Question about Dwin TransVision 3 Plus Multimedia Projector
Degrading picture with my Dwin projector
When we first start the projector, the picture is fine. However, after a time (it was originally almost 2 hours, now the problem is starting after about an hour) the picture becomes unstable...light flashes, loss of color and clarity...starts small (very sparse, light flashes...almost not noticeable) but within about five minutes gets to the point where the flashes are constant. If we turn it off, then on again, the picture is fine for about 30 seconds before it starts acting up again. If the projector is left off overnight, then started, it's fine for an hour or so before it starts the problem again. We replaced the bulb about 700 hours ago. The projector is about two years old, and only started doing this in the past month.
  • 2,237 Answers
The colorwheel is going bad and needs replacing. the colorwheel needs to spin fast enough to sync up with the dmd chip. if it cannot, the pic goes bad then off. the flashing is the colorwheel trying to catch up.
Posted on Aug 19, 2009
Dwin TV4 Light will not com eon
I would have thought the red light means a defect. Check the manual for troubleshooting tips. and explanation of the red light functions.
Jan 28, 2014 | Dwin Office Equipment & Supplies
I have a transvision 3 that starts up and runs fine. at some undetermined point the picture will flash back and forth from snow to the clear picture????
prestopete here...no kidding..I have the same problem...Can't find any cables. I do have a source for bulbs if you need.
Mar 25, 2012 | Dwin TransVision 3 Plus Multimedia...
I have a Dwin TransVision 4 that is not working. It started out with us being able to watch a movie for about an hour and the bulb shutting down. I finally ordered a bulb from Dwin (at 458.00!!) and...
honestly it sounds as if a capasitor is overheating and once it overheats the machine is shutting off.... I myself would be able to look at it and see if this was correct or not. i am not sure how familliar you are with these types of things, probably best to take it in and tell them exactly what is wrong...
Feb 26, 2011 | Dwin TransVision 3 Plus Multimedia...
Dwin Trans 3 Shadowing at Edge
you'd need to remove the top from the projector. the light tunnel is between the colorwheel and the lens assembly. remove the metal frame from it. chances are it's falling apart. since the company's out of business, finding a part is an exercise in futility. time to trade up.
Jan 07, 2009 | Dwin TransVision 3 Plus Multimedia...
Dwin Trans3 Plus will not lite
I had a similar problem and it turned out to just need a good clean. The fans can pull in a lot of dust and eventually this causes intermittant starting problems/noise. I attacked mine with compressed air and a vacuum cleaner and this completely fixed the problem. Try to control where the dust goes you want to avoid just blasting it inside the unit and on the lense, bulb, etc
Dec 31, 2008 | Dwin TransVision 3 Plus Multimedia...
Picture becomes unstable after turning it on (lack of color,
The problem is with overheating!. after a few years the fans accumulate dust and "stuff" and don't work as well. Get a can of compressed air and blow out all the ports and fans. I take the cover off and with everything cool, I blow out all the internal fans also. The 3 big fans on the back are easy to remove and clean and get spinning again. Usually this fixes the issue for several months but eventually, professional cleaning may be needed at DWIN.
Dec 23, 2008 | Dwin TransVision 3 Plus Multimedia...
I HAVE DWIN TRANS3 PROJECTOR 3 YEARS OLD PROJECTOR STOPS WORKING IN 5 MINS, FIRST PICTURE GETS FUZZY AND NO PICTURE BUT SOUND STAYS ON, I ALREADY PUT NEW BULB BUT SAME THING
it's time to clean it out. the colorwheel might be going and if it doesn't spin to keep in sync with the dmd chip, the lamp goes out.
Nov 21, 2008 | Dwin TransVision 3 Plus Multimedia...
Dwin lamp turns off
I design and implement switching power supplies for the commercial lighting industry. I also own a DWiN Transvision and have opened it and worked on it several times. I believe I can answer this question.
The DWIN projectors use a proprietary switching power supply to strike the lamp and keep it burning. The power supply is extremely sophisticated and maintains tight voltage and current tolerances. This is important because the halides in the lamp are damaged by power supply fluctuations. The halides can often be seen in an unfired lamp, they appear as small specks of dirt or tiny beads inside the lamp envelope. When a metal halide lamp is struck, the halides (which are rare earth elements) vaporize and cling to the inner wall of the lamp envelope. The mixture of halide gas in the lamp is what determines the color temperature of the lamp, as well as the accuracy of the lamp across the entire color spectrum.
One of the ways that DWIN is able to deliver such great color is because they use a lamp which delivers this great color across the spectrum, but, as I pointed out earlier, can be damaged by fluctuations.
The power supply contains three switching sections and five references for such things as input and output voltage for each psu section, as well as overcurrent demands from the lamp.
From my experience, your lamp(s) are all exhibiting issues that require replacement.
Sep 25, 2007 | Dwin TransVision 3 Plus Multimedia...
Video then Black
the colorwheel is going bad and needs replacing.
Jul 27, 2007 | Dwin TransVision 3 Plus Multimedia...
Dwin TransVision 3 Plus Multimedia Projector Logo
297 people viewed this question
Top Dwin Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you a Dwin Office Equipment and Supply Expert? Answer questions, earn points and help others
