Question about Kenmore 64942 Electric Dryer
Should I replace t-stats and/or hi-limits and thermal cutouts?
I have a Kenmore model 110.96281100 front load electric dryer. I recently had to replace the heating element because it had burned out. It actually broke the element and was shorting to the cabinet on the L2 side, causing the element to be energized with 120V when the dryer was not running. I also had to replace the element about a year ago due to similiar circumstances. I checked the venting and discovered that I had a 22 foot horizontal run with 4 90 degree bends, equivalent to 42 feet total. I was also dismayed to find that the pipe was the aluminum foil flex that is supposed to only connect from the dryer to the wall. Someone taped together enough of them to get all the way out of the house. I replaced the entire run with 26 ga hard pipe, but could not reduce the number of 90s. This has made a great difference in the performance of the dryer. My question is this: should I think about replacing any of the t-stats or limit safety switches just to be on the safe side? When the element grounded out the last time, the path for the 120v that was energizing the element was not in the path of all the safeties, which would have cut the power. Could the prolonged heat have damaged any of these?
I have tried to explain this as well as I can. I am a HVAC guy and have good electrical skills, but I am not a dryer guy :) Any help would be appreciated.
Thanks, Rob
    Sergeant:
  • 311 Answers
I have fixed thousands of dryers over the years and the element shorting to ground is a rare ocurance.if you are loosing elements this fast it is due too your ducting as i think you know.and your replacement of the flex with hard ducting will surly aid in that cause.too answer your question,sure the thermo's will have been weakened but i have seen the same thermo's on 15,20 year old dryers ,so they can take some punishment.i owned an appliance repair buissness for ten years and after market wholesale thermo's were about 3$ each so if could find at that kind of price ,ok.other wise may be looking at 30 to 40$ and i dont see it making your dryer much safer then is with out new. God bless,hope that helps,tom
Posted on Jan 22, 2009
Drum will not spin
While most Samsung dryer component failures will generate a trouble message on the display, a failure of the hi-limit thermal protector won't. If the hi-limit thermal protector has opened, it directly interrupts power to the drum motor. As a result, you can start a cycle using the buttons, the 'brain' will turn on the relays controlling the motor ( the faint clicking sound ) and run the cycle timer, but the motor can't actually run. And without drum rotation being sensed, the burner won't turn on either.
Solution is to replace the hi-limit thermal cutout, which is located on the 'nose' of the blower assembly next to the dryer temperature control thermistor ( which is slightly larger than the hi-limit thermal cutout ).
Also note that the usual cause of a hi-limit thermal cutout failure ( or a thermistor failure ) is ducts restricted by lint ... both the burner exhaust duct as well as the blower intake duct. Both should be disassembled and thoroughly cleaned while you have the dryer apart.
Feb 12, 2012 | Samsung DV448AGE Gas Dryer
I have a kenmore gas dryer, the drum turns but no heat, I replaced the radiant sensor and the control thermostat but still no heat?
here is a partial list of componets that could cause the dryer to not heat
Ignitor
control t-stat
high limit t-stat
gas valve coils
thermal cutoff
thermal fuse
flame sensor
electronic control/or timer depending on your exact model
cycling t-stat
motor
Jul 23, 2011 | Dryers
Electric dryer spins no heat, replaced heater element and high limit thermostat, tested thermal fuse and it does have 0 ohms, thermistor reads ~50 ohms.
in addation to checking the high limit t-stat have you checked the thermal cut off (the small t-stat) on the heater housing where the element fits into, the high limit t-stat and the thermal cut off BOTH shoud have 0 ohms (the thermal fuse is in the blower housing) the cut off is on the heater box, if you have checked those to be good, check that the heat relay on the control board is closing and sending power to the element, if not replace the control, if all above are good then the motor switch is bad and not sending power to the element(thats a built in safety feature so the dry would never heat when the motor isnt running)the element of course heats only when 240 volts ac is to the element ,120vac from the relay on control through the high limit t-stat then through the thermal cut off finally to the element and 120vac from the motor switch for a comined 240 vac
Jul 20, 2011 | Kenmore Dryers
I have a Kenmore electric (front load) dryer, model number 84092500 that would spin but does not produce any heat. I tried cleaning/vacuumin the tubing that vents to the outside and resetting the circuit...
The first step of the fix has been done by cleaning the lint filter and the vent system.The next step is replacing the thermal cut-off and the high-limit thermostat both located on the blower housing. It is common that the dryer stops heating when the thermal cut-off blows open due to the failure of the high-limit thermostat to cycle off and regulate the heater temperature. The thermal cut-off cuts power to the heating element should the high-limit thermostat fails and the dryer temperature goes extremely high as a safety feature. Click on the links below for the troubleshooting and repair details.
Whirlpool and Whirlpool-made Electric Dryers (With Removable Back Panel) Not Heating
Whirlpool and Whirlpool-made Electric Dryers (Without Removable Back Panel) Not Heating
Jun 19, 2011 | Kenmore Dryers
Kenmore dryer Model 110.86982 Year 1989 does not heat
If you bypass the hi limit thermostat you will blow your thermal fuse within minutes. The hi limit thermostat is a bi-metal thermostat which warps when heated to kill power to the element. If its bypassed then the element will not turn off.....which will in turn blow your thermal fuse which is rated at a higher temp than the hi limit. So unfortunately it will not work.
Hope this helps _MJ_
Feb 07, 2010 | Kenmore Dryers
Wiring
You are missing over $150 in parts. You can buy a working unit out of the newspaper for that or less.
All of the wires on those models have letters and numbers on them near the connectors at each end.
Go to the Sears Parts Direct website with your Model Number and you may be able to print out a wiring diagram, because that is what you will need.
Jul 13, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer will not start. Can this be related to a
it sounds like the thermal fuse is out or possiblity of the high limit fuse is out to check those things you will have to take it apart and then get a volt meter and put it on where it beeps when the leads touch together make sure it is unplugged the check your thermostarts and the thermal fuse and the high limit stat they should beep if not they are bad
Jun 13, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
Thermal fuse location
the thermal is on the heater box on the right side it has two white wires going to it
you need to remove the high limit stat and bracket and the heating element to get to the safety stat
Jun 13, 2008 | Crosley CDE6000 Electric Dryer
Kenmore 64942 Electric Dryer Logo
91 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
