Question about Samsung RB217ABPN Bottom Freezer Refrigerator French Door
Digital display reads OF all the time wont stay on any temp.
My beverage cooler MCBC58DST wont stay cool after it reaches target temp.
Throw it out and get another model from another company. Their units are junk!
They last a year, at best. Them and Magic Chef are one and the same...so you may have to bite the bullet and get a real unit.
Good luck. I speak from experience...I've had four now. Complete junk!!
Nov 23, 2014 | Vissani 5.8 cu. ft. Wine and Beverage...
2007 Chevy Silverado 2500 HD. I was driving and my digital dashboard reported engine hot and AC turned off. My temperature gauge read cool. What do I need to replace?
This sounds like a bad coolant temp sensor that give computer false reading, check the coolant temp sensor connector and if it is good with no bad wires to connector then replace coolant temp sensor , when the computer gets a signal from temp sensor that engine is hot it turns fans on high speed to cool radiator and displays a/c turned off , if this truck does not have electric cooling fans then they wont run just explaining what happens depending on engine and cooling set up. replace coolant temp sensor and check connector.
Dec 25, 2012 | 2007 Chevrolet Silverado 2500HD
Digital control reads REM off and we connot seem to reset the control. What should we do?
Press and hold the "temp up, temp down and mode" buttons at the same time for 5-7 seconds...The display should show REMon or REMoff... You have REMon probably. Toggle with the up/down buttons to show REMoff... This should default back to original display. If not, push the mode button....
Aug 18, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
No power to white rogers thermostat
Either you blew the fuse on the air handler control board or you burnt out the air handler transformer.
The thing that blew the fuse is probably the contactor in the condenser unit. You will need to check out out cause of the outage before replacing the fuse or transformer.
heatman101
Apr 08, 2010 | Carrier 38CKC036 Air Conditioner
My refregirator temperature sometimes warms up 10 to 15 degrees higher when i open its doors to load it up with items and takes a long time to cool back down.
If your reading the display temp , your reading what the thermistors are telling the control board . NOT the actual temp inside . After closing the door , from the food that was already cold in the fridge , the coldness will keep the inside temp , the same temp as when you opened the door . The thermistors themselves will detect the warmness and send it to the board . A good way to try to put this acrsoo , is to put a thermometer between , say , 2 packages of salads . Wait a little while and open the door . Watch the display temp , then read the thermometer between the packages . The thermometer will stay the same , due to the coldness of the packages not changing . When you put food in the ref , the surrounding food will give off some of the coldness to the freshly installed food , thereby makeing it cold faster . After a while , this coldness will return to the thermistors and the display will start to drop in temp . Hard for me to put into words , except for , the temp reading will actaully be the same as the actual temp display , only when you FIRST open the door .
Sep 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Tandy digital controller display is flashing on and off
whoa bad board may be but first check the thempetore sensor is at around 10k omh if bad replace first read the manual to change the time if doesnt chage replace the board
May 26, 2009 | Jandy Digital Lite2 Lj250 Btu Heater,...
HI showing on digital display frialator 14ss/chhov
When high is displayed it means that the probe and controller is reading that your oil temp is 30 degrees over your set temp. Use an external probe, locate it about one inch above your probe in the tank check actual temp and compare to your set temp. If you find that it is not 30 degrees over than there may be a problem with your probe, wiring or the digital controller. With a multi meter you can check your probe resitance it should be at 942 ohms at 350 degrees.
Jan 26, 2009 | Pitco Frialator 35C Deep Fryer
Hotpoint oven
does the display go to 425 or are you putting a dial thermometer in it?is the new control doing the same thing as the old control?
Oct 23, 2008 | Hotpoint RGB745 Gas Kitchen Range
Samsung RB217ABPN Bottom Freezer Refrigerator French Door Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
