Question about Brother IntelliFax-2920 Plain Paper Fax, Copier and Phone , 33.6 Kbps Modem Laser
WHAT IS ERROR #202 MEANS
WHEN WE TRY TO SEND FAX .IT GET DIALED BUT THERE AFTER WE GET AS IF LINE IS BUSY AND FAX DOES NOT GO.
OUR FAX MACHNE IS LESS THAN 2 YEARS OLD AND MODEL NO. IS BROTHER 2920.
PLEASE HELP. OUR'S IS SURGERY AND WE NEED TO KEEP FAX MACHINE ON TO RECEIVE MEDICAL RECORDS
  • Anonymous Mar 16, 2009
    i have 1 fax mechine 2920 if i am trying to send fax tat time getting message from there bussy.........
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
There is no such thing as error 202 on Brother FAX 2920. Are you sure about that? Search the users manual i provided for more information
Posted on Dec 01, 2013
    Champion:
  • 320 Answers
Hello! i just checked the dervice manual for the rror202 that you said that you are having did not find that code could you clarify thanks brother sr tech
Posted on Jan 24, 2009
What does transmission report cdoe NG290000 mean on a Sharp MXM363n MFP When trying to send a fax?
My recommendation would be to hit the speaker button when sending a fax to hear why your fax wont go through.
When you hit speaker you should have a clean dial tone, then when you start dialing and the tone stops make sure you don't have any static or noise on the line.
There are several reasons you might get a NG error. One is the fax line you're trying to send to is busy. Maybe it's a phone line not a fax you're trying to send to. Maybe you need to dial a 1 or 0 for long distance, maybe your fax line has noise on it.
Using the speaker can help troubleshoot what the problem is.
Jun 12, 2014 | Sharp Mx-M363n Copier, Printer & Scanner...
Why won't the fax work?
Skelton Business Equipment Houston Copiers
May 08, 2014 | Sharp MX2610N Printer
How do you send a Fax?
1 Load the document face up into the Document Tray.
2 Dial the receiving party's fax number.
3 Press [Start/Copy].
The fax begins sending.
Note
If an error occurs during sending, the fax beeps intermittently for a few seconds and an error
message appears on the LCD. If this happens, correct the problem and then press [Stop], then
try sending the document again.
The fax automatically redials if the receiving party does not answer or if the line is busy.
Feb 21, 2011 | Canon FAX-JX200
Fax is always busy when sending, have the line into the phone line port and into the telephone jack, fax scans and dials and even redials but it never go through, prints out receipt that says busy/no...
Has it always done this, or did Fax once work? Sadly, Windows XP Fax has many shortcomings, not the least of which is that it won't work with many modems still in common use. Modem incompatibility is not apparent during installation or the initial setup. It only becomes apparent when you try to send or receive a fax. The Fax Service will dial or will answer an incoming fax but then fail with any of a number of unhelpful error messages such as "Line is busy," "There is no answer," or "Reception error." There will be nothing in Event Viewer to give a clue as to where the problem might lie.
These errors have been nearly impossible to track down. To do so requires enabling both PSS and debug logging of fax transmissions, both of which require fairly extensive registry changes. For the time being, the best advice is to attempt to use XP Fax only if you have a modem that is listed on the Windows XP Hardware Compatibility List and using the latest drivers.
Hope helps.
May 09, 2010 | Brother MFC-5840CN All-In-One InkJet...
Every fax we try to send it comes up with a error tx report of "NG". What does "NG" mean and how can we fix it?
Hello.
NG means: Some or no pages sent.
Check the paper feeder to see if the page is pulling through.
Listen to see if the fax line "sounds"like it is working or if you hear dialing or not.
Hope this helps.
Mar 22, 2010 | Canon FAXPHONE L80 Laser
Status 50 on a fax estudio 45
the number is busy. Try pressing the monitor button and listening for a dial tone. No dial tone means your phone line is not working. If you have dial tone, dial the number you wish to fax and listen to see if it picks up. If you get a busy signal, or hear someone answer, that is why it's not working. If you hear the fax tones, press start and send your document. This is a way to fax that allows you to hear the whole process.
Aug 10, 2009 | Toshiba E-STUDIO 450 Copier
Ricoh fax error #400
Possibly the fax line is open (busy). Try ringing the fax number, see what you get. Try unplugging the fax and plug a normal analogue handset into the line. See if you are getting a dial tone.
If not, then the cabling or line are faulty. Talk to your carrier. If yes then replace the cable on the fax (if possible) or have it looked at.
Mar 03, 2009 | Ricoh Office Equipment & Supplies
Difficulty sending a fax
Hello. Please make sure your telephone line is plugged into the correct outlet.
Most fax machines typically allow you to plug the line (the cord that goes from the fax machine to the wall jack) and and a telephone (the telephone connects to the fax machine).
In order to fax correctly, you must plug the line into the jack with a block (looks like a 'T') marked on it. Do not plug the line into the jack marked with a phone hand set marked on it.
http://gdlp01.c-wss.com/gds/0900002546/PIXMA_MP780_750_Easy_Setup_Instructions_EN.pdf
This shoulds in detail how to connect the line properly. For this printer the line cord must be plugged into the jack labelled "L"
http://gdlp01.c-wss.com/gds/0900002542/PIXMA_MP750_780_Quick_Start_Guide_EN.pdf
This will show you how to actually send the fax. On your PDF View select page 42.
Feb 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Error 401 & 634
error 634 is an indication that the line was either busy, or there was no answer on the receiving end.
Jul 23, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
Brother IntelliFax-2920 Plain Paper Fax, Copier and Phone , 33.6 Kbps Modem Laser Logo
331 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
