Question about HP Officejet 5610 All-In-One InkJet Printer
Need a free network tool to troubleshoot all printers
Searching for a network printer tool to troubleshoot and solve printer problems on a network???
    Habit-Forming:
    New Friend:
  • HP Expert
  • 40 Answers
  1. Click the Start button, and then, on the Start menu, click Devices and Printers.
  2. Click Add a printer.
  3. In the Add Printer wizard, click Add a network, wireless or Bluetooth printer.
  4. In the list of available printers, select the one you want to use, and then click Next.
  5. if you want to get proper detailed information about hp printer support then you should call on 1-888-924-2961 toll free number anytime.
Technical Support For HP Printer
Posted on Oct 13, 2016
HP photosmart c309 printer continues to not print or will only print the header and stops printing. How do I fix it?
Network troubleshooting
If you are encountering issues using your HP Photosmart over a network, try the following steps in the order listed:
  1. Turn off the router, product, and computer, and then turn them back on in this order: router first, then the product, and finally the computer. Sometimes, cycling the power will recover a network
    communication issue.
  2. For wireless networking issues, run the Wireless Network Test from the product control panel.
    1. Press Setup.
    2. Press the down arrow button until Network is highlighted, and then press OK.
    3. Press the down arrow button until Wireless Network Test is highlighted, and then press OK.
      The Wireless Network Test prints.
    If a problem is detected, the printed test report will include recommendations that might help solve the problem. If you need to change the network settings on your product or have never run the Wireless Setup Wizard, do so now.
    Double-click the HP Solution Center icon, click Settings, click Other Settings, select Network Toolbox, and then select the Wireless Setup Wizard link.
  3. If the previous steps do not solve the problem and you have successfully installed the HP Photosmart Software on your computer, run the Network Diagnostic tool.
NOTE: The diagnostic test might prompt you to connect a USB cable between the product and your computer. Position the product and computer near each other and have a USB cable readily accessible.
To run the Network Diagnostic tool. In the Solution Center, click Settings, click Other Settings, and then click Network
Toolbox. On the Utilities tab, click Run Network Diagnostics.If you are unable to run the Network Diagnostic tool or it does not help solve the problem, check the following sections for additional information:
  1. Make sure that the computer is connected to your network
  2. Make sure that the product is connected to your network
  3. Check to see if the firewall software is blocking communication
  4. Make sure the product is online and ready
  5. Make sure the HP Device Discovery software is running
Sep 09, 2014 | HP Office Equipment & Supplies
Hp officejet 7000 printer cartridge bulb and power blinking
Carefully check the Header . hope it will solve your problem.
Jul 16, 2014 | HP Officejet 7000 Wide Format Printer...
Ribbon error on B-EX4T1 with direct thermal labels
First of all, With any Toshiba label printer, after a parameter reset, you must send a label before doing a feed. Otherwise the printer will try to feed the ribbon.
You can use the setting tool to tell set the printer to direct thermal also.
Easiest way is to use the windows driver , add a label format coresponding to the one you are using, verify in the support tab that you are in direct thermal, do a test test print from the driver and you'll solve your problem
Apr 17, 2014 | Toshiba TEC Office Equipment & Supplies
Need default printer driver for color laserjet 3800n for windows 7 32 bit operating system
The Windows 7 has a compatible driver for many teams, try your printer is a greatadvantage when connecting it almost immediately begins to install. And do not waste your time searching for drivers on the network, there is little to W7
Apr 23, 2012 | HP LaserJet 3800n Printer
There are gaps in my printing!!! The docs are missing lines...Is it the printheads or could it be an ink problem?
Yes it might be a problem with the print heads. You can try cleaning printheads under tools menu. After cleaning printheads click on Align Printer in Tools menu and that will solve your problem. If not then you might need to replace the printheads. If you these print heads are less than 2 years then HP will replace it for free.
Apr 19, 2011 | HP Officejet Pro L7680 All-In-One Printer
Can i make my printer HP Officejet Pro L7580 wireless?
The printer will work with a wireless network, but you will have to set up your router or AP to broadcast a wireless signal, then configure the printer to communicate with the access point. Please see this HP support article, and this home support page for your printer. (or choose from here.)
Then, depending on your particular operating system, read about setting up a home wireless network here by choosing your os and then searching the help & how-to page for wireless networking or setting up a wireless network. You will find step by step instructions. Also check the support site for your router or AP, as they will have instructions specific to your router.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Dec 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
My lasejet 1100 print only test pages wether i print other documents please solve my problem soon
HP designed a quick and easy tool that diagnoses and resolves many printing problems: The HP Print Diagnostic Utility. HP recommends that you download and install the Print Diagnostic Utility any time you need to troubleshoot a printing problem.
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Nov 04, 2010 | HP LaserJet 1100 Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
198 people viewed this question
Seeker5211
Seeker5211
