Question about D-Link AirPlus Xtreme G DWL-2100AP (DHDWL2100AP) 802.11b/g Wireless Access Point
Password How can i setup a password on an existing setting? thanks, bogdan
  • 366 Answers
Assuming you want set password in your WLAN:
  1. connect to router using the IP address you find referred to gateway in your connected PC (use ipconfig or check on net connection status).
  2. in wireless section home tab set Authentication to WPA-PSK create a pass phrase you'll use to enable the connection on Client PC.
You can see a full simulation here
Let me know if you are looking to set password on your PC to log into existing WLAN
Posted on Jan 24, 2009
Every iPad should be capable of sending email. You first have to setup the account, in settings, then email, then add new account.
While entering a new account, you have to fill in all settings correct, so you need to know it it is a POP or SMTP server, you must fill in the complete and correct e-mailadres and server name and the correct password. if filled in and you press next, the program will check the validity of the address. Only if the address exists and the password is correct it will tag everything green. Then you can use the mail address. It must be an existing mail address. You can't create new addresses in that part.
I'm not sure if you are running the iPad on a G3 or G4 network from BT, because that firm can try to block other mail, to save bandwidth, but I don't believe that.
You should be able to setup the BT account. If you keep having trouble setting up the BT account, visit a bt store and ask them to setup your mail address
Jul 18, 2014 | Yahoo Mail
I have lost the security code and have a new laptop, how do i set it up to work
If you don't remeber the wireless security code, maybe you still remeber the user and password to access the web management interface of the router.
Then you have to connect the laptop to the router by using a network cable. Open a browser window, type in the IP adress of your router and check the wireless setup section. There you can find / modify the wifi security code.
If you don't know the router's IP adress, then open on your computer a ms-dos prompt and type the command
ipconfig /all
it will display your current IP adress, subnet mask and GATEWAY. The gateway adress is the router's IP adress that must be typed into the browser.
If you don't remember the user and password for accessing the router's web interface, please refer to the router's user manual in order to reset it to factory default configuration, and then proceed as for the first installation of the router.
Hope it helped,
Aug 30, 2011 | Belkin (F5D8231-4) Wireless Router...
Someone gave me a dell optiplex 240 pc they did not have the password i have tried removing the password jumper and also the battery and still it asks me for a pass word help
Make sure you remove the jumper with the power OFF (not connected)
Disabling a Forgotten Password
NOTICE: This process erases both the system and setup passwords.
1 Open the computer cover.
2 Remove the jumper plug from the PSWD jumper to disable the
password feature.
See "Jumper Settings" to locate the password jumper (labeled
"PSWD") on the system board.
3 Close the computer cover.
4 Reconnect your computer and devices to an electrical outlet, and then
turn them on.
This erases the existing password(s).
5 Enter system setup and verify that the password is disabled.
Jul 14, 2011 | Dell XPS 400 PC Desktop
How to remove toshiba a200 model the password after power on?
Press the appropriate key to enter BIOS setup.
Enter the current password, to allow you to access BIOS setup.
Then, set a new password.
The password exists to prevent a thief in possession of your laptop from using the stolen computer.
Find your original bill-of-sale, and telephone Toshiba, and they will help the registered owner in resetting the password.
Jul 22, 2010 | Toshiba Sattelite® Pro A200 PC Desktop
My WRT54G lost its security setting and also its network name
Log on to Rtr Setup using Default Gateway.
You will find security centre , where you can set up security for the existing network name .
May 31, 2010 | Linksys Wireless-G WRT54G Router
How do i set up yahoo mail on blackberry storm2
from your mainscreen you will go to setup or setup wizard. from there you go to personal email set up. it will ask you if you want to add an email or create one. you will select add existing email address. you then put in your email and the password you use to access your email from a regular computer. after you submit it and it had verified your email and password than you should start receiving emails in about 20 min.
Mar 14, 2010 | RIM BlackBerry Storm 9530 Smartphone
D-Link DPR-1260 print server setup problem
Try admin for logon & password.
Sometimes it is user ......
Feb 01, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
My computer will not boot up.
First, if there is no password set you may be able to simply press enter leaving it blank and continue with the repair.
Alternatively, you can reinstall WIN XP over your existing installation which will replace your windows files with fresh copies from the CD.
Jan 01, 2009 | Microsoft Windows XP Professional With...
Help for Panasonic Lumix DMC-TZ 1
For a factory reset:
Turn on the camera, push the menu button, push left, down and then right.
You are now on SETUP menu.
Scroll up to the RESET option, push right and then answer YES two times.
Nov 21, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
D-Link AirPlus Xtreme G DWL-2100AP (DHDWL2100AP) 802.11b/g Wireless Access Point Logo
322 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
