Question about Maytag Dryers
How to change the belt on a kde 50 maytag dryer
Kde 50 electric apartment dryer
Nitrotrike
  • 589 Answers
SOURCE: Open Dryer to replace belt
Here's a pretty good tutorial on disassembly. Just scroll down to the Maytag section:
http://fixitnow.com/2003/11/appliance-tip-of-day-dryer-disassembly.htm
Posted on Jan 11, 2008
captaynkyrk
  • 170 Answers
SOURCE: dryer belt replacement
remove the front panel. you may need to remove a kick panel below the front panel. the top panel connects to the front panel by some plastic push in retainers (you can loosen them with a screwdriver) You need to prop the top panel up. the belt goes over the top of the drum down to a drive wheel that is located at the bottom of the dryer.
Posted on Jul 07, 2008
  • 4 Answers
SOURCE: replacing maytag dryer belt
looking at the back of the motor where the belt pulley is you would grasp belt coming down from the left side of drum then come across the top of belt pulley that is on motor shaft going clockwise around that pulley then continue back to your left and over the top of belt tension pulley going counterclockwise around that pulley this is when you will have to raise pulley against spring pressure to get belt on then release belt tension pulley make sure that belt is still in belt groove on the drum hope this helps ed
Posted on Nov 01, 2008
TheMobilian
  • 8220 Answers
SOURCE: Need to change the belt on my Maytag Performa Dryer
The belt is a 341241, a pretty standard belt. To install it you must get the front panel off. Do this by using a putty knife: 549402b.jpgUse this hady DRYER BELT ROUTING guide
Posted on Mar 27, 2009
  • 10865 Answers
SOURCE: replace dryer belt
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Posted on Apr 07, 2009
I took the dryer apart and lubercated the belt and now I cant put the belt back on. How do I do this?
Hi buttcrackplu...
The belt will go around the drum,around the motor and idler pulleys....
Go to this webpage to see how the belt is routed.
Free Answer.,..Please rate me
http://www.applianceaid.com/images/belt-config.JPG
Apr 18, 2011 | Maytag Neptune MDE4000 Electric Dryer
WORN BELT ON MAYTAG ELECTRIC DRYER
Remove the two brackets on the back holding the top on. Then pry the front part of the top off with a flat screwdriver. Next remove the electrical connectors. The remove the front panel. Then pull the drum out. Install the belt and push the drum in place placing the belt correctly into the tensioner for the belt
May 10, 2010 | Maytag PYE2300AY Electric Dryer
Change belt
Here is how to open the dryer to change the belt on the link below.
http://www.ehow.com/how_4841992_change-maytag-dryer-belt.html
Apr 27, 2010 | Maytag Neptune MDE5500AY Electric Dryer
What part number is the drum belt for a maytag electric dryer model # DE 50 Serio no. 997874 KF?
part number and demensions Dryer drum belt - Length is 87-3/4" Width is 1/4".
Part Number: AP3865318 made by FRIGIDAIRE does not come up as maytag.
Oct 09, 2009 | Dryers
Maytag Neptune Dryer smells like burning rubber or plastic...
The drum belt could be rubbing on something inside. Does the dryer make a squeeking noise? Se if there are small rubber particles on the bottom, this will indicate a deteriating belt.
May 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer wont spin
It is fairly simple,but I have changed a few.you may want to pay someone for first change and watch how he pulls everything apart.to replace a belt is not expensive.I charge anywhere from $98 to $115.00.everyone has diferent prices
Mar 10, 2009 | Maytag PYE2300AY Electric Dryer
Needing 15-20 year old apartment sized dryer belt.
go to a Maytag service agent
even the unit is old , there is a good possibility that the belt is still in use or was discontinue recently and they may have spares
Aug 19, 2017 | Zanussi TC180W Electric Portable Dryer
MAYTAG DRYER LDE4914ACE BELT CHANGE
The belt goes around the pully so that the pully tension takes the slack out of the belt. Just like the serpentine belt on your car.
Nov 15, 2007 | Maytag PYE2300AY Electric Dryer
Dryers Logo
52 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
