Question about Poulan Garden
Does the McCulloch WildCat chainsaw have a decompression lever?
Pulls hard with plug in
  • 211 Answers
SOURCE: homelight chainsaw pulls hard. can't get started
Hi Remove the fan housing with the starter mecanism.Pull the starter and check if it works properly.Try to turn by hand the flyweel.It is normaly to feel dificulty only when the piston comes up in the cilinder.If you feel difficulty all the time there is too much preasure on the cilinder walls(piston rings friction.Easy kick the end of the crankshaft with a hammer until the piston moves easier in the cilinder
please leave a rating.Thanks
cheers savumihai71.
Posted on Dec 07, 2008
Curt_W
  • 60 Answers
SOURCE: Trying to get McCulloch MS354 35cc chainsaw started
Stiff usually means good compression. So, pump the fuel bulb, put your foot on the flat in the handle, lock the throttle open using the button on top, set choke all the way out and pull. It should kick after a few pulls. Then close choke half way, and pull until it starts, then push choke all in. If it doesn't start, disconnect spark plug and take it out. Have someone watch while the sparkplug is held against metal engine to see if there is a good spark at the plug. If not maybe needs new coil. look at plug to see if it is wet, ie, gas is getting to it to isolate problem to carburetor.
Posted on Apr 27, 2009
  • 5 Answers
SOURCE: HARD TO PULL CORD WITH SPARKPLUG IN CHAINSAW. IF
sound like hydraulic lock,try leaving the spark plug out and pull it quite a few times with the spark plug hole facing the ground, this should shoot the offending fluid out.
might work ?
Posted on May 01, 2009
  • 110 Answers
SOURCE: How to test magnito on McCulloch 310 chainsaw
The only way to test an ignition module on any small engine is on the machine. Simple and easy.First remove the spark plug , then remove the wire that connects the module to the kill switch, its located right next to the plug wire above the laminations. Put a spark tester in the pkug boot and ground the other end. Pull the rope and look for a spark. Its that simple. If you have a spark, check the switch and wire, if you dont,check the grounding screws that hold the module to the block for a clean contact.If you still have no good spark its time to replace the Ignition module (coil).If you dont have a spark tester, ask someone dumb enough to hold it. If they jump and cuss you out you know you have a good spark
Posted on Nov 15, 2009
SOURCE: NEED INSTRUCTION MANUAL FOR MCCULLOCH 838 AS CHAINSAW
Found it at
http://www.mcculloch.biz/int/support/owners-manuals/?query=MAC+838&types=O
Posted on Apr 16, 2010
Testimonial: "Thanks exactly what i was after,thanks again."
Saw starter pulling too hard to start.
Check piston rings. Sounds like you have a seized engine.
Feb 20, 2013 | Husqvarna Chain Saw Models 51, 55
Thanks but my new model 450 doesn't have a blue choke like the others I have owned. This has a sngle lever and goes up to start and down to kill. I push it up, prime it,decompress and pull. It hits...
The start procedure is done on one red lever, as you say prime till the bulb is 3/4 full, push deco vave in, pull the red lever out against the spring and right up, this engages choke and part throttle, pull until it fires once, push red lever down to dissengae choke, then pull again until it starts, flick the throttle trigger to release the part throttle and bring the engine to idle,if all is correct it should start within three to four pulls, if not it needs tuning on the carb screws.
May 19, 2011 | Husqvarna 450 e-series 18" Chain Saw
How do i take apart an eager ****** mcculloch chaisaw to put on new gas lines
Drain the fuel tank, then remove a screw at the back end of the trigger handle, two screws at the rear of the case and possibly one or two under the rear case half. Keep track of which screws went where. The rear case should just pull off (watch the wire oil-pump lever which will come loose). The fuel tank pulls off rearward as well. This exposes the engine and main fuel line. Hope this helps!
Oct 24, 2010 | McCulloch Garden
Looking for a manual for mcculloch pm 484 chainsaw. cannot start the chainsaw.
If the ignition and fuel supply systems are good that is correct. I was not able to find a McCulloch 484. Are you sure that is the model number?
Lou
Dec 17, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Apr 27, 2009 | McCulloch Garden
Getting my 2001 yz 426 started
hold the decompression lever in and kick it slow then let go of the decompression lever and give it a good kick without using the decompression lever.
Nov 29, 2008 | 2001 Yamaha YZ 426 F
Husqvarna Chain Saw Rope Pulls Very Hard, what is the cause?????????
Has it always done this or has it developed?
Some saws have a decompression button to make it easier to pull over.
Oct 03, 2008 | Garden
Garden Logo
18 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
