Question about Vizio P50HDTV20A 50 in. Plasma HDTV
HOW TO TEST YOUR Y BOARD - Vizio P50HDTV20A 50 in. Plasma HDTV
    Top Expert:
  • Vizio Master
  • 74,459 Answers
It is very difficult to describe all details here by this window. In most cases, we can only determine it by replace it with an original number. If you wish to vet more details about the repairs to Plasmas, check this link.
Posted on Jan 12, 2013
Stepmill 7000pt is free spinning and has no resistance.
How to Test the Relay Board on Stairmaster 7000PT Stepmill How to Test Relay Board of a Stairmaster Stepmill 7000PT Disconnect power from the machine.
Disconnect the main cable from the relay board J1 terminal. Main cable should remain disconnected for the duration of the relay board tests.
With the Power ON, place a jumper wire across the GND/BLK and RLY/RED test points. (Ensure jumper wire only makes contact with the designated test points.)
  • Verify that the Relay LED is lit. Remove jumper wire.
With the Power ON, place jumper wire across the +/WHT and FLD/BRN test points. (Ensure jumper wire only makes contact with the designated test points.)
  • Verify that the Field LED is lit. Remove jumper wire.
With the Power ON, place jumper wire across the +/WHT and with the other end touch the ALT/C, FLD/NC, and RES/NO.
  • Verify that the Field LED lights.
If any of these jumps fail, replace the relay board and or power supply. Stairmaster Stepmill 7000PT Electronic Testing of Relay Board
The second link will take you to the service manual. Starting on page 13, you will find some more valuable information on the relay board. Last link will take you to a video on how to test the alternator
Video about Performing Jumper Test on Stairmaster Alternator
Mar 12, 2013 | Stairmaster 7000PT Nautilus Stepmill
Tip
How to Test the Relay Board on Stairmaster SM916 Stepmill
How to Test the Relay Board on a Stairmaster SM916 Stepmill Disconnect power from the machine.
Stairmaster SM916 Stepmill Relay Board Testing
on Feb 25, 2015 | Stairmaster SM 916 StepMill
Fitnex t60 display says prg bad, what does that mean and how can i repair it
1) You must test first the power supply for +5DC for I.Circuit( Including EPROM, ROM, etc)
2) Test the flexible cable between KeyPanel and display board, and clean.
3) Chechk the connector between Display Board with the lower board(Main Controller Motor)for loose connection, loose wire.
4) Test the transformer controller supplying the 12VCA, to the power supply at the Main Controller Board since this supply the +5vd to the Display Board.
Finally you must have Strong Conclusion if the problem is 1)Display Board faulty, 2) Power supply Faulty, 3) Transformer Controller Faulty 4) Main Controller Board Faulty.
For All test you must use Dvoltmeter.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA.C.A
Nov 21, 2011 | Fitnex T60 Light Commercial Treadmill
What is code F-24
E11 Fill time too long. Refer to test (1).
E13 Water leak in tub or air leak in air bell. Refer to test (2).
E21 Water not pumping out fast enough. Refer to test (3).
E23 Drain pump relay on control board failed, wire off pump or pump Replace console control board, wire or
defective. pump.
E24 Drain pump relay on control board failed. Replace console control board.
E31 Pressure sensor not communicating with control board. Refer to test (4).
E35 Pressure sensor indicates water overfill. Refer to test (5).
E36 Console control board problem. Replace console control board.
E38 Air chamber clogged or pressure sensor defective. Check air chamber, rpl press. sensor.
E41 Control board thinks the door switch is open. Refer to test (6).
E43 Console control board thinks the door locking device has failed. Refer to test (7).
E44 Console control board problem. Replace console control board.
E45 Console control board problem. Replace console control board.
E46 Console control board problem. Replace console control board.
E47 Console control board thinks the door PTC circuit is open in spin. Refer to test (7).
E48 Console control board thinks the door PTC circuit is closed. Refer to test (7).
E52 Bad signal from tacho generator. Refer to test (8).
E56 High motor current. Refer to test (9).
E57 High current on inverter. Refer to test (9).
E58 High current on motor phase. Refer to test (9).
E59 No tacho signal for 3 seconds. Refer to test (10).
E5A High temperature on heat sink caused by overloading. Test first-if bad-rpl speed control brd.
E5B High temperature on heat sink. Replace speed control board.
E5C High temperature on heat sink. Replace speed control board.
E5D Communication problem. Refer to test (11).
E5E Communication problem. Refer to test (11).
E5F Communication problem. Refer to test (11).
E66 Heating element relay failure. Refer to test (14).
E67 Input voltage on microprocessor incorrect. Refer to test (15).
E68 Current leakage to ground on heater or fuse opened. Refer to test (14 & 15).
E71 Wash NTC failure. Refer to test (15).
