Question about Solo Garden
Fuel ratio for solo 662
Fuel ratio for 662
Solo 662 chainsaw carburetor adjustment
most non professional grade or smaller saws are only adjustable by re jetting the carb. if they are adjustable there will be a low, high and idle adjustment on the side of the carb, however unless you have a portable tach and know the rpm limits or are experienced doing it "by ear" i wouldnt suggesting messing with it as youll more than likely burn up the power head.
Jan 08, 2014 | Solo 662 667 Chainsaw Carb Carburetor
What is fuel mixture for solo motosage 60135
Some say 100:1 with synthetics. I use synthetics on 80cc and larger saws in the range of 40/50:1. I never go higher than that....saws are just too expensive to be stepping over dollars to pick up pennies. A lot of people are trying to make mixing ratios like some kind of mystery voodoo. You'll always be fine in the 40/50:1 range with a good synthetic oil.
Jun 16, 2013 | Solo 654 Chainsaw Vintage Collectable Saw...
Fuel mixture ratio
Oil Mix Ratio:
Starting in the early to mid 90s Dolmar, Echo, efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl and Tanaka all started recommending 50:1
  • 1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil or
  • 4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen recommend 40:1
  • 1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil or
  • 4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
Jan 07, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I need to know what the fuel to oil ratio is on my Stihl mini boss chainsaw
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
Your OM can be found here:
Stihl Product Instruction Manuals
http://www.stihlusa.com/information/info_product2.html
If you want to verify my recommendation.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Sep 04, 2010 | Garden
Fuel oil mix for a Poulan 14" saw ?
Oil Mix Ratio:
Sep 02, 2010 | Garden
What is gas oil ratio for a 16 inch poulan chain saw
Oil Mix Ratio:
Lou
Aug 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Just bought a McCulloch 32cc, Mdoel 3214 from a pawn shop with no manual. Does it require mixing oil with the gas and if so what ratio?
Fuel requires 2-cycle oil be added, bar oil is straight from the container.
Oil Mix Ratio:
Lou
Aug 06, 2010 | McCulloch Garden
What gas to oil ratio is needed
Oil Mix Ratio:
Lou
Jul 12, 2010 | Poulan Pro Chain Saw 46cc 20"
Model PM374 mixture ratio please
Hello George:
I cannot find an OM for your saw. I did find 3 IPLs the oldest being 1993. I have 2 McCulloch (1983 & 87) saws both older than yours and their OMs recommend the current mix ratio of 40:1
Oil Mix Ratio:
Lou
May 10, 2010 | McCulloch Garden
Garden Logo
Top Solo Garden Experts
Colin Stickland
Colin Stickland
Ted Maxwell
Are you a Solo Garden Expert? Answer questions, earn points and help others
