Question about Gateway SX2110G-UW318 Small Form Factor Desktop PC with AMD E1-1200
Problems with the gateway sx2110g-uw318 - It will shut down and won't turn on again unless you first unplug it and then plug it in again. Help!
It has the Windows 8 OS. Purchased it at Walmart in December.
  • 114 Answers
SOURCE: When I turn on my Gateway 838gm desktop PC it
try changing the ram, as a failing ram can lead to that. if that doesnt work, try checking the pc fan
Posted on Jan 23, 2010
  • 644 Answers
SOURCE: Problems loading OS in Gateway desktop
Normally installing the os on a different mechine, and then putting into another pc dosent work.
If the hardrive is the oringinal drive, which came with the system, and you want to install xp on, you will have to use a dos disk with fdisk on it, delete all partitions on the drive and create a new partition, then start loading windows, it will give you the option to format the drive for nt(ntfs) file system and setup windows.
If you do that and it still gives you protecting files error, you will have to take the side panel of the computer tower, unplug from the mains and take the cmos battery out for about 30 secs, put the battery back in, plug in the mains and reboot the computer, start loading windows again
Hope this helps and post back if you need further assistance.
Posted on Feb 19, 2010
Testimonial: "That explains a ton, didnt know I need extra software for Gateway. Only one question. Dan o you know wher I can get the software. TY"
SOURCE: My Gateway 700X PC (Windows XP) will not Shutdown/Will not Start.
I had a Systemax Pc that did that and it turned out it was a faulty power supply
Posted on Mar 07, 2010
SOURCE: My gateway dx4300-03 starts up
By Cyclontech!
Hi, The solution to fix the problem is by changing your power supply. Just make sure that you replace it with a 500W or higher and not with the same 300W which does not have enough power for this system, plus it is defective. I have changed the power supply to 4 diferent gateway PCs same model dx4300. And all 4 are working perfect. And run a check disk on CMD to fix the disk errors that were created every time you unplugged it and turned it on again.
Posted on Nov 23, 2010
Testimonial: "Thanks I will try it"
  • 22 Answers
SOURCE: My gateway profile 5 won't turn on. Checked plugs
Try to power drain it. Unplug all the power related devices that are connected, like a monitor data cable or external printer, just unplug all the cables in the back after you shut down your computer, press the power switch of your computer and keep it pressed for about 45 secs, release it, plug everything back and check it if its working. As well double check if that particular socket is usable, plug something else in to see if its working.
Posted on Jun 30, 2011
My PC starts-up said my name welcome and stays on that scree with the spin next to welcome and that's it.
Sometimes updates running in the background act that way. You can wait it out (could be 1/2 hour or more depending on how many updates) or you can try holding "ctrl", "alt" and tap "del" key and see if "task manager" opens up. If it does, it should show what processes and applications are running. That may give you a clue. Finally, you could just hold the power button down a few seconds until it shuts down. Upon restart, you may have to select an option such as "start normally". If you continue to have problems after the restart you may need to go into "system restore" mode (type "system restore" (w/out quotes) in search box of Start menu, follow the prompts and choose the restore point just before the last system change.
Oct 18, 2016 | Gateway SX2110G-UW318 Small Form Factor...
How can I start in safe mode
Press the power button and press the F8 key on your keyboard and your done..
May 29, 2014 | Gateway Computers & Internet
Where is my graphic card located
This computer does not ship with a graphics card. It contains a GPU, as all standard PC's do.
Feb 21, 2014 | Gateway SX2110G-UW318 Small Form Factor...
Gateway sx series sx2110g-uw318 boot menu with AMD E1-1200
It's either F1 or F2. However, once I had a Gateway which needed "Delete". You can try to put one finger on each button and press them successively. If everything goes right, you will enter BIOS and then you will have to enable lagacy usb support, change boot order so that you can boot from USB or CD (it depends...). Hope this helps!
Jan 26, 2014 | Gateway SX2110G-UW318 Small Form Factor...
This is an snippet from the Gateway Website.
"In order to access the boot options on this portable computer, press the ESC or F10 key while the Gateway screen is displayed during the startup process. This opens a Boot menu with the option to start the computer to any of the available drives or to enter the BIOS Setup Utility. Use the UP ARROW and DOWN ARROW keys to select a menu option, and then press the ENTER key to start to the selected device.To "boot" (start) to a CD, DVD, or a floppy disk, the media must be in the drive when starting the computer."
How to optimize Gateway SX2110G
There are a lot of ways on how you can optimize a computer. You can upgrade the hardware part of your computer which can boost up its performance or you can maintain the current the optimum capability of your computer by making sure that you have an anti-virus running on it and you have all drivers updated. I suggest you install RadarSync to automate driver updates. It's very important if you want it to run in its optimum level of performance.
David
Feb 19, 2013 | Gateway SX2110G-UW318 Small Form Factor...
How do I turn off secure boot or access BIOS settings (UEFI)
This specific PC requires you to immediately press the "Delete" key at one-second intervals in order to access the BIOS.
Not the F1 or F2 key
Feb 10, 2013 | Gateway SX2110G-UW318 Small Form Factor...
Gateway SX2110G-UW318 Small Form Factor Desktop PC with AMD E1-1200 Logo
214 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
