Question about ACDelco 2008 Saturn Vue GPS Navigation System
Map dvd read error - ACDelco 2008 Saturn Vue GPS Navigation System
I can't get into the map on my pioneer avic d3
The AVIC D3 is not pioneers best. The navigation side of the unit is wearing out. The slider slot in the dvd and other moving parts are wearing down fractionally and that is all it takes for the unit to no longer read the high density map data discs. The map disc is a dual layer 8.5gb disc and it is just about max out. (The disc must be in the unit for the navigation to work.) This is a lot of information and the unit must be able to read every bit of data on the disc or it will error out. All it takes is the fractional wear to mess up the tracking of the laser over the disc and cause problems reading the data on the disc. When the unit spins and spins, it is working hard to read something on the disc and will eventually error out if it can't. Also a fingerprint or tiny spot on the disc will prevent the unit from reading the disc. (Clean with a drop of water and soft cotton cloth even if it looks clean.) The data is information or instructions telling the unit what to do, and if it misses any information it will go crazy and error out. This is very different from music or video/movies that just play and if a spot is on the disc it will just be a fuzzy picture or static from that spot. If you have a disc your system likes, take care of it. I say likes because every disc has fractional differences in data location on the disc. (This is tolerance) That fractional difference could make or break the ability of your unit to read the map disc. So one possible fix is trying different disc to see if your unit will like one of them. Still eventually this also will die. These units are beyond their life cycle and the dvd drive is operating on borrowed time. I hope this helps.
Jun 22, 2014 | Pioneer AVIC-D3 Car DVD Player
Buick enclave navigation disc not working
maybe the dvd lens broke. to be sure try it with a new dvd disc.
Nov 27, 2013 | Buick Enclave Cars & Trucks
GPS indicating check map dsc error
This is a common navigation radio issue on this vehicle. The message "Map DVD read error" comes on randomly.... sometimes it works, sometimes it doesn't. Make sure your Map DVD is clean and without fingerprints or scratches first. If it the disc is okay, the issue, unfortunately, is within the radio itself. The only correction I've seen for this problem is to replace the radio itself. Also note, that if the radio is replaced, it will have to be reprogrammed by a GM dealer to correctly set up your vehicle's options and learn the vehicle's VIN so the radio will unlock.
Mar 19, 2013 | 2007 GMC Acadia SLE
Hi, I have a BMW 525D '06 My problem is that the navigator suddenly stop working - "Reading error. Please insert DVD" and I can not use the navigator. Often it occur after aprox one hour drive....
This SIB may apply to this issue:
SI B 65 24 07
Audio, Navigation, Monitors, Alarms, SRS August 2007
Technical Service
SUBJECT
CCC Navigation Map DVD not Detected
MODEL
E90, E91, E92, E93 (3 Series) with SA 609 (CCC Navigation)
E60, E61 (5 Series) with SA 609 (CCC Navigation)
E63, E64 (6 Series)
E70 (X5) with SA 609 (CCC Navigation)
Vehicles produced from 8/31/2006
SITUATION
When entering into the navigation system, the screen only displays "Please insert DVD", even though a DVD map is inserted in the drive.
CAUSE
Incorrect map DVD
CCC software or hardware error
PROCEDURE
On a customer complaint basis proceed as follows:
Always verify that the correct map DVD is used (identified by DVD-CCC). Try a known good map DVD and see if the problem is resolved.
Update the complete vehicle per SI B09 05 01 (Programming and Coding with Progman) Procedure B, using Progman 25.00.00 or higher.
If the fault is still present, replace the DVD drive. Refer to Repair Instructions RA 65 83 580
PARTS INFORMATION
Part Number
Description
Quantity
Refer to EPC
DVD drive
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Please refer to the latest KSD for all applicable labor operations and allowances.
If the appropriate labor operation is not contained in KSD, then a work time labor operation should be used.
Mar 07, 2011 | 2007 BMW M6 Convertible
We just purchased a 2004 Yukon denali and the DVD player quit working. It worked for a few hours and then stopped. It says "Disc format error". We bought a cleaner and thought that would help but...
Hi i have the same issue same 2004 model year. Its reads...
"Unable to read data, Check if map DVD is Correct"....what? I cant play a dvd but it plays all my cds so far. Can someone please help me with this problem!!! Any Solutions?
Oct 25, 2010 | 2007 GMC Yukon Denali
I have a HP DVD 1040 that won't read a map disc from National Geo
Try transfer from DVD to Flash disk, insert flash into the PC and run from that. should work. It is a work around.
Jan 26, 2010 | Philips Dvd Video Player
Magellan Maestro 4250 2008/2009 Map Update will not update my GPS
I also had problems with a refurbished Magellan 4250. The paperwork inside said to install the 4.85 firmware update which I found would not work with Windows XP Home at least for me. I used my laptop which has Vista Ult 32 bit it updated with no problem that is so far the only solution I used.
Apr 21, 2009 | Magellan Maestro 4250 GPS
Cant copy DVD software to SD
write me at vince954@yahoo.com if this does not work. On the dvd there is also a zipped version of the map_sd directory, copy it to your pc and unzip it and then copy the contents to your sd card. as the file is so large, some dvd drives have issues reading it.
Aug 16, 2008 | Fine Digital FineDrive 400 GPS Receiver
Error screen trouble shooting
If you have the USB cable and a dvd/cd that contains the software/maps, then it needs to be loaded. Install the software on your computer. With the unit off, plug it into USB, then turn on unit. run program installed from dvd/cd. you can also try resetting the unit by holding down the Menu and Nav key, hopefully a small box appears and you can use the stiff stick to change the numbers. if this does appear, change the numbers to read 32 then press the stiff stick in (pressing enter). _Daniel
Apr 13, 2007 | Magellan eXplorist 200 GPS Receiver
ACDelco 2008 Saturn Vue GPS Navigation System Logo
37 people viewed this question
Top ACDelco GPS Experts
Will Halftowaite
Are you an ACDelco GPS Expert? Answer questions, earn points and help others
