Question about Home Security
Genie gxl9500 wiring diagram
How to wire my garage door opener
SOURCE: garage door sensors
#2 and 3 on my opener. #1 and 2 are atteched to the wall button. So # 2 has both attached. Hope that helps.
Posted on Aug 24, 2008
dburns60
  • 410 Answers
SOURCE: Genie Directlift garage door opener, wall control problem.
Sounds like a skinned wire on your front or rear limit switches is touching metal. Go over your low voltage wiring and test again.
Posted on Jul 05, 2009
  • 3197 Answers
SOURCE: I have LiftMaster garage door model 41A3039 and
To program the keypad, first unplug the garage door opener from the electrical outlet. Next remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Posted on Jul 13, 2009
  • 3197 Answers
SOURCE: wiring diagram for garage door sensers
Each sensor has 2 wires. One solid white and one white with a black tracer. The solid wire from each sensor goes to terminal 2 and the white wire with the black tracer goes to terminal 3.
Posted on Oct 16, 2009
  • 3197 Answers
SOURCE: liftmaster 1265LM garage door opener control wiring diagram
If you are looking for a schematic diagram they are not available.
Posted on Mar 04, 2010
Wall button worked for awhile, now will not. Have tried a replacement, it does not work either. hat can I check?
Touch the pair of wires that go directly back to the garage door opener together. If the garage door closes, than the wall switch is the problem. If the garage does not close when the two wires are touched together, than the problem is with the garage door opener. Please check to make sure that the opener is plugged-in and getting power to it also.
Jun 06, 2015 | Genie Garage Door. SilentMax 1000 3/4 HP...
Garage door opener not working
Sensor must show steady light to close circuit and let opener work. If aligned, then there is a loose or broken wire. Try reaiming first to get steady light. Then check all wires . Another way to test and prove that is the issue is if u hold down the wired button at ur back door and the opener closes, then it is sensor issue. Good luck.
Apr 11, 2015 | Genie Company Genie Garage Door Opener...
Learn button for model GXL9500 where is the Learn Button located?
That is a Genie Opener and there are several "versions" of that. Take off the light globe that faces the door. Two screws at the top should allow it to fall and hang from the bottom attachment. Locate where the wires for the eye beams and the wall button are attached to the opener. The learn button should be right under those wires. Good luck!
Jan 19, 2015 | Building Materials
Genie garage door won't shut. the down limit switch wire (brown) got caught and I had to reconnect...stripped and twisted wires (just the brown down switch wire) together ... door still won't shut , it...
You don't say which model you have, however, MOST Genie systems use the switches as temporary contacts. By twisting them together, the computer board is reading it as a short. You need to replace the switch and route the wires properly.
Nov 21, 2009 | Genie Company Genie Excelerator Down Limit...
I have a chamberlain garge door opener and I bought a genie intellicode outside remote access and can't get them to work together.
They will not work together. You need to get the keyless entry for your chamberlain garage door opener. Or got a wired system gd-1 from Domino
Oct 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Jul 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programming my keyless entry
Yes, you purchased the wrong wireless. You must get a Genie keyless and there are two types of Genie keyless (GWKP & GWK-BL) depending on which Genie operator you have. You might think about a wired keyless entry (Domino GD-1). Then if you change your operator you don't have to change your keyless.
Nov 09, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Battery does not last
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Aug 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
74 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
