Question about Peavey Music
How to hook up peavey profex 2 - Peavey Music
Is there a way to hook a Mackie profx12 mixer to "this" Peavey PA?
We would need to know which Peavey PA you're asking about.
Feb 18, 2016 | Peavey Music
HOW CAN I HOOK TUNER AND MORE SPEAKERS THROUGH MY PEAVEY SESSION 500
There is an external speaker jack on the back.
Plug in a cab of your choice down to 2 ohm load.
enjoy.
Jul 29, 2015 | Peavey Music
Senpera 2 when plugged into amp lights up but no display screen shows
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Dec 31, 2014 | Peavey Electronics Peavey Sanpera 2
I want to know how to connect a powered subwoofer to the peavey 10 mixer
Connection is hooking up from mixer's main outputs (L,R) to
Subwoofer amp inputs.
Oct 10, 2013 | Peavey Electronics Peavey PV10 Mixer
Hello, What is the proper way to connect an Ashly XR1000 Crossover and a Pyle Pro PTA1400 power amp to my Peavey XR8600 so I can use 2 subs? The subs are not powered, but do have a passive crossover...
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00513220_7.pdf I didn't look at the manual for the crossover but this is probably the way I would do it. Look at page 13 in the manual : Come out of the Main out (31 in the diagram) into the main in of your crossover. Go out of your crossover Hi and Mid out setting back into Power amp In 1 (labelled 32 in the diagram). Hook your speakers that you normally use to the output jacks on the back of the Peavey. Make sure you match the output impedances. Go out of your crossover low output into the Pyle power amp and out of the Pyle into your subs. Make sure the impedance ratings of all your speakers match the output impedances of your amps. You will only be running in Mono mode as that is the signal output of the Peavey mixer. You can run faux stereo by using the Main monitor Out as 1/2 the pair and the Main Out as the other 1/2 to both channels of the crossover but you won't be getting a true stereo pan mode.
Aug 22, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Peavey XR800F 8 channel - I can't get but very little sound to my big speakers. Help
Troubleshooting is always a "process of elimination." Have you tried hooking up your Peavey powered mixer to another set of speakers? How about connecting the speakers to another audio system? Your term "very little sound" could mean audio input problems, mixer/amp settings or failure and possibly speaker damage (internal passive crossovers). Please be more specific.
Jun 12, 2010 | Peavey Pv 2600 Power Amplifier
I have 2 Peavey Impact 1015s and 2 PV 118 Subs. I have a Peavey Kosmos PRO that runs from my Numark CDMix3 to my amps. My two amps that I have are a Peavey CS800x and a Crest Audio CD3000. Could you tell...
Just a note regarding connecting: USE BALANCED lines everywhere you can. Use either XLR if available or TRS type cables. This will reduce noise pickup.
Another hint: For SAFETY of your equipment run ANY interconnected devices from the SAME power source. DO NOT say power the amps from one place and your other equipment from a different outlet. Afford a power distribution system that feeds from a single receptacle or nearby receptacles near a common electrical panel. This will ALSO help avoid noise as well as the hazards to your equipment from ground loops.
Apr 01, 2010 | Peavey Music
Peavey sound board 2 channels not working
check for cold solder joints from the input jacks and the fader. If any look suspicious (dull or grainy) re-solder.
Apr 29, 2009 | Peavey Pv 2600 Power Amplifier
Music Logo
47 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
