Question about Maytag Atlantis MAV6000 Top Load Washer
Loud Clicking noise only for the first 30-40 seconds of spin cycle.
Over the past few weeks I have noticed a loud clicking noise during the spin cycle. Last night I removed the front cover to inspect the insides. I didn't see anything obvious, I also tilted the washed back and inspected the belt. I removed the belt and hand spun the pulleys both the Larger basin pulley then the water pump pulley, both seem to move freely in both directions without any noticeable restrictions or sounds. I then removed the plactic dust cap from the bottom of the larger basin pulley and there were no shavings to indicate any damage. I then put the washer back down and stared a load with the cover off. I advanced the timmer to speed up the test, and again the loud clicking but I cannot locate it. Now , here is what I am thinking, maybe the water pump. The water pump has a somewhat clear top, and I can watch the water flow throughout the spin cycle. The clicking starts when the water is flowing through and just when the pump starts to cloud up with soap residue, or the tub is empty, the clicking start to fad and the silent. The rest of the spin cycle is quite. Any Ideas??
  • brandon aly Jul 06, 2007
    Thanks for the quick response. Last night I performed some test to hopefully isolate the trouble. I advanced to cycle to spin and started the washer. Then when the spin cycle started, something was making a hell shish racket. A waited for the noise to fade away (32 seconds exactly), then I opened the lid, stopping the spinning action. I then closed the lid and the basin started spinning again but this time no loud sound. I repeated this several times all with the same result!
    Due to my inexperience with working on appliances I am very cautious about making quick judgments, but I am leaning towards a water pump simply because of the following:
    1. It only makes the sound during the spin cycle (water pump is only active then)
    2. It last for only 30-40 seconds (About the time it takes to pump all the water out)
    3. After the water drains and the spin cycle is interrupted then restarted, the sound goes away.
    Thanks for the previous post; I think you are on to something. However I am unfamiliar with appliance water pumps and haven?t the foggiest clue on how these contraptions work. Can I take the water pump apart, are they serviceable?
  • 5,911 Answers
You may have something caught in the pump impeller. I have found nails, screws, drill bits, paper clips and other small items that some how make their way past the wash tub and into the drain line. I would inspect the drain pump. Remove as much water as you can. Using a wet/dry shop vac to pull water through the drain hose is the best way to drain all residual water from the pump and drain lines. Remove the inlet line first and inspect the pump impeller. Chances are, you have something stuck causing the impeller to rub against it. If this has gone on too long, you may have some damage to the pump. I hope this is helpful to you.
Posted on Jul 06, 2007
  • Jeff Rockwell
    Jeff Rockwell Jul 06, 2007
    Unfortunately, I do not believe the pump is serviceable on your washer. You can remove it and look inside either end of the pump, but I don't believe you can open it up. You may be able to see what is causing the noise (if this is the case) and fish it out, or simply just replace the pump and be done with it. Part number 1000731 on repairclinic.com. The part runs slightly less than $50. Good luck.
Started making loud "clicking" noise
Blocked pump, open flap bottom right, drain off excess water manually and remove pump filter. Make sure you get right down and have a look in at the impellor and give it a turn to make sure its free to rotate. You'll probably find a coin, button etc that is catching the pump impellor. When you start a cycle the pump engages for a few seconds and then the w/m takes in water, so if something is stopping the impellor rotating the w/m will not start.
Best of luck
Jul 13, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Loud noise during spin cycle
what kinda noise, sqeeling, or clunking, mite be sumthing small that made its way behind ajatator an is causeing noise..or one of the springs that hold it broke..sorry i dont no what kind of noise.....
Jan 31, 2010 | Washing Machines
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
My washer is making a loud, clicking noise
One of them underwire garments could be stuck in the pump and eating a hole into it.You should take the cover off and take a look at it in motion without the case.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 24, 2009 | Kenmore 24032\24036 Top Load Washer
Extremely loud noise during spin cycle of my Neptune dryer--just started happening in the last month. The dryer is probably 7-8 years old, so it's not the newer Neptune model.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
hgd76
Jun 26, 2009 | Maytag Neptune Washer
Loud spin cycle
OTHER THEN CHECKING THE WATER PUMP I THINK YOUR RIGHT THE BEARING ARE GOING,IT WILL WORK FINE TILL THEY LOCKUP THEN THE BELT WILL BURN OFF,BUT I WOULD CHECK THE WATER PUMP ALOT OF TIMES IT JUST THAT,LET ME KNOW -MIKE
Nov 03, 2008 | Frigidaire FTF530ES
HOOVER 510 PREMIER WASHING MACHINE ABOVE THE BELT SHAFT THERE IS A PLASTIC COG WHEN THE WASHING MACHINE IS ON WASH CYCLE IT SPINS FINE ONE WAY THEN ON THE REVERSE SPIN THER IS THIS ORANGE LEVER THAT MAKES...
I imagine you've bought a new machine by now? The plastic gearcog is the clutch housing. The arm that clicks is part of the brake lever. On these models, the brake lever is supposed to hold the clutch in place during the wash cycle so that it slips in both directions to get a forward and reverse wash. On spin, the lever moves away releasing the clutch and gearbox brake and allowing the bowl and agitator to spin together. The brake lever wears and allows the gearbox to slip during the wash cycle. When this happens, the clutch housing will "ratchet" past the brake lever tongue. this causes the "clicking" noise in 1 direction.
Oct 17, 2008 | Hoover Washing Machines
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Loud noise on Spin Cycle
CENTER SUPPORT BEARING IS BAD. VERY COSTLY IF NOT UNDER WARRANTY USE FOR BOAT ANCHOR. GOD KNOWS I HATE TELLING PEOPLE THAT. SORRY, FXIT
Oct 11, 2007 | Admiral AW22 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
232 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
