Question about Ovens
We have an aeg competence oven and we cant get it on cos the digital screen is flashing P00;00 and we cant get it of to set the time so the oven will work can you help
The problem may be with the clock chip, and not having a functioning clock means that the relay which connects mains power to the lower oven is not tripped. the clock unit costs $200 here in Yurp. since I don't use all the timers and delays that's a lot of money for a clock. so a friend and I took the clock unit out and shorted the relay so that mains power is always provided to the lower oven, and ginger bread is being baked as I type. and just to make it a traditional repair I put a piece of duck tape over the flashing P0.00, that was a bit irritating.
Posted on Dec 23, 2009
  • Ovens Master
  • 3,463 Answers
Switch oven off completely, yhen switch back on again, and try to set a time on timer,this should solve the prob, it will not work whilst it is flashing.
Plz rate my comment.
Thanks.
Posted on Jan 23, 2009
The display erratically flashes 12:00 and cannot be set. I have the manual. Everything else seems fine. Timer just resets back to blinking 12:00.
Call an AEG repairman .would be my choice of repair.but FIXYA does not have a photo you provided us .
Dec 13, 2015 | AEG Ovens
The light on my aeg competence oven and grill is not working. I can not use the timer.
It's either the thermostat / switch or the timer unit. Make sure the timer was not set to have turned off the grill first
http://www.espares.co.uk/part/cookers-and-hobs/thermostats/aeg/p/1604/143/0/0/1061574/top-oven-thermostat.html
May 20, 2010 | Ovens
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
Mar 09, 2010 | AEG D5701-4 Electric Double Oven
AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Feb 05, 2010 | AEG Ovens
Oven is AEG Competence, single oven, fan assisted, 4 yrs old. Oven doesn't heat. Light ok, automatic cooking settings not switched on, grill working
If the fan is working o/k, then you need to replace the oven element.
This is located at the rear of the oven compartment, behind a removeable cover.
This should solve the prob.
Please leave feed back.
Thankyou.
Jan 06, 2010 | AEG Ovens
Timers on my aeg competence cooker
Hi, My Competence B1180-4 digital clock keeps switiching itself off and then back on. This means that the timer etc dosen't work. It is intimitant.
Aug 10, 2009 | AEG B1180-4 Electric Single Oven
Need replacement Dial knobs on Oven
Look in yellew pages for a Zanussi dealer, you will need mod number,,serial number, and er number, all of which are on the rating plate found at the front of the oven.
Nov 17, 2008 | AEG B1180-4 Electric Single Oven
Clock settings
press 1st and third buttons together. use rhs button to set time and it should then work
Jul 13, 2008 | AEG B1180-4 Electric Single Oven
Ovens Logo
249 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
