Thermostats on hot plates not working
Will only work on high .
  • Washing Mach... Master
  • 17,129 Answers
Possible that the selector switch is faulty , possible that the thermo-couple is damaged. In both the cases you need to test the switch or the sensor independently so as to confirm and replace.
Posted on Jan 12, 2013
3f engine
replace thermostat use the right thermostat rating 195 degrees and make sure vechicle has enough coolant in the system not too much air.too much air in the cooling system where engine coolant sensor cant get hot in the coolant where pcm cant get signal to turn on cooling fans vechicle will run hot.the ECT sensor and thermostat need to be in hot coolant to work right.
Jul 18, 2013 | Vehicle Parts & Accessories
Rover 25 1.4 2004 hot engine and radiator fan problem
Yes, it is possible to install a thermostat backwards, though unlikely. If the thermostat isn't opening properly, the hot engine coolant won't be flowing over the cooling fan switch and give you high temps. I would first determine if the thermostat was opening at all, and if it is, is it opening at the proper temp. I have had many new thermostats that, while new, didn't work correctly. To check the cooling fan motor, turn on the AC(if equipped) and the fan should engage. If no AC, disconnect the cooling fan switch, and the fan should engage. Check for power and ground at the fan motor. If you have both power and ground, the fan motor is faulty
Apr 21, 2013 | Cars & Trucks
Car engine temparature always show high,last two weeks temp is normal,some times come to high.i found water very hot in radiator,
Sounds like you need to replace thermostat. Thermostats open and close accordingly to engine temps. When reading goes hi usually indicates thermostat is sticking open, recirculating hot coolant. Now you mentioned it's been reading normal which makes me think this thermostat is not working consistent. So I'd change it now before it overheats and causes alot of damage. Regarding hot water in radiator, after running any time it's going to be hot, normal engine temp is around 195 degrees.
Feb 21, 2011 | Gaskets for Ford Laser
I have a 40 gal model 8IV400 B and the water is not getting hot What should I do?
Hello. Turn up the temperature setting and see if that makes a difference. If not, check the fuse or breaker that feeds the hot water tank. Also check to see that both the top and bottom element are getting power. Finally check the continuity of those heating elements as one or both of them may have gone bad. Joe
4 thumbs up please. ty.
Nov 03, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My gl4 ariston the only way it will heat water is to reset it . It will heat water til it get hot and then you have to reset it to get the water hot again
Occasionally, the high temperature limit shut off device may trigger and shut the
system down. This occurs when water temperature exceeds 190° F and shuts off
power to the heating element. The shut off device may also trigger from a power
outage or electrical storm.
To reach the thermostat:
1. Pry off the round cover plate (V Fig. 3/1) from its right hand edge (W Fig. 3/1) with
a small flat-head screwdriver.
2. Remove the Phillips screw revealed beneath the round cover plate.
3. The cover (C Fig. 3/1) can now be removed by pulling out its left-hand edge. When
reassembling, work in the opposite way being careful to insert the tongue of the
cover into the slot.
4. Firmly press reset button (B Fig. 4). Reconnect power.
5. IMPORTANT: Check the operation of the thermostat, turn temperature dial from
high to low, if the red light does not go off on low setting, turn off power supply and
call a service person to replace the thermostat.
6. If the system works, place dial setting to desired setting. Note: a lower setting is
more economical and reduces the risk of scalding. Replace cover plate.
CAUTION: Call a technician if the high limit needs to be reset frequently.
Sep 24, 2010 | Bosch Ariston GL4 GL4 Point-of-Use...
Hot plates go red hot even on low setting on my westinghouse avondale 529 stove
The hot plate needs a new thermostat. When thermostats go bad, there is no control of temperature and they stay on high. The circuit remains closed, not allowing any cycling of power, which regulates the temp
May 16, 2010 | Ovens
Chef Supreme Co-ordinate Series Ser. No.: 2004434294 Manuf. No.: 091E11SE1 Sales No.: RETSZW Hot plate not working & suspect bad element or thermostat? 1. The element is not an exposed coil, but rather...
this could be a 220 v unit and one side of the lines is out . ck your power at the breaker and at the cook top . if power is ok I would think it's the control sw . and not the plate .. you will need a volt /ohm meter to test . whirl / g e / frigidair / have genric switches that should replace yours .. hope this will help mm
Dec 03, 2009 | Cooktops
Dryer works until it seems to get to hot then cuts off
Check for a faulty high limit thermostat. It is a small round black device mounted on a metal plate. It is usually mounted to the internal ductwork with two screws. It can be tested for continuity using a multimeter or ohm meter. It should have no continuity. If it has continuity, it is stuck open and is faulty. I am attaching a pic showing a thermal fuse and high limit thermostat for reference. Hope this helps and best wishes.
Aug 06, 2009 | Dryers
Where is the reset button model #wh 7l
I am not familiar with this brand, but have worked on many others and they share common components. Here's my best guess: There should be two metal covers vertically mounted on the outside of the water heater, one about chest high, the other knee high. Behind each cover is a thermostat with a red reset button in the plate. In most cases, there is a white plastic snap on cover over the thermostat and wiring. Caution, the wiring is hot. Each wire will have 110 volts on it, and can electrocute you. Use insulated tools, and press the resets with the insulated tools, not with your fingers.
Best regards, --W/D--
Aug 04, 2009 | Amtrol Water Heaters
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
