Question about Sharp R-1500 Microwave Oven
Not working when the microwave is turned on there is a blue light (electrical) coming from the right side of microwave. What do I need to replace to get this problem fixed
  • Sharp Master
  • 5,568 Answers
This sounds very much like an arc and may produce ozone that you can smell. If it is an arc, the high voltage power supply for the magnetron is at least working and the fact that it is arcing may come from a breakdown of insulation, something that could be a safety hazard if you decide to open the unit - be very careful; the energy needed to feed the magnetron will definitely roast human flesh too.
While there are a number of things I offer guidance for on microwave ovens, this one makes me uncomfortable and I really wish you would either retire it or have a pro look at it for you.
Posted on Jan 22, 2009
Riccar microwave oven RM 700N Light no longer works - can't figure out how to get to the bulb to replace it.
1 Unplug the microwave oven from the outlet. Wait 20 minutes for the capacitor that is inside the microwave to discharge.
2 Unscrew all the screws around the casing by turning them counterclockwise.
3 Remove the cover by lifting off.
4 Locate the light bulb in the microwave. This will be located on either the right or left side.
5 Unscrew the light bulb by unscrewing counterclockwise. Some light bulbs are held into the socket by two notches; for these you will need to gently push on the bulb and turn counterclockwise to remove the bulb, then pull out of the socket.
6 Place your new bulb in the empty socket and secure by turning clockwise until tight, or if the bulb is one with notches on both sides, then guide the notches into the slot on the socket, push gently and turn clockwise until clicked into position.
7 Replace the cover and screw back on. You are now done and may plug back in the microwave.
May 02, 2011 | Microwave Ovens
Our microwave is a GE Spacemaker, Model # JVM1630WB004, mfg. in Mar, 2001. Just today it suddenly decided not to function other than the light in the oven coming on when activated, etc. It does not cook...
If your microwave oven doesn't seem to work at all, check these:
Fuses
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Oct 27, 2008 | GE Microwave Ovens
Tip
What to do when your microwave oven wont turn on after a electric storm.
When there is an electrical storm and your microwave oven is affected, and wont turn on. First you should un screw all the screws the two on the bottom right, then the two on the back of the microwave case and then the two others on the left bottom. Then you need to lift up the cover case upwards and then towards the back until the case is completly off. Then you must blow off the dust with a compreser and make sure thatall conections in side are fit tight, then look for the fuse. Some fuses are located on the right uper side of the microwave in a black little box with two cables and two screws, or it can also be located on the bottom of the microwave or the back panel. First unscrew the the containing unit for the fuse then pull the two cables from the conection and set them apart from each other if needed label them with a and b then with a small flat screw driver push the tabs on the containing case of fuse box and pull apart. Then a small shaft and spring will come out make sure to set them in the order they came out first the shaft then the spring. Then the fuse is at the bottom of the box in side, turn it up side down and the fuse will fall out. Then change the fuse "20" amp fuses needed in most microwaves but check the containg unit and see proper fuse amp. then installing method is reverse of taking apart. Remeber to make sure that all conections are not loose and falling. when done your microwave oven will work again.
on Aug 22, 2010 | Microwave Ovens
Lightbulb on ceiling of oven went out. How do I
Hello :
1:Unplug the microwave oven from the outlet. Wait 20 minutes for the capacitor that is inside the microwave to discharge.
2:Unscrew all the screws around the casing by turning them counterclockwise.
3:Remove the cover by lifting off.
4:Locate the light bulb in the microwave. This will be located on either the right or left side.
5:Unscrew the light bulb by unscrewing counterclockwise. Some light bulbs are held into the socket by two notches; for these you will need to gently push on the bulb and turn counterclockwise to unsecure the bulb, then pull out of the socket.
6: Place your new bulb in the empty socket and secure by turning clockwise until tight, or if the bulb is one with notches on both sides, then guide the notches into the slot on the socket, push gently and turn clockwise until clicked into position.
7: Replace the cover and screw back on. You are now done and may plug back in the microwave.
Warning : Unplug the microwave before starting and wait 20 minutes for any residual electricity to be bled off from the capacitor.
Things you will need : Phillips screwdriver
good luck .
please rate !
Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE MIcrowave model JVM1631BJ01 hood lights won't work
The part that controls that is goes through your control panel on your microwave. For the lights to come on to start with the door being closed switches have to be working right and when you press start the lights come one. When the microwave is through cooking and you open then close the door then the lights should go out. The logic IC on the control panel board that detects all these events is not being reset correctly. Unless you get a microwave tech to track down the component on the control panel circuit board it is not something that you could do on your own since it takes voltage and signal checks with the proper equipment and then some soldering and desoldering of the defective component(s). Good luck and God bless.
Dec 22, 2008 | GE JVM1631 Microwave Oven
Ge sca1000h
UNPLUG THE MICROWAVE FROM THE ELECTRICITY,,,,AGAIN,,,UNPLUG THE MICROWAVE FROM ELECTRICITY---NOW ,SOMETIMES YOU CAN SEE A TRAP DOOR LOCATED ON THE OUTSIDE OF THE CABINET --THE SIDE WHERE THE LIGHT IS ,, MAY NEED A PHILLIPS HEAD SCREWDRIVER,,THE LAMP IS THERE--DID I SAY ---UNPLUG THE MICROWAVE,,YES ..IF YOU ARE NOT COMFORTABLE WITH THIS --DON' T TOUCH IT !!!!!! TUNICA
Oct 30, 2008 | GE Advantium SCA1000H Convection /...
Whirlpool GMC305PD -- Thee beeps and won't start
the 3 beeps are telling you that your fuses are blown
Mar 26, 2008 | Whirlpool RMC275PD Microwave Oven
Stove Light
try to fine the light switch in door and check the bulb
Sep 18, 2007 | Whirlpool MH7155XM Microwave Oven
Sharp R-1500 Microwave Oven Logo
150 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
