Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub zero frig
Turned refrigerator off to clean and when I turned it back on the freezer stopped freezing and making ice
  • 175 Answers
First check the condenser up top behind the grille and on the right side. If it is clogged with dirt, shut it down and use a vacuum to remove the dust. If tis clean then look at the display. Does it read "service" or "vacuum condenser" Also, whhat temp does the freezer read on the display? Lastly is it saying anything like "EC40"? These may be clues as to the problem. Let me know about this and I can give you more help if necessary. Good luck!
Posted on Jul 18, 2007
SOURCE:
Sub zero 501 freezer and refrigerator ice builds up on back panel
Possibly the timer that controls the defrost cycle is defective.
Do you get any defrost melt water in the pan below the frig?
Sep 01, 2012 | Sub-Zero Refrigerators
Sub-zero is not freezing
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 11, 2010 | Sub-Zero Bottom Freezer Refrigerator
Icemaker for sub zero 632 is not working, tray will not fill with water,there is no water in tray, It worked fine before hurrican, we emptied the frig and freezer and shut off the breaker for the hurr
check the water pressure ... if you have a filter in the line it may be restricting the pressure ... I had the same problem and a new filter fixed it
Nov 06, 2008 | Sub-Zero 632 / S
Sub zero 632 s frig freezing everything
First, is the temp really 40??  Get your outside thermometer and stick it in there.  You may get a surprise.  If so, see if the thermostat will respond to any changes.  It is possible that either the sensor or the electronics have gone bad...I'd vote for the sensor.
the other possibility might be low gas...but I'll want to see what the temp in the unit is and whether the changes you make do anything.
Oct 24, 2008 | Sub-Zero 632 / S
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Jan 28, 2008 | Frigidaire GLRS264ZA Side by Side...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
139 people viewed this question
Top Sub-Zero Refrigerators Experts
Steve Allison
Steve Allison
louis_benton
Level 1 Expert
john h
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
