Question about Sanyo DS35510 35" TV
DS35520 UNIT COLLAPSED VERTICALLY. OPEN SUPPLY RESISTOR AND SCAN DIODE LEAKY. PICTURE NOW OPEN BUT NO TUNER. TUNER B+ SUPPLY THERE. CAN INPUT VIDEO THROUGH JACKS AND GET AUDIO AND VIDEO THROUGH INPUT JACKS ONLY USING S-VIDEO JACK. IF JUST USING STANDARD VIDEO JUST A BLUE SCREEN WITH AUDIO. CAN AUTOPROGRAM TUNER AND SAYS NO SIGNAL. IF USING A/V JACKS, HAVE AUDIO ONLY WITH BLUE SCREEN. NO VIDEO OUT ON SET. SUSPECT COMB FILTER PROBLEM?? ANYONE KNOW IF COMB FILTER CIRCUIT IS ON A/V INPUT MODULE?? THANKS!
    Problem Solver:
  • 5 Answers
Maybe, try replacing the IC
Posted on Jul 05, 2007
SOURCE:
Cable input
Hi
I think the problem is in the tuner, a small metal box near the antenna input and can be removed and serviced. But first you should check the DC supply line to the tuner. The circuit has a big limiting resistor (15K/3W) and a 33V zener diode and a small filter electrolitic capacitor). The zener is prone to be leaky and unstable.
Sully
Sep 27, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Horizontal line
Basing on your post : Horizontal line ,
check vertical deflection circuits
( includes IC, capacitors , resistors % foil paths ) , up to the yoke.
Could be just a cold solder joints on Vertical IC, open resistor,
leaky capacitor or both
Have voltage :
On most the supply line of vertical IC is +24V
Aug 14, 2012 | Televison & Video
What can u do when the picture is vertically too big the heads don't fit the screen?
You have a vertical problem. You have bad capacitors next to the vertical IC. There may be leaky diode, a bad resistor and the Vertical IC may need resoldered or replaced. This is a good start for repairing your TV. Thanks for asking and show a few hands of support.
Jan 11, 2011 | Televison & Video
Panasonic M#35G25B picture goes to single horizontal line but sound still good. We can bump side of tv and restore picture. Problem is becoming more frequent. What would cause this and is it something we...
Assuming this is a TV with a picture tube, it is most likely a vertical deflection/drive fault, caused by a number of components including (but not limited to) the vertical IC. Dry solder joints and/or hairline fractures within the copper tracks on the board can cause the vertical collapse as well as leaky diodes and faulty resistors. (dry joints are usually the most common causes of circuit failure - before component failures) Non-electrolytic capacitors which are also in the vertical stage can affect the output when they fracture.
** It would be a good idea to check the board thoroughly for dry solder joints before considering replacement of any parts on it. **
Unless you are tech. savvy, and have some experience with electronic circuits, particularly TVs, this is not something you should try to repair yourself. Send it to an authorised repair centre for a quote and second opinion, then make a decision afterwards - up to you.
Sep 19, 2010 | Panasonic CT-35G25 TV
My TV picture has collapsed to a single horizontal line
If it is an standar analog tv, I'm sorry to tell you but, is time to get a new one.
Dec 05, 2009 | Panasonic Televison & Video
MY LCD HDTV 15 INCH TV HAS A PROBLEM I DO NOT HAVE PICTURE ONLY VOICE IT WAS PURCHASE ON 10/27/08 WHAT CAN I DO TRIED EVERYTHING
1.In this case the problem is usually found in the high voltage power supply.Most probably is the vertical IC defect.
Warning : This procedure has to be done by an expert.It is risky and can cause death to those who dont have knowledge in repairing.
A.) Open the unit and try adjusting the screen variable found in the flyback transformer. Notice any pattern on the screen of your tv.If their is a horizontal white line on the screen the defect is the vertical IC,replacing it can remedy the problem. Also check the 24v supply of the vertical IC coming from the flyback transformer.If their is no 24v get the resistance of the fuseable resistor and rectifier diode.Usually the resistor opens and the diode create short circuit.
B.)For most, make sure that their is no loss contact or cold solder on the board.
Jul 09, 2009 | Televison & Video
Philips TV (old) showing a horizontal line in center of screen
Check for the cracked solder joints on the IC or dried capacitors on the vertical side
Mar 28, 2009 | Televison & Video
Sony KP-65WV700 DVI-HDTV Issue
Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
From here:
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Nov 12, 2008 | Sony KP-57WV600 57" Rear Projection...
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
Dec 26, 2007 | Zenith Z32X31D 32" TV
Vertical collapse
I think L301 is an inductor coil supplying B+ voltage to the vertical output IC, also a diode and resistor are associated with this circuit. Most likely the vertical IC has shorted causing L301 to open up. The diode could also be shorted. Stargazer
Aug 25, 2007 | Samsung TXG2746 27" TV
Open Questions:
See all Sanyo DS35510 35" TV Questions
Sanyo DS35510 35" TV Logo
199 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
