Question about Refrigerators
Water puddling under the frigerator
The pan under the refrigerator is overflowing. Either too much condensation water is being produced or it is not evaporating quickly enough. Which could it be. At least a whole quart of water is being produced per 12 hour period.
    Sniper:
  • 50 Answers
One thing you should check first is to make sure the condenser fan is running. the fan is usually next to the drip pan at the back of the unit. make sur your condenser is clean and that air movement isn't blocked due to a dirty or clogged condenser which result in very little hot air is circulating around the drip pan to evaporate the water. if you have an icemaker and water dispenser check to see that theconnections located very close to the drip pan. other than that i don't know of anything else that could make(or leave ) that much water in the drip pan
Posted on Jan 22, 2009
I had the same problem. The problem was the drain tube from inside the freezer to the drain pan was partially plugged so ice was building up inside, then when the freezer went thru its defrost cycle large amounts of ice were melting. I fixed it by removing valve in the end of the drain hose, all ice inside freezer and ice in drain hose (pour hot tap water thru it).
Hopefully this helps.
My refrigerator is leaving a puddle under the freezer - it is a side by side. There is not a drip pan in the bottom. Should there be a drip pan? What could be causing the puddle?
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 16, 2011 | Hotpoint Refrigerators
Hi, I have a refurbished RFG297AARS from Samsung that we purcased as a refurb about 7 days ago. On day 1-3, a puddle of water formed under the back right underside of the fridge, without the water line...
Chances are its either the drip line or drip tray.. there is a drain to route the condensation pulled out of the fridge and freezer that leads to a drip pan underneat the unit.
Either the drip tray was not installed.. reinstalled incorrectly or the drain tube is leaking or no longer directed to it, or it's overflowing due to excess condensate.
Best of luck!
Apr 26, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
On humid days water puddles in the bottom of the frig.
Sounds like the door is not closing properly so humid air is coming into the fridge OR door not closing properly and the humid air is condensing around the door so it is leaking the condensation OR
The water from the defrost cycle is not evaporating so it overflows from the evaporator pan above the compressor. You better call a service technician before getting some floor damage (Do not call A&E)
May 02, 2010 | Refrigerators
A stream of water leaks out of the bottom of the fridge at night.
the condensate pan under your fridge has overflowed. this pan catches any condensation from the evaporator coils.
Nov 12, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
Water is leaking from under GE side by side from time to time.
This _may_ be normal behaviour. When the freezer defrost element is heating, ice that melts off of the evaporator coils in the freezer will drain out of a small opening at the back of the freezer compartment and into a catch pan under the refrigerator. If that pan has other debris - cat hair, napkins, etc - the water may overflow the pan onto the floor.
Get behind the fridge, remove the bottom panel (at least that is how I can access it on my GE side-by-side), and see what you can see.
While you are back there, it is a good idea to clean the dust from the condenser coil, or use a shop vac to blow the dust from the coil.
Remember your electrical safety and unplug the fridge first, and be careful what you touch. I assume the compressor uses a large start capacitor that could still be energized even with the fridge unpluged.
Jul 28, 2009 | Maytag MSD2656G Side by Side Refrigerator
I have a jenn air JCD2389GES. Every day I'm getting puddles of water underneath the the unit. Our ice maker is turned off (broken for the third time)but the water line is still open to dispense water. We...
The condensate drain may not be draining into the pan under the fridge or it may have a leak or could even be not connected to the condensate pan in the evaporator.
Another possibility is that your condenser might be dirty or plugged causing the suction line going to the compressor to freeze up and then thaw leaving puddles under the fridge. Clean the condenser (the coil under or behind the fridge) and it should stop.
Over stocking the freezer will cause this as well. If you cover the air return in the freezer the evaporator will freeze up and the suction line will freeze back to the compressor.
Jul 09, 2009 | Jenn-Air JCD2389G Side by Side...
Ice freezing up on bottom of freezer and water puddles in front
Two possibilities, ice maker leaking or the defrost drain is blocked with ice or another object. Unplug the freezer and remove the rear panel in back of freezer. At bottom of the evaporator coil is a tray that catches the defrost condensate and sends it to the pan beneath your refrigerator to be be heated by the compressor and fan heat produced from the condenser. The moisture is then returned to the air inside your home. If the drain is blocked with ice or anything between the freezer and the pan below, the condensate tray will overflow will end up inside your freezer or fresh food compartment. Questions? I will be here to help you, Let me know, Sea Breeze
Jun 23, 2009 | Maytag MSD2758G Side by Side Refrigerator
My side by side refrigerator is leaking water from the rear
It sounds as if the refrigerator is low on freon or either the compressor is going out. The pan is catching the condensation from the coils, probably during the defrost cycle and is filling the tray up.
Mar 17, 2009 | Refrigerators
GE Profile TFX27PF/TFT27PF Refridgerator
There is a line from the defroster catch pan, up under the freezer, to an evaporation pan, down under the bottom. If it becomes clogged with dirt, bugs, whatever, the catch pan will overflow, and leave a puddle on the floor. Find it and unclog it.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side refrigerator has puddle under freezer
Check and clean door seal, chech defrost drain tube ad a cup of water and clorine into tube, Check drin pan and clean under refer.
Sep 08, 2008 | Sub-Zero 690 Side by Side Refrigerator
Refrigerators Logo
370 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
