Question about Reelcraft 5650 OLP
My reel craft 5650 olp leaks air
Where the hose meets reel
How to repair leaking inlet connection on the reel inside a yardworks retractable hose reel
sadly there is no repair parts for these pitch it and buy a new one all we can do .
Nov 23, 2015 | Garden
Petrol leaking from where hose joins tank
First, make sure the fuel line itself isn't cracked/torn from age.
Then check if the leak is actually where the hose meets the petcock (fuel shutoff), as if the hose clamp is loose.
Finally, if it's coming from where the petcock meets the tank, it's sealing washer (o-ring, gasket, etc) needs replacing.
Dec 07, 2013 | 2003 Harley Davidson FLSTF Fat boy
I have a leak where The air switch is. The leak is where the tube meets with the box. Would that be a seal?
The Air Tubing presses onto the little nipple on the underside of the air button. There is no seal on this set up. Once the air hose is attached to the nipple there should no air leakage when the air button is pressed.
Before you install the air hose you might cut off half inch on the end to make sure the end has not splits and you get a good piece of hose so it will seal properly.
US Parts Center
Aug 30, 2013 | Jacuzzi Home
Carrier ductless condensation leak
look at the base of the pan where the hose meets the pan for blockage to the drain
Aug 27, 2012 | Carrier XHB123D X/Y Series Heat/Cool Air...
Got longer hose how do i adjust the spring
Reel are made for a size 25' 50' Etc. what you want to put 30' on a 25' REEL.?.
Jan 15, 2011 | Toolshopusa Retractable 25' Air Hose
Craftsman 3/8 in. x 50 ft. Air Hose Reel, Retractable how to replace hose
Unreel the hose all the way out. Unscrew brass fitting at reel. Screw on new hose with fitting tape. reel up new hose. You're done. Good luck.
Jan 07, 2011 | Suncast Air Hose Reel GCWAR50R
Cars over heating leeking coolent for the bottom and not sucking in form the resivor and not leaking form hoses
Change the thermostat. Follow upper radiator hose to where it meets the thermostat housing on the engine. Remove the 2 or 3 bolts that hold on the housing, then replace the thermostat and seal and put housing back on. With cap still off, vehicle running and warm, then fill up the coolant system. Make sure there is not air pockets by burping the hose when adding the fluid.
Dec 31, 2010 | 1999 Plymouth Breeze
Can thee hose be fixed if it has a leak.
If the leak is on the OUTBOUND side that is towards the Nozzle, it CAN be repaired but for safety I would strongly recommend a new hose. Main reason being that the pressure generated in that hose will blow MOST joints you put in there.
If it is the input side then just get a hose joiner and install it.
Feb 07, 2010 | Karcher Hose Reel
Ratchet/click stops do not work,but spring still reels in,no rust or dents in any part
catch pawl in the reel is shot. I used to work in places where this happened. The only solution is tie the hose off on to a stationary object.
The only other solution is replace the reel..
May 10, 2009 | Toolshopusa Retractable 25' Air Hose
Reelcraft 5650 OLP Logo
Top Reelcraft Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Reelcraft Air Tool and Compressor Expert? Answer questions, earn points and help others
