam
Posted on Dec 05, 2009
SOURCE: HP 800 designjet plotter Error Message 21:10
need to replace service unit
Posted on Mar 22, 2010
HP DESIGNJET 1100/44 ERROR 02.1:10 NON PARLO INGLESE MI SCUSI.E GRAZIE DEL SUO TEMPO CHE PERDE PER ME CIAO DIEGO
"I DO NOT SPEAK ENGLISH I EXPECTED AND THANKS TO HIS TIME THAT LOSSES TO ME HELLO DIEGO"
google translated.
the only words that matter are printer error. Designjet
now i google this error and find one here.
https://www.lpscomputer.com/blogs/news/85334849-designjet-t1100-error-02-1-10
and theses
https://duckduckgo.com/?q=HP+DESIGNJET+1100%2F44+ERROR+02.1%3A10&ia=web
if you want to ask HP, (FIXYA is not HP.com) sorry but not.
https://h30434.www3.hp.com/t5/DesignJet-Large-Format-Printers-and-Digital-Press/bd-p/DesignJet-LargeFormat-DigitalPress
Jun 12, 2018 | HP Computers & Internet
Ps pc software
you will need to order the z6100ps hard drive and not the hpgl hard drive you may want to try re writing the eeprom using the diagnostics mode 9 from mainPCA to HDD although I'm fairly certain it will error out as its the wrong type of hard drive
Jan 06, 2014 | HP DesignJet Office Equipment & Supplies
I have a HP Z6100, and I got many times error 86:01 possible paperjam, after changing encoder strip and encoder sensor, carriage PCB. I still have 86:01 error, after Scan Axis in maintenance mode, the...
Observe when 86:10 error appearing? after intializing the carriage or immediately after powering on?
# If immediately error appearing do the below discussed activity
# after intializing if error appearing check trailing cable,service station wipers & cappings,cutter position, cutter movement & lubrication on rail.
Detatch power cable & data cable,remove right door, pull out carriage assembly from service station area (if its locked by service station manually unlock it). Remove cable connections, screws & take out service station from the printer.Place the service station out side(ensure that cables has to fix properly) connect the cables,switch on the machine, check for the error..
if error is not appearing: check the service station, found any damage replace it or shoot the problem.fix it back..
*even error is appearing: Remove carriage belt from the pully..check carriage movement, if found any hardness/obstruction? shoot the problem.
Finaly: check trailing cable( while carraige movement some tracks may lose their continuty)
Power supply.. ( check voltages)
Need your feedback for further help.. vinay229229@yahoo.co.in
Apr 11, 2012 | HP Designjet Z6100ps InkJet Printer
Colors and photos do not look right when printing on glossy paper using the HP Z6100PS large format printer. With photos on glossy paper, the ink seems to reflect off the paper, making the photos have a...
Hi
Did you try to calibrate on the same media what you want to print?
Try to delete any other calibrations stored. And re-calibrate the plotter on the same media or a plain paper.
DO RATE MY SOLUTION
Jul 07, 2011 | HP Designjet Z6100 InkJet Printer
A thin line is printed all the way across my poster through a photo and I can't figure out why it printed like that. I did a second printing thinking it was a fluke but did it in the exact same place. ...
Check under the printing head. There might be some dust accumulation stuck there and that cause that problem. I experienced the same problem ans that was the cause.
Jan 06, 2011 | HP Designjet Z6100ps InkJet Printer
Errore code 24:10 give us solution
This error may indicate a problem with your ink cartridges. Check this link for more info:
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=1326713
Hope this helps!
Mar 28, 2009 | HP Hewlett Packard Designjet Z6100ps...
HP Designjet Z6100 InkJet Printer Logo
122 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
