Question about Canon imageRUNNER 1023iF Black and White Copier
Canon 1205iF printing fax receipts ok
Want to turn off receipts
3 Suggested Answers
  • 385 Answers
SOURCE: It use to issue an ok receipt for sent faxes,but not any more.
press menu!Go to report settings press ok!It say tx result report,press ok the little star should be next to on(use the arrows left or right)press ok and stop!
Posted on Apr 01, 2010
canontech
  • 1219 Answers
SOURCE: We used to be able to get an automatic print
Under menu, under REPORT SETT. set activity report ON.
Posted on Jun 14, 2010
How will I know if my fax is received by the recipient? I did not receive any delivery report.
Go back to the SETUP menu and find the print receipt confirmation and select "print" or the positive equivalent offered on your machine . There is a function to view transmission results without printing, in the machine. this is a link to one of the manuals for this machine. It contains over 200 pages. I do not recommend printing but download and viewing on your screen. https://www.manualowl.com/m/Canon/MF4270/Manual/39328
Sep 15, 2015 | Canon imageCLASS MF-4270 Multi-Function...
Can you please tell me how to print Fax activity report each time? means whenever I send a fax I need confirmation receipt thats its gone through.Can't find anything in Manual.
ACTIVITY REPORT
The FAX is factoryset to automatically print an ACTIVITY REPORT after every 20
transactions. If you want to print an ACTIVITY REPORT before it is automatically
printed, follow this procedure:
Transactions in an ACTIVITY REPORT are listed chronologically.
1 Press Function.
2 Press Report.
3 Press OK.
• The FAX prints an ACTIVITY
REPORT.
• If you prefer the FAX not to print an ACTIVITY REPORT after every 20 transactions,
disable the ACTIVITY REPORT setting ( p. 145).
• Please note that only one transaction number (TX/RX NO.) is assigned when you send
a document to several fax numbers in one operation.
ACTIVITY REPORT
PRINTING REPORT
27/12 2002 15:00 FAX 123 4567 CANON 001
ACTIVITY REPORT
ST. TIME CONNECTION TEL CONNECTION ID RESULT
* 27/12 13:43 905 795 1111 Canon CANADA 5001 AUTO RX ECM 1 OK 00'33
* 27/12 13:45 905 795 1111 Canon CANADA 0001 POLLING RX ECM 0 OK 00'00
0 STOP
* 27/12 13:51 03 3758 2111 Canon TOKYO 0002 B'CAST ECM 3 OK 01'18
* 27/12 13:53 2 887 0166 Canon AUSTRALIA 0002 B'CAST ECM 3 OK 01'18
* 27/12 14:10 905 795 1111 Canon CANADA 5002 AUTO RX ECM 1 OK 00'18
* 27/12 14:16 2 887 0166 Canon AUSTRALIA 5003 AUTO RX ECM 4 OK 03'59
* 27/12 14:27 20 545 8545 Canon EUROPA 0003 DELAYED TX ECM 1 OK 01'20
27/12 14:30 20 545 8545 Canon EUROPA 0004 DEL SQ BDCST ECM 1 OK 00'36
27/12 14:31 03 3758 2111 Canon TOKYO 0004 DEL SQ BDCST ECM 1 OK 00'36
27/12 14:57 2 887 0166 Canon AUSTRALIA 0005 TRANSMIT ECM 3 OK 01'25
0 STOP
27/12 14:59 1 432 2060 CANON OPTICS 0006 TRANSMIT 0 OK 00'01
0 #018
go to this site to download manual (see page 11-3)
http://files.canon-europe.com/files/soft30110/manual/FAX_L220_L295_UG_ENG.pdf
Dec 16, 2010 | Canon L220 Plain Paper Laser Fax
Incoming faxes do not print, fax report reads 'power fail' and diplay reads 'low memory' - Can you help?
First, does the machine print normally from a computer or when making copies?
If so, then most probably you have enabled a private receive fax mode. In this mode, faxes are not printed immediately upon receipt (to prevent unauthorized people to read them), but are stored in memory, waiting for an authorized person to come and print them, providing a PIN (password).
To print the faxes stored in memory, do the following:
- press FaxMenu
- using arrow buttons select "receive"
- press OK
- using arrow buttons select "print faxes"
- press OK
- using the alphanumeric keypad enter the PIN/password and press OK
THe previously received faxes should print..
SOmeone must have turned this option on, so ask that person what he/she entered as the PIN.
Dec 04, 2009 | HP Laserjet CM 1312NFI Color Printer
Need printed confirmation fax receipts
I had the same problem with my 6210. A different machine, but this may be worth a try. You need to go to the general setup, rather than the fax menu on the keypad. Two pushes of the button takes you to "print reports". Press OK and you go to "Fax Report Setup", OK again gives you "Print Report". You then can toggle with the arrows for the various options. In this case press OK when you are on "sent faxes"
Apr 20, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Mar 17, 2008 | Canon L120 Fax Laser Printer
Repeated Fax TX report printing
Solution #3 solved it for me. The report kept printing over and over, so I used the menus (roughly) mentioned in Soluton #3 by guest.
My problem was the printer was trying to print the TX Error Report with the image attached. That made the report too big for standard sized paper, so the machine kept telling me to check the paper size, and I'd hit 'OK', and that made the machine try to print the report again, for it continued to think it had not printed a complete report.
Here's what I did...
Go to: Fax Menu
Arrow right ( >) to Maintenance/Settings, hit, 'OK'
Arrow right to (>) to Device Settings, hit 'OK',
Fax Settings, hit 'OK',
Arrow down ( v ) to TX Settings, hit 'OK',
Arrow down ( v ) to TX Report, OK
Select 'Print error only', hit 'OK',
Attach TX image, Select 'NO', hit 'OK"
With the instruction to not attach the TX image, it will print out the error report without the TX image, the report will fit on the paper, and it will clear this problem.
Jan 22, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Paper feeding when printing recieved faxes
If this is primarily happening with receipts from one sending fax machine, the most likely cause is that the sending machine is transmitting an end code that causes this page to print.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Oct 26, 2007 | Canon FAX-JX200
Not sure if faxes have been sent successfully how can i tell?
I am not technically qualified for faxes but most fax machines i have used have a setting that allows you to have a receipt that prints off after you have sent one, this is something that can be turned off if not wanted, look in the manual and it will tell you how to reset it, i think it was called "polling" after a fax has been sent it prints off this little bit that says what time it was sent how many copies and time received, fax number it was sent to and sometimes company name etc some machines i have seen and used have a poll button after you have sent your fax, try just pressing it, it may print out a conformation receipt of the last ten faxes sent hope i have helped, if so rate me please
Oct 04, 2007 | Canon FAX-JX200
Canon imageRUNNER 1023iF Black and White Copier Logo
24 people viewed this question
old marine
old marine
