Question about Dell Computers & Internet
Monitor does not turn on
Monitor light next to button blinking- when trying to turn monitor the scree icons appear but when button is relaesed the screen goes black
It would be good to know what make and model of monitor you have, this info can usually be found on the back on a label. It sounds to me as if the standby circuit has an issue. if you feel up to the job you could dissasemble it and take a look at the internal fuse, the actual switch mechanism itself and any capacitors on the board for the power circuitry. Pictures would allow me to help you more
Posted on Jan 22, 2009
When i supply power in my hp 1502 desktop and connect it with cpu than my desktop scree only show its going to sleep
1.check with a other monitor.
2.check the cabels should be seated tight.also the videocard should be seated tight.
3.the videocard or the monitor can be brooken check with a new or other monitor first.
Apr 17, 2013 | HP 1502 LCD Monitor
How to get rid of static
Your radio allows you to listen for weak signals on
the current channel at the press of a key.
To turn ON the Monitor Mode:
• For brief listening, press MON button. The RX
icon blinks.
• Press and hold MON button for 2 seconds until
two beeps sound for continuous listening. The
receiver circuit stays open, letting both the noise
and weak signals to be heard.
To turn OFF Monitor Mode:
Press MON button to return to "Normal" mode,
and the RX icon stops blinking and disappears.
Dec 28, 2011 | Uniden GMR22382CK Two Way Radio
Monitor menu appears automatically Problem
microswich in the monitor to be replaced and try presing hard once for relaese
Jun 20, 2011 | Computers & Internet
Installed AOC 2436vh, top of screen off of physical structure of screen, tried power down, physical reinstall, roll back of driver and reload of cd, how do I uninstall monitor to try again? Or adjust it...
I have the 2436V (no speakers), but I suspect the solution will be similar. My screen was a bit to the left of the monitor's physical display area, and I was able to solve it using the built in menu (If you take too long deciding what menu button to press next, the menu will time out. Just start over if that happens. You will get faster with practice).
1) Press the menu button on the monitor (the menu appears).
2) Press the up button on the monitor 4 times to highlight the icon that looks like a slightly angled screen with yellow cross-hairs in one corner (the toolbar for positioning the screen appears - all 5 icons on the positioning toolbar are blue).
3) Press the menu button on the monitor to "enter" the selected toolbar (one of the toolbar icons turns green to indicate the selected tool on the toolbar).
4) Select the tool you need using the up/down arrow buttons on the monitor (I needed the one that moves the screen horizontally, you need the one that moves the screen vertically).
5) Press the menu button on the monitor to activate the selected tool (the meter above the toolbar icon turns green to indicate the tool is active).
6) Use the up/down buttons on the monitor to position the screen.
7) Press the menu button to exit back out (or, just let the menu time out).
Note: the disk that came with the monitor doesn't seem to have drivers for Windows 7, but allowing Windows to search online while updating the driver found a compatible driver online.
Dec 22, 2010 | AOC Monitor
I have a lcd monitor problem, it wont turn on. the little light thats suppose to light up when you plug the monitor doesnt light up.. when i press the power button the green light appears for a sec and the...
sounds like a power issue with the monitor. try to remove and reconnect its power cord. If same thing happens, try using a confirmed working power cord like the one you use with the computer and make sure you test it out using a confirmed working power outket. If it has the same issue, would mean you need to get a replacement monitor. Refer to the vendor if it is still in warranty.
Aug 31, 2010 | Computers & Internet
PC boots for seconds then NOTHING APPEARS SCREEN
Check to see if you have inadvertently hit the CRT button which turns off your screen to turn on an externally connected screen even if there is no external screen plugged in. OR you could have a bad (Back-light) or (Inverter)
Jan 27, 2010 | LG Flatron L1750S 17" LCD Monitor
VL 1919 power button blue light blinks and screen
Yea I fixed it ..bought a new monitor......I tried the old monitor on two other PC's same problem.....
Nov 23, 2009 | Computers & Internet
Dell monitor blank. nothing appears on screen. light is blinking by minitor power button, but nothing at all on screen. I hooked up to my laptop, still nothing. Checked power/ tried new power cable. No...
Make sure you set up your laptop to display to a second screen. Depending on your Operating system, go to your display properties and go to the settings tab. Then click on the second monitor and enable it.
Apr 08, 2009 | Dell E773C 17" CRT Monitor
Green Power light blinking
Check the resolution in the Windows while connected to the old monitor. If greater than 1280 X 1024 and/or the refresh rate exceeds 75 Hz, the monitor may not respond. But you should at least see the BIOS splash when the computer is turned on. If that does not appear, maybe a problem has occurred in the monitor. Another indicator: if you turn the monitor power button off and then back on, you should get some sign of life such as "no signal", or "out of range". If nothing appears, that would indicate some problem within the monitor.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Jan 04, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
Dimming the brightness
Hey...Mama of many,
Try used your fingers press on the buttons on the monitor and the on screen will appeared. Then just press the next button until you reached the icon (brightness.) Next used the - and + to changed the brightness. Have a nice day!
Jul 29, 2008 | LG Flatron 295LM 22" LCD Monitor
Computers & Internet Logo
171 people viewed this question
Alun Cox
