Question about Refrigerators
Hello My kenmore refrig turns(the light) on but does not get cool and the freezer does not work
Your fridge uses nitrogen, which is what makes it cold! Therefore get someone to put the gas back onto your fridge! Another issue is that you must make sure that he finds where there might be a whole in the circulation system. The gas must have escaped through that hole. This will 100% solve your problem. Please do come back to tell us what has happened because people only come to these forums to ask and once they get the answer they never report back. Which I feel is selfish!
Posted on Jan 22, 2009
Inadequate cooling- Freezer on 4 reads 30 degrees on freeaer thermometer and 50 in refrigerator
Hello
Have A look at the fan in the freezer check that it is coming on.Do this turning the cooling down.
Also there is a vent or plastic duct leading to the fridge from the freezer,check for anything blocking old air from thr freezer to the refrig area.
May 25, 2011 | Kenmore 64802 Top Freezer Refrigerator
Kenmore 18tfa top freezer refrig model # 72852101 freezer works, no cool air going into the refrig part. Ice machine works fine too. fan is on.
Possible fan not blowing the air into the fresh food compartment or your freezer could be frosted up. Need more input.
Jan 29, 2011 | Kenmore Refrigerators
Refrig compartment does not cool on my new Kemore Frig.
Check and make sure the fan in the freezer is running. if not possible bad fan. If fan is running, check to see if you have any ice built up on back freezer wall. Normally frost type ice. If so, you may possibly have a bad defrost bi-metal mounted in the freezer section. Next could be a defrost timer control. Model number usally will help more in getting it right.
Feb 28, 2010 | Kenmore Refrigerators
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Feb 17, 2010 | Kenmore Refrigerators
No air coming into refrig to cool
We pulled the back panel in the freezer and found the coils frozen. We defrosted the coils and the fridge started working. We will be getting a new timer. Thanks
May 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore sidebyside
Hi! There,,,If you want help, one needs to explain the problem.. A refrig is quite simple in opertion, with time used experience. For a side by side the freezer is cooled with the same system as the refrigerator cooling system. One and only. Freezer works, do you mean it is provining design temperature of some -10 deg F??? Do you have a by-pass duct between the the two. yes, then open it up more, disconnect motor is auto, and prop vent open, set refrig temp to a low temp say 40 deg F. are we cooling??? Post your condition, if you want further info Regards,,,fmauka
Sep 05, 2007 | Kenmore 74822 / 74824 Top Freezer...
Kenmore top freezer unit-refrig not cooling past 50degrees
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 03, 2007 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
