Question about Vulcan EF3 Deep Fryer
Vulcan fryer probe open - Vulcan EF3 Deep Fryer
Why does my fryer says shorted probe
You need to replace the thermostat probe. That probe controls your heat and prevents it from over heating or not heating so if its out it has no way of being able to do so so it stays off. I couldn't find part but call manufacturer and provide serial number and they will get you everything you need and even help with any small questions.
Aug 26, 2014 | Vulcan Hart 2GR45DF LP - 45-50-lb Fryer w/...
Where is the reset button on vulcan fryer?
Most Vulcan fryers do not have a reset button. The high limit is self resetting when the fryer cools down to a safe temperature.
May 31, 2014 | Vulcan Fryer LG500-NAT
My vulcan lg 300 deep fryer latch won't turn what should I do
Some fryer valves have a safety lock, usually a slide on the handle near the valve body that must be released to open the valve. Check for this first. It's very rare for a fryer valve to stick unless it was forced shut with something partially blocking it. If not, let the fryer cool completely. Dip as much oil out as possible. Then disconnect the gas line and, with help, turn the fryer upside down draining the remaining oil into a suitable container. At this point, you have little to lose. Take a large wrench or piece of pipe to get more leverage and try to force it open and free it up. Do not use so much force that you damage the kettle. If you get it free, check to see that it does not leak before putting oil back in the fryer. If it leaks or fails to come free, replace the valve.
May 23, 2014 | Vulcan Kitchen Appliances - Others
On the display appear a sign of "draining " and the fryer does not satr
Are all drain valves closed completely? Will not turn on if there is one open...
Jan 02, 2014 | Vulcan 1GR45D Fryer
"PROB" shows when fryer is
Computerboard will display "PROB" error when it could not sense resistance reading from the temperature probe sensor (temperature probe sensor is either open circuit or short circuited). Check first the temperature probe connectors, tighten loosely fitted connectors on wiring harness and computer board, then check if the wires are not damaged. Disconnect the temperature probe and check the resistance using an ohm meter. If the reading is either zero or infinite, you have to replace the temp probe.
Dec 18, 2010 | Pitco Frialator SG14 Deep Fryer
Can not get fryer to turn on. when you flip the switch to the on position, the high limit light flashes and go back off emediatly, and no power comes back on. i can here a click in the board behind the...
The High Limit is a self resetting thermostat that acually works like an oven control. If the fryer is too hot it will cut off the gas burner valve voltage:
OEM PN is 00-854453
Original PN VUL854453
Source 1
http://www.3wire.com/webstore/parts/PartSearchResults.aspx?searchText=Switch+High+Limit&mfrCode=VULCAN
$98.50
Source 2 Must log in.. new account
http://www.a1service.com/vulcan/vulcanlimit.htm
$90.20
The 854453 number comes up often in the part search for the high limit.
The high limit contacts can be checked and reading the NO and NC terminals. This control / switch is normally closed until opened by heat at 450 Deg F.
Thanks for Choosing FixYa,
Kelly
Sep 28, 2010 | Vulcan GRD45 Deep Fryer
I cant buy just the nat gas to lp gas conversion parts for a Vulc
call your gas supplier as they have reasonable sources for all of these parts. shame on vulcan.
Mar 31, 2009 | Vulcan EF3 Deep Fryer
Vulcan Deep Fryer, burners shut off, remains off!
sounds like your gas valve to me, you need a manometer to test it under gas pressure.
Dec 07, 2008 | Vulcan EF3 Deep Fryer
HOW TO DRAIN THE OIL?
it should be in the front of the fryer after opening the front door there is a 3/4 drain valve
Sep 16, 2008 | Vulcan EF3 Deep Fryer
Vulcan EF3 Deep Fryer Logo
64 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Treefrog15
Treefrog15
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
