Question about Gbc ® Pinnacle 27 Two-Heat Roll Laminator, 27" Wide, 3ml Maximum Document Thickness
The laminator keeps turning off and Er 1 flashes on the panel. Why is it doing this?
The Pinnacle 27 laminator is less than two months old and is laminating just fine. However, after about 7 resolutions it stops and an Er 1 flashes onto the front panel. I then have to turn it off and start it again. Over and over it turns itself off. Is this an electrical problem?
4 Suggested Answers
SOURCE: I have a gbc heatseal
There is a small 125 v 10 amp fuse in the circuitry on the right inside the unit. Whether or not this will solve your issue is unknown. I have one apart in front of me right now with other problems.
Posted on Jan 13, 2011
alpug
  • 1961 Answers
SOURCE: Using a model 95P laminator,
there are different reasons why the sheet didn't come out.
1. first, one part of the laminating film where adhesive is was exposed to the rubber roller. the reason why when the sheet place between the two laminating plastic film enter the laminator the heat cause this to bond in one of the rubber roller. (Remember that the paper should be placed in the middle between the two plastic laminating film were adhesive part is face together.. you can feel the side where the adhesive is when you touch it rough)
2. second, although you make it right by pairing two laminating plastic with both the adhesive part facing together, the connecting end for the two laminating were not cut proportionally. Thus, the part where an adhesive was exposed when you enter this on the laminator it will bond to the rubber roller.
You will have to open the the unit. Unscrew to remove the sets of rubber roller. Remove the plastic stuck on the roller. You can should strip off remaining adhesives residue on the rubber roller. The roller must be free from any foreign materials especially adhesives.
Hope this will guide you
Posted on Feb 19, 2011
SOURCE: Our heat seal laminator is
DO YOU HAVE THE DULL SIDE MEETING TOGETHER AND GOING THRU THE MACHINE
Posted on Nov 16, 2011
GBC Pinnacle 27. Right side top heat shoe does not get as hot as left side. Lamination is milky colored on right side
Could be one of the elimebts have burnt out as there are more than one into the tip just take to local shoe repiar as taking it to golf shop will be expensive
Sep 03, 2016 | Cars & Trucks
How do I find out the error codes?
Good Afternoon Delia Collins, thank you for your post!
Based off the information you have provided your Frigidaire dishwasher is flashing an "ER" error code on the panel. Typically, the "ER" stands for an error code sometimes to help clear out a false error code you can perform a reset on your dishwasher. In order to do that you would need to disconnect power from your dishwasher for approximately ten minutes.
If you continue to experience an issue with the error code I would recommend contacting a technician for proper repairs. The technician will be able to properly diagnosis your dishwasher and this will help you to avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Nov 05, 2014 | Frigidaire Dishwashers
Our machine is starting to squeal when working what do we do
There isn't anything you can do, those machines are screamers. sometimes they start screaching right away, sometimes it takes a few rolls of film run through before they start, but they ALWAYS start to scream, sooner or later. it becomes loud enough that some people refuse to use it because they think its coming apart. not my favorite.
Sep 18, 2014 | Gbc Pinnacle 27 Ezload Roll Laminator, 27...
Pinnacle er-1
left hand side cover is probably off and excess light is getting onto the motor speed sensor. put the side cover back on and try it, most likely that will fix it. could also be the set screw on the right side is loose, error 1 means you have a speed problem. check gears and chain. only other part that has caused this in the past is the keypanel.
Sep 15, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
Why won't someone answer the ??s about the GBC Pinnacle 27 power light in the back works, but no power
Each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime......
Westco Laminating Service 405-324-6092
Aug 09, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
Gbc pinnacle 27 ezload power light turns on but the front panel does not
you have one of the TCO's that is blown out, To test them you need to take the right side cover off, and test continuity from one side of the tco to the other, start with the tco wire that is connected to the tray switch, the other end of the tco wire is connected to the wire block on the right side of the laminator. just follow the wires back to the heat shoe and check for continuity. A TCO is no more than a temperature fuse. you can actually make a test "jumper wire" and jump across both connectors and it should power right on. You need to be careful and follow the wires back correctly so you don't fry the laminator the rest of the way.
Mar 31, 2014 | Office Equipment & Supplies
The heat button won't turn on
either the top or lower heater shoe TCO is blown out. take the right side cover off, trace the wires back to the heat shoe and check for continuity, (unplug machine first) find out which TCO is blown order another one, replace it and your off to the races. I've fixed many of them.
Mar 11, 2013 | Gbc 1701720: Pinnacle 27 EZload Laminator
GBC Pinnacle 27 won't come on
each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime.
Feb 20, 2013 | Gbc ® Pinnacle 27 Two-Heat Roll Laminator,...
I have a Pinnacle 27 EZ load Laminator that keeps showing an ERROR CODE 02, nothing in my service manual showes me what this problem is, the unit will not run, HELP!
have no idea what the code means but i would hazard a guess and say the heater circuit isnt working ,take it apart and try a volt meter across the heater element
Dec 16, 2010 | Office Equipment & Supplies
I work for the city of red deer, and we just purchased the GBC Pinnacle 27" laminator. We keep getting an error code ( Er.1 ) it dosent list this code in the manuel. We have tried calling the 7 different...
That error is the speed sensor and it could be a bad sensor or light is getting into the machine and causing a hard time with the opticals in the sensor or it could be bad set screw, The transport system that moves the lamination holder is having issues. Check the chain and gears and make sure they are tight.
Dec 27, 2017 | Office Equipment & Supplies
Gbc ® Pinnacle 27 Two-Heat Roll Laminator, 27" Wide, 3ml Maximum Document Thickness Logo
76 people viewed this question
Top Gbc Office Equipment & Supplies Experts
George Mclaughlin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
