How to connect dvd player to AV reciever
Just got a yamaha RX-V650 AV Reciever & trying to connect an LG LH-T550 DVD/CD Reciever to it to play DVDS through YAMAHA surround.
Have connected VIDEO PLAYER WITH AUDIO OUT - OK
Have connected MINI DISC PLAYER WITH OPTICAL - OK
Will probably connect TV WITH OPTICAL - ?
LG DVD PLAYER ONLY SEEMS TO HAVE AUDIO IN INPUTS
CAN I USE S-VIDEO OUT TO GET SOUND ?
HELLLLLP PLEASE
  • rob2009 Jan 25, 2009
    Brought new dvd player a few days ago. Thanks
  • wangaimugo Feb 25, 2009
    cant get sound with s video and the red white cables dont plug to the camcorder
  • 33 Answers
S-Video is a media type that only carries video. Unfortunately the LG unit was designed only to be a self contained surround sound unit. There are only video outputs to the television on this unit. Because of the unit having surround sound capabilities, LG felt that their wasn't a need for audio output. You would need to buy a new DVD player to allow audio from the DVD to your new Yamaha unit. Good Luck!
Posted on Jan 25, 2009
I have a new Yamaha AV receiver rx-v381,trying to connect an old CD DVD player, Sony dvp-nc665p. I have audio, no video. No HDMI on CD DVD player. What am I doing wrong? Help!
On my Yamaha AV receiver, DVD video (usually a yellow connector) passes through to a video output which then connects to the video input of the TV.
Feb 11, 2017 | Sony Audio Players & Recorders
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
I plugged in my cable HDMI into my RX - V365 Yamaha reciever. and HDMI into my TV. I get video, but cannot get my attached (to reciever) speakers to play. Help
RX-V365 doesn't support HDMI audio. You need to connect the cable box also via spdif cable for audio to work. Look at the box if it uses optical spdif or coax spdif. If optical, you see that optical input on receiver is named DTV/CATV, so use also DTV HDMI for video. Coax spdif is named DVD, so in this case you will need to use DVD HDMI input.
Also you need to configure the inputs accordingly.
Nov 14, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
LG DvD Reciever (LH-T550) issue (Xbox 360/ TV sound)
I dont know about a universal remote my friend but a remote is defo needed to ajust and alter sound settings , I have the same system and it can not be done with the reciever alone. The AUX button on the remote has to be activated to get sound thru LG speakers providing your game console is connected to your TV, then a set of audio cables from your TV via the (OUT) ports (this is a must) back into you LG reciever. Goodluck
Feb 18, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Lg lh-t550 dvd player
i think i have solved the problem,i was advised to buy a lens cleaner and this seems to have solved the problem. thanks for your attension. David Bowyer.
Dec 27, 2008 | LG Televison & Video
Tv built-in dvd player wont play thru surround sound
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Dec 20, 2008 | Yamaha HTR-5930 Receiver
Lg lh t550. WHEN DVD IS PLAYING NO SOUND ONLY COMMENTARY
Basically films on DVD cary diferent audio formtas when playing. On the remote when playing a dvd thre shuold be an audio button which then scrolls through what language/commentary to use
Sep 23, 2008 | Televison & Video
Conecting my EQ to my Yamaha reciever
your media out(dvd-cd-dat-deck player)-to equalizer in-and equalizer out to aux or cd in receiver.
Jul 17, 2008 | Yamaha EQ-70 Home Equalizer
Home surround system
do a master reset of the system.
Oct 06, 2017 | LG LHY-518 System
313 people viewed this question
 Grubhead
Grubhead
