Question about Royal Sovereign Broil King Sovereign 90
Burned plastic smell in barbecue
Trying to burn off the smell of plastic on our new barbecue but the smell is still there
What to do when oven smells like burning plastic
new ovens do have a certian amount of "burn in" to do when there new best to heat up and cool off oven several times before actuall food use to remove any construction solvents and "cure" all the materials inside
also ck to make sure you removed all the shipping packing sometimes this gets left inside by accedent and smells something horrible when heated ( caution :: Foam degrades to cyanide deadly gas when heated!!!!)
Sep 08, 2014 | Microwave Ovens
Burning smell
If it smells like burning a burning plastic/ceramic then your brakes are locking up and burning. Next time it does it, see if the smell is coming from the rear tire. if so, its time for a brake job
Nov 11, 2013 | Acura Cars & Trucks
Burning plastic smell from under hood
You will need to check where the liquid is coming from, It may be anything from Air Con, Fuel, Transmission Fluid etc..
The fact you smell burning plastic could be 3 things..
1, Brake pads could smell and burn down if they are on too tight (Had this problem with a trailer). Hence when you apply the brakes it could be squirting brake fluid out due to too much pressure.
- Check brake fluid
2, If the smell and liquid is inside the car (front pass side) it could be the air ducts. Under the dashboard you have air ducts etc for the fans and in car cooling (brother had issue with this)
3, Whatever the fluid is, it could possibly drip onto something hot, unusual for liquid to smell like plastic though, Auto transmission oil smells like fish.
Best bet would be the brakes. Next time you smell it just smell in the wheel mag and see if you can smell it, check the engine fluids often and dont use A/C (Air Con) as that does drip fluid (normal). If it is the brakes smelling you will need to have the lines bled out, tyre places may be able to do this, and possibly new brake pads
Good luck
Oct 20, 2012 | 2007 Suzuki XL-7
Burning smell from sym orbit II Burning smell after 10 km * + Add a Comment 1. * By avatarChris mcwilliam 5 hours ago * plastic or rubber - something very mu
Hi, Chris the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
Good luck and have a wonderful day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 27, 2017 | Motorcycles
Brand new portable air con- burn smell
Two units, same plug, burning smell ... hire an electrician to check your wiring
Jul 19, 2010 | Sharp CV-P09FX Air Conditioner
Burned plastic part on refrigerator compressor
side by side refrigerator freezer, smelled melting plastic, found a plastic box connected to the compressor burned. What is this and how much does it cost to replace?
Dec 13, 2009 | KitchenAid Refrigerators
Burnt plastic smell that burns your nose
sounds like it could be electrical then... have you done any changes to the electrical at all? rewiring, changing headlights, etc? I had a similar smell when I changed my headlights... new headlights were defective and were melting the housing and harness...
Aug 11, 2009 | 1994 Chevrolet Camaro
Smells like burning plastic
Probably the odor from the new lamp. It should disappear shortly.
Jul 16, 2009 | Televison & Video
Burning plastic smell in ViewSonic E55 monitor
Unplug it NOW and take it back to the store ASAP.
Mar 02, 2008 | ViewSonic E55 15" CRT Monitor
Royal Sovereign Broil King Sovereign 90 Logo
309 people viewed this question
Top Royal Sovereign Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Royal Sovereign Grilling Expert? Answer questions, earn points and help others
