Question about Samsung HLP5685W 56" Rear Projection HDTV-Ready Television
Samsung DLP HLS5086W - spider crack
There is a spider crack on outer screen of this dlp tv, but there is nothing wrong with the picture. i've been told that there are two screens that make up a dlp. What do i have to replace to fix this problem and can i do it myself? thanks for your help!
    President:
  • 3,130 Answers
You will need to get the screen from here:http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP67%2D00261A&search%5Fmodel=HLS5086W You should also get the service manual for this TV set, as that will show you how to disassemble the TV set. Good Luck
Posted on Jul 05, 2007
2 Suggested Answers
  • 150 Answers
SOURCE: Samsung HLS5086W - spider crack on outer screen
The outer screen is called a Lenticular screen, it may come as a set with the Fresnel (the inner, and the way I would actually go) the screen is very hard to replace usually on a DLP as they have a somewhat sealed upper side and alot of screws.
Posted on Jul 06, 2007
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
White spots on samsung DLP tv
DLP/mirror chip is going bad. A common problem on Sammy TVs after 2-3 years. Chip is user replaceable (try samsungparts.com or ebay) for about $150-200. Sammy was (last year) repairing the DLP White Spot problem for free. You MUST talk to ECR (executive customer service) to even think about getting that consideration--forget the standard CS people. Don't know if they are still covering this out of warranty in 2010.
Apr 27, 2010 | Samsung HL-R4264W 42" DLP HDTV
Signs that the bulb in a dlp is going out
A DLP Lamp will fail in two ways. 1.The glass tube housing the filament will shatter and the TV will not turn on. 2. The lamp has many hours of use on it and will gradually grow dimmer. At no time will the lamp cause any picture defect. Check your Cable or Sat box for the correct aspect ratio as well as the TV aspect ratio. Chances are the aspect ratio in either system is set incorrectly. If the gray borders are uniform then the aspect ratio is not set properly. If this occurs on certain channels but not others then the particular channel is broadcasting in the 4:3 aspect ratio and there is nothing wrong with your set.
Apr 12, 2010 | Samsung HL-67A510 67" DLP HDTV
My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Plasma work fine but outer screen cracked.
it's hard not seeing the 'crack' but basically a real crack will allow the (plasma) gas to escape. if that happens just forget it and buy a new one if out of warranty.
if it really seems as tho there is a crack in the glass, I would just enjoy it while you can, and try not to ever move the TV as it may totally go at that point.
if under warranty get a tech out to the house before it expires. make them come out in this case rather than bring it in for the aforementioned reason.
Feb 11, 2009 | Samsung DLP HL-P5663W 56" TV
When i start my samsung hls5086w dlp tv it makes a buzz when it starts up
Probably your color wheel or a bad fan, either problem will need expert help
www.classtorations.com
Jun 08, 2008 | Samsung Televison & Video
My Samsung 50" HLS5086W wide screen tv keeps shutting off....
I am not in my shop, so, I cannot look at the schematic. The only problem I have seen with two lights blinking with this set is an intermitent thermal fuse above the lamp. Sometimes the lamp door switch is in the up position and it needs to be down (This normally occurs when the lamp door has been opened and it also comes from the factory in the wrong position. The set has a one year warranty. Contact: 1-800-SAMSUNG for a local servicer.
Aug 25, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Jul 05, 2007 | Samsung HLP5685W 56" Rear Projection...
Open Questions:
Samsung HLP5685W 56" Rear Projection HDTV-Ready Television Logo
230 people viewed this question
Jerry Greenberg
Jerry Greenberg
