Question about Maytag MMV5207A Microwave Oven
Will not heat
Hi again
I would like to know is there a code you can punch in on the pad for a microwave maytag 4205aa to reset it to factory settings,just in case it was knocked out due to a power failure??
thanks Dave
  • fekewigs Jan 23, 2009
    thanks for the help,it help me to determine it was toast.
  • Maytag Master
  • 9,174 Answers
No, you would need to do a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Posted on Jan 23, 2009
  • William Miller
    William Miller Jan 23, 2009
    Exactly what problem are you having with it?
    These can usually be economically repaired.
SOURCE:
Lite stays on,clock works, timer works, but keypad will not set to heat
It could be the pads themselves. The touch pads are notorious for going bad. The light staying on could be a bad door switch. Check there first. There are three switches in the door interlock assembly. One of them could be causing the unit not to reset so it can cook.
May 03, 2015 | Maytag Microwave Ovens
Maytag Microwave over the counter -error code SE
Banging on the control panel got it working would indicate a bad connection inside, not a short. Could be anything from a bad wire connection to a cracked solder joint on the main board.
Aug 23, 2017 | Microwave Ovens
Touch pad doesn't work
Your touch pad is connected to your board with a ribbon wire, it has probably come loose. Unplug the unit and remove the face plate. Pull it back and you will see the wire, it looks like a ribbon, push it in tight, replace the face plate and it should work properly. I see this happen all the time.
Sep 12, 2017 | Maytag Microwave Ovens
Maytag microwave cook delay - first minute on timer no heating, then works fine
Not a feature I've heard of.
I would do a hard reset by unplugging the oven for a minute or two, setting the clock, then trying again.
If it still does this, I would contact Maytag customer service at the number in the owner's manual.
Dec 25, 2012 | Maytag MMV6180WS Over the Range Microwaves
Just stopped heating, making a louder than normal sound as well is there a reset button or something I can do. all else works, pad, clock timer etc, just not heating?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 13, 2011 | Maytag MMV5156AAS Microwave Oven
Microwave will not heat up
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ghkd
Feb 25, 2010 | Maytag MMV4205 Microwave Oven
Microwave will not heat food. punch in heating time, press start and nothing happens
HI. your control board has failed. you will need to replace the control board asap if possible.
May 30, 2009 | Panasonic Microwave Ovens
Timer descends very quickly
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Feb 01, 2009 | Maytag MMC5000 Microwave Oven
MMV5000BAW maytag over-the-range microwave
Found this in the GE section instead of Maytag, but we're happy to answer it anyway.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doen't fix it.
If not, you may have a shorted keypad or bad control panel, either of which we can repair economically.
Please write back with more details if you need further help.
Nov 25, 2007 | GE JVM1870 Microwave Oven
Maytag MMV5207A Microwave Oven Logo
256 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
