Question about Toshiba BDX2200 BluRay Player
Reset toshiba bdx3300 bluray player - Toshiba BDX2200 BluRay Player
I had Att DSL and never had an issue with my bluray player. I switched to charter Internet and now my Samsung BDP-1590 bluray player will not connect to the internet. Any ideas? I have reset the bluray....
If you're using the same router, nothing should have changed. If you're using a different router, you will need to connect to the network from the blu-Ray player, providing the network pass phrase/preshared key. You could try using an Ethernet cable from the router to the BD player and see if it works that way. This is assuming your network is up and the rest of your devices work fine.
Hope this helps!
-Plemmons
Jan 24, 2015 | Samsung Televison & Video
How can this player be made region free?
'Regioning' is not part of the actual player, it is built into the codec's used to decode the information on the disc, and monitored by the operating system. so basically, you need a hack that tells your decoding program that it is from the region the disc was published in. so far I haven't found an effective one.
Aug 11, 2014 | Toshiba BDX3300 - Blu-ray Disc Player
My samsung BluRay Player BD D5700 will play DVD's but will not play BluRay DVD's.
I had a similar issue. Try resetting your resolution. By default it should be at the highest level. I reset mine to 1080i and now the BluRays will play.
My TV is a few years old, I think it was bogging down because it was getting too much information from the player, but that's just a guess.
Jan 28, 2014 | Samsung BDD5700 BluRay Player
Toshiba BDX3300 doesn't have a menu screen, but it turns on
What kind of tv are you plugging this into? Also has the input jacks on the tv ever been yanked on while something else was plugged in? Something might have been damaged on the TV.
Oct 28, 2012 | Toshiba BDX3300 Blu-ray Disc Player
After performing an update now it will not connect to the internet
This is just a suggestion but I would check for an firmware update as well. Can be found on the Toshiba website.
Oct 07, 2012 | Toshiba BDX3300 Blu-Ray Disc Player
Bluray player can't hear voices but background music
Either the player or the set it is hooked to may have in the audio settings a "Hall" or similar setting--background will be louder than people speaking---its a setting.
What is brand of TV? (Toshiba?)
May 16, 2012 | Samsung BD-P1500 Blu-Ray Player
The Kick-*** Bluray won't play on my Toshiba BDX2000 player. Is there some way to update it so the disc will play?
Finally found the BDX2000 firmware.
Here ya go:
http://support.toshiba.ca/support/ceg/downloads/all/view.asp?docid=D000026
Aug 08, 2010 | Toshiba BDX2000 Blu-Ray Player
Toshiba BDX2200 BluRay Player Logo
64 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
