Question about RCA HD61LPW175 61" Rear Projection HDTV
Looking for a ballast for RCA HDLP TV
My name is Barbie W.
I am looking for a Ballast for my RCA HDLP TV model # HD50LPW175.
I replaced my lamp and still no picture. You can hear it come on but the lights still blink 3 to 5 times indicating a problem. I have talk to the people I got the lamp from and he said it's the ballast. However I have been looking for 3 weeks and can not find one for this tv. I was not aware that I would be able to find parts for it when I bought it. Could you please by the grace of God help me.
ctf1800
  • 4402 Answers
SOURCE: RCA HD50LPW175YX1 Panel lights blink 5 times, not power on
make sure the lamp is pluged in all the way
Posted on Dec 05, 2007
  • 3 Answers
SOURCE: tv screen won't go one, no sound, tv buttons blinks
You need to replace the lamp no ohther problem
Posted on Jul 06, 2009
techman
  • 3130 Answers
SOURCE: how can i check my lamp ballast in a rca scenium
are you sure when you replaced the lamp you seated it correctly, no really hapens all the time so dont feel bad. also another common error is the lanp door is not seated or closed and locked properly that is the most common problem that happens after a lamp is replaced, or the new lamp is bad never throw out your old one as somr dealers will give you what they call a core refund , they reuse the case around the old lamp. some can be worth as much as 50 to 60 bucks!!!
Larry Dillon
(AKA) (TECHMAN)
Posted on Sep 04, 2009
ladywinn
  • 5138 Answers
SOURCE: rca lamp replacement, still no picture, power light still blinks.
Ballast Board #261629 Ballast is what turns Lamp on, Also Check your Lamp Fan if it is defective Lamp will not Light!
Posted on Dec 30, 2009
SOURCE: replace lamp on 50' rca dlp and still no working.
i just replaced the lamp in rca m61wh185yx1, and the tv is doing the same thing----blink---blink----blink---flashes-steady
what-else could it be
Posted on Feb 21, 2010
Blue light flashes 5x times for about a minute,manual says bulb,replaced bulb,still doesnt work.
The "bulb" indication means that the lamp has not "fired". This can be due to a defective lamp or a defective ballast. Since you have replaced the lamp, I would next chack the ballast. A professional service shop should be able to help with this. It is extremely rare for a lamp to be delivered defective.
Hope this helps a bit.
Dan
Apr 25, 2011 | RCA HD50LPW175 50" HDTV
RCA HD50LPW175 50 in. HDTV Television Problem
If it's agreen wire with a stripe (usually yellow) it is likely a chassis ground (ie center plug of 3 prong electrical cord). The best source for schematics I've found (although they cost) is servivcemanuals.net.
Hope this helps.
Dec 02, 2009 | RCA HD50LPW175 50" HDTV
So...I'm told that I have a bad ballast in my 52" RCA projection TV. Can someone describe to me what the ballast looks like so I can I.D. it whan I open this TV up again for the 3rd time.
If your model is the D52W20 RCA you dont have a ballast you have a flyback transformer. Locayted on the far left side looking in the rear. Its a 259296 flyback and you can get one at www.tvrepairworld.com the flyback comes with the CD with detailed instructions
Nov 13, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have the same problem on my rca serial# hd50lpw166
It seems more to be an issue with your ballast, of course this is if you replaced the lamp before, but regarding the clicking sounds it's most probable to be your ballast. discountdashmerchantdotcom, the ballast aren't that expensive, they're around 60 dlls
Jul 23, 2009 | RCA HD50LPW175 50" HDTV
My RCA 50'' DLP Rear Projection TV will not turn on
Hi, This could be several things as the power goes everywhere. Long distance troubleshooting so hang in there. First try a cold reboot by unplugging and replugging after 30 minutes. If nothing check P1 on the light engine for the following voltages: pin 2 5vdc, pin 3 3.3vdc, pin 9 3.3vdc, pin 12 12vdc. If any of these are not good it is the formatter board. If all are good, does the color wheel spin at all. If this is OK then check J4 on the light engine, the ballast enable line should be 0 vdc in stby, .5 vdc at turn on, and 2.5 to 3.25 vdc in run. If good, is the light engine trying to fire the lamp? If not, inspect the J4 connector and the lamp power supply, If they look OK then the lamp ballast is probably bad. This will give you something to do for now, Good Luck!
Feb 15, 2009 | RCA HD50LPW175 50" HDTV
Tv wont come on
Good Day,
If you use your TV a lot then you need to replace the lamp, but if you only use your TV about 8 hour a day, then you also may need to replace the ballast.
The lamp is really easy to change. You should get at least 5,000 hours on your lamp.
Call RCA customer service and ask for a concession to replace the lamp and ballast. This is a common problem for RCA!
Good luck, God Bless.
Jun 11, 2008 | RCA Televison & Video
Hplpw175x7
I need to know which type lamp assembly you use there are two types type A and Type B. Let me know and I will post a link where you can get a new ballast circuit.
Jun 10, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Rca 50 dlp hd50lpw175
Yes but did you find a fuse open and changed it?
Jan 08, 2008 | Televison & Video
RCA HD61LPW175 61" Rear Projection HDTV Logo
283 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
