Question about Dryers
Dryer Drum will not turn .
Power is OK Can turn drum backwards but to turn forward is very difficult
Dryer belt appears OK
This problem started part way through a Cycle.
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    dose your dryer make a noise like its trying to start,or no noise at all.what brand?how old?
    Novelist:
  • 101 Answers
Your motor is freezing up. That is why you can turn it backwards but not forwards. Look back there at the motor and see if there is just a problem with the pulley first. Also check the wheels located on the drum and see that they spin okay. If all that is okay though you have a motor problem. It's an expensive repair if it's your motor. Look for a refurbished one as it will be a lot cheaper then a new motor. Let me know if you have any other questions and good luck. Also let me know if this was helpful to you.
Posted on Jan 22, 2009
Dryer turns on but drum will not spin
Sounds like the belt is bad or the motor needs to be replaced. Unplug unit. When you open it up get a block of wood (a piece of 2x4 works) if your units are stacked on top of each other, pull the dryer towards you approx 2inches. You are going to push on the top of the dryer and insert the board underneath the dryer. The reason you pulled the dryer forward was to keep the dryer from slipping backwards while working on it. Now check the two bottom corners on the front of they dryer.occasionally there are screws holding the kick plate. Take these off, pull out and down and look for broken belts. Be sure to vacuum any loose lint while you have the unit open. Good luck.
Jul 14, 2014 | Kenmore Elite HE4 Electric Dryer
Tumble dryer drum not turning under load
Was the belt changed recently? The reason I ask is because it sounds like the belt was put on backwards, meaning the ribbed tire looking side of the belt is facing upwards instead of making contact with the drum. The symptoms of this are the exact same you are describing.
May 15, 2012 | Dryers
My dryer squells through the entire cycle.
You will need to replace the dryer belt. To do this follow the instructions below
  • Disconnect the power for your dryer before beginning any work. It can be disconnected from the wall outlet.
  • 2
    Open the top of your dryer cabinet and tilt it backward.
  • 3
    Use a Phillips head screwdriver remove the top two screws. Put the screws in a safe place.
  • 4
    Tilt the front forward and roll the belt around the drum.
  • 5
    Remove the old belt by lifting the drum slightly in order to give way to the front supports. You may have to open the dryer door to help the belt fall to the bottom of the basket.
  • 6
    Position the new belt by aligning it in the correct position before beginning to thread it through the motor pulley and idler. It will take someone with strong fingers and skinny arms to be able to get past the drum in the front. The dryer belt in a General Electric dryer has to be threaded looking in from the back.
  • 7
    Reassemble your dryer by replacing the screws in the top of your dryer.
  • 8
    Close the top and slide the dryer back against the wall.
  • 9
    Reconnect the power to your dryer by plugging the cord back into the wall outlet.
  • May 02, 2011 | GE Dryers
    1 yr old whirlpool dryer, belt and pulley ok but will drum will not turn. motor appears to be ok
    ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
    Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
    If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
    If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
    Note: This method works for most front loading machines.
    Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
    Remove the lint filter and the screws that hold the filter housing.
    Then remove the top of the dryer.
    Note: Some of the tops tilt backwards and do not have to be removed completly.
    Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
    Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
    While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
    This is a FREE answer, Please rate me
    Oct 05, 2010 | Dryers
    Is60v belt replacement. The replacement belt seems difficult to fit.size/ belt number checked against old one & details are the same. What is the method of replacing / refitting the belt?
    The belts do appear to be undersize, this is because they are a stretch belt, and this makes them very difficult to fit.
    Remove the top cover and right hand side panel of dryer, this will give you access to the belt.
    Move the front panel forward to fit the new belt on the drum, and then you really have to pull hard down on the belt to get it round the motor pulley.
    It is very difficult.
    Good luck.
    Jan 16, 2010 | Dryers
    Whirlpool Electric dryer won't start
    Your problem sounds like it could be a broken belt, faulty motor, or maybe the belt has slipped off of the motor or idler arm pulley.
    You can try this first:
    Uplug the dryer, reach inside and try to turn the drum 1/4 to 1/2 turn, the plug the dryer back in, and push the start button. Sometimes motors will get dead zones in them and this will move it from that zone.
    If you attempt the repair, and if you have a front loading machine, you would remove the front of the machine, this will expose the drum and belt, you can now check the belt to see if it is ok. If it is ok, then you can remove the drum and belt and this will expose the motor, idler arm with pulley and drum rollers.
    While you have the drum out of there it is a good time to check the condition of the drum rollers to see if they have flat spots on them, if they do have flat spots on them, then need to be replaced. If not then I recommend that you lubricate them at the shaft with a good grade of Machine Oil such as 3 in One oil. This will save problems later.
    Good luck,
    I hope this helps you
    Oct 04, 2009 | Whirlpool LER5636P Electric Dryer
    Hoover Washer/Dryer WM120 : Dryer function - drum not turning
    There can be many reasons why your dryer will not start or turn...
    The most common causes are the belt breaking or jumping off, or the motor goingbad...
    Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
    Dryer Repair - The Dryer is not Turning
    Dryer Repair - The dryer will not start
    heatman101
    treru
    Jan 25, 2009 | Hoover H120M Front Load Washer / Dryer
    Kenmore Dryer: Drum will rotate, but only manually
    Best way to confirm if it's a belt/pulley problem is to remove one of the access panels on the back of the dryer. For many models, it's on the bottom, right hand side. Open it and look inside. You also use that access panel to put a new belt on since it can be difficult to do from the front, having to reach past the drum. But if everything is intact, then you should be able to "rethread" the belt around the idler pulley and onto the motor pulley.
    Here's a common diagram:
    If the belt is OK, but came off the pulley, then most likely, your idler pulley has too much play in it or the spring has lost tension and isn't holding it securely. I'd put the belt back on. If it comes off again, then look into replacing the idler pulley and/or spring.
    Oct 20, 2008 | Kenmore 62602 Electric Dryer
    Dryers Logo
    51 people viewed this question
    Top Dryers Experts
