Poor line condition message on the brother intellfax 2840 fax machine
SOURCE: "poor line condition'
This is a problem with your voice over ip service. You have to change the setting on your fax machine for example the Baud speed down to 9600, the ECM= off, and the Oversea settings on. Make sure your VoiP ATA is the first thing after your modem or whatever connection you are using for the internet. If you using and old model fax 95% of the time it will not work with VoIP service.
Posted on May 11, 2008
alvinbga
  • 130 Answers
SOURCE: Brother Intellifax 1270E plain paper fax
It could be either. take the machine to anothewr line see if the
error goes away.If it does not call brother customer service. There is an adjustment for input sensitivity of so brother fax machines. It may be in your operators manual
Posted on Jun 11, 2008
  • 75 Answers
SOURCE: poor line condition-can't send fax
Try turning off the E.C.M. mode off ( error correction mode )
I have had a lot off problem's with communication problem's with this function turned on.
It is in your manual under advance fax function.
if need more help let us know.
Posted on Jan 30, 2009
SOURCE: Consistently receiving poor line condition error
The other fax machines are not on the same line though, right? Try installing a line filter.
Posted on Jul 11, 2009
  • 4044 Answers
SOURCE: NG Poor line condition whenfaxing
If this is truely an issue involving poor line conditions you can try using a Line Noise Filter which you can get at most Radio Shack locations. Should cost about 14.99 or so. This could be caused by a loose connection in your home/office wiring or a loose connection at the switch box or anywhere along your line all the way to the tandum. If you actually hear static on the line have the telephone company do the work. Call in a bad connection issue and ask for a line test. If there is a grounded line somewhere that will detect the fault and they can better isolate where the problem actually is located.
Posted on Sep 08, 2009
Unable to Fax. Poor line condition
I Have had this occur on several occasions while trying to fax with a brother fax machine.Sometimes this message will occur if there is a storm or bad weather were the fax transmission signal sometimes seems to be disrupted by storms or bad weather.Wait until the storm or bad weather has dissipated,as this has helped in the past.Also,to help the problem,make sure there are not several members in the household logged on to their computers at the time you are trying to send a fax. I have found that if a computer is on or connected,the message appears frequently with the brother fax machine.To help solve this problem,I make sure no one is connected to the internet,and it works every time.I have noticed this helps the fax reception when I had the same message regarding poor line condition.Make sure any and all other phones that may be on a handset are properly hung up on the base station.Also,try unplugging and then plugging the fax line cord back into the wall,these above steps I have used for years and I also live in a hurricane state.All the above steps have helped with the fax transmission.I hope this is helpful.Carrie
Sep 29, 2014 | Brother Office Equipment & Supplies
Poor Line Condition message
If your fax has a handset listen to the dial tone and make a call if the connection is poor call the phone Co.
DickyO
Nov 09, 2009 | Brother IntelliFAX 1170 Plain Paper...
Poor line condition-can't send fax
Dec 11, 2008 | Brother FAX-575 Plain Paper Thermal
Brother intellfax 2800
Scroll through the menus for NUMBER OF RINGS
Oct 20, 2008 | Brother IntelliFAX 2800 Laser Fax
Black line on all faxes I send to recipients
open the document feeder and look for wite-out on the small scanner glass.
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Very often this is caused by either the sender or receiver having VOIP phone service. Check this and if this is the case you need to set the baud rate to 9600.
Hope this helps!
Jun 09, 2008 | Brother MFC-8840D All-In-One Laser Printer
May 27, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
365 people viewed this question
k24674
jasbo
jasbo