E74 Wash temperature does not increase. Wire off NTC - rpl water valve.
E75 Water temperature sensor circuit. Refer to test (12).
E82 Console control board problem. Replace console control board.
E83 Console control board problem. Replace console control board.
E91 Comunnication error between UI board and console control board. Refer to test (16).
E93 Console control board problem. Replace console control board.
E94 Console control board problem. Replace console control board.
E95 Communication error. Replace console control board.
E97 Console control board problem. Replace console control board.
E98 Console control board problem. Replace console control board.
EB1 Incoming power frequency out of limits. Refer to test (13).
EB2 Incoming line voltage above 130 VAC. Check voltage at outlet. If < 130VAC,
replace the console control board.
EB3 Incoming line voltage below 90 VAC. Check voltage at outlet. If > 90VAC,
EBE Console control board problem. Replace console control board.
EBF Console control board problem. Replace console control board.
EF1 Clogged drain pump. Unclog the drain pump.
EF2 Too much soap. Advise customer to reduce the amount
of soap they are using.
Apr 24, 2010 | Kenmore 43142 Front Load Washer
No heat coming out fan blows but no heat
there's a blend door actuator behind the dash. they are going bad all the times. however, check your coolant level first.
Feb 28, 2010 | 1996 Lincoln Town Car
Ice and water working intermittently, makes ice, Artica PSS 26NG
Go into the test mode and use 0 4 as the test code between the dispensor board and the main board .(communication test) Sounds like the main control board though .
Jul 18, 2009 | GE Profile¿ Arctica® Energy...
Paxar 636 diagnostic test 2 error
paxar 636 diagnostic test 2. i've encounter this problem last 2004. the diagnostic test stops at diagnostic 2. what we did is that we've checked the mother board and the printhead board. basically those boards are the main problem when you encounter that error (diagnostic test 2 error ). what we did is that we changed the mother board as well as the printhead board.
Aug 02, 2008 | Avery DesignPro Deluxe CD-ROM...
Code E 70 on a 6000
Here are all the Fault Codes on the 6000/7000 but i dont see a E70 on here are you sure?
Failure code Fault condition Check
E11 Fill time to long. Refer to test (1).
E23 Drain pump relay on control board failed. Replace control board orwire.
E24 Drain pump relay on control board failed. Replace control board orwire.
E36 Control board problem. Replace the control board.
E41 Control board thinks the door switch is open. Refer to test (7).
E43 Board communications problem. Replace the control board.
E44 Board communications problem. Replace the control board.
E45 Board communications problem. Replace the control board.
E46 Board communications problem. Replace the control board.
E47 Board thinks the door PTC circuit is open in spin. Refer to test (7)
E48 Board thinks the door PTC circuit is closed. Refer to test (7)
E56 Highmotor current. Refer to test (9)
E5A High temperature on heat sink. Test first if bad replace
E5B High temperature on heat sink. Replace the speed control
board.
E5C High temperature on heat sink. Replace the speed control
board.
E68 Current leakage to ground on heater or fuse opened. Refer to test (14).
E74 Wash temperature does not increase. PlaceNTC in correct position.
E76 NTC temperature for the cold water valve over the limits. Hot and cold water hoses
switched.
E82 Console control problem Replace the control board.
E83 Console control problem Replace the control board.
E91 Selector LEDs do not light up Refer to test (16)
E93 Console control problem Replace the control board.
E94 Console control problem Replace the control board.
E95 Communication error. Replace the control board.
E97 Console control problem Replace the control board.
E98 Console control problem Replace the control board.
EB1 Incoming power frequency out of limits. Refer to test (15)
EB2 Incoming line voltage above 130 VAC. Check voltage at the outlet.
If below 130 VAC replace the
control board.
EB3 Incoming line voltage below 90 VAC. Check voltage at the outlet.
If above 90 VAC replace the
control board.
EF2 Tomuch soap. Advise customer to reduce
the amount of soap they are
using.
EBE Console control problem Replace the control board.
EBF Console control problem Replace the control board.
EF5 NTC temperature for the hot water valve over the limits. Hot and cold water hoses
switched.
May 08, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing machine error code on Frigidaire ATF6000E
No E20 on that model# Heremis a list of the codes
board.
board.
switched.
Mar 29, 2008 | Frigidaire ATF6000ES Front Load Washer
I think I figured this one out. I think it means that the washer is not able to drain, therefore it won't spin either. Underneath the washer is a series of outlet hoses and within one of them is a filter. When I finally found the filter it was clogged up with lint, fibers from a pillow and coins. You have to dig the filter out and then clean the filter and rehook up the hoses, this was relatively simple even for me. The washer works perfectly now.
Vizio P50HDTV20A 50 in. Plasma HDTV Logo
32 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
